Question about APC SURT1000XLI 1000VA 700W 230V UPS (SURT10000XLI) UPS System
Surt10000xli show the dc bus over voltage fault What can I do
Trun on the cold start ups show the fault led of dc bus over voltage fault.I've check the Inverter board component but I don't find any faulted component.Please help me.
3 Suggested Answers
  • 68 Answers
SOURCE: Overload LED lit, constant warning tone, no load
you may have to many things plugged into the ups, it is not good to plug a power bar into one of the outlets of one of these as you are OVERLOADING the device with more power than it can produce
Posted on Oct 24, 2009
SOURCE: hello there i have an APC
Usually UPS works like a breaker. Once you replace the parts, press the reset and that should make i work again.
Hope this works for you.
Posted on Jul 19, 2011
Where is the problem with "-DC bus low" EX11RT?
How are you checking the batteries? If you are simply reading the voltage with a multimeter, then this is probably your issue. The batteries, when getting worn out, will often show full voltage in a static (non-loaded) state, but as soon as they are called on to produce load, their voltage will drop significantly, thus giving the DC bus low indication. Batteries in UPS's are similar to car batteries, they need to be tested under load to ensure they are good. If they are three years old or older, chances are they need to be replaced.
Jun 18, 2015 | Computers & Internet
Pw9120-700i dc bus fault ,low o/p v messages
If your batteries are ok a DC BUS fault and low o/p voltage means one of the componants inside is defective. An end user can not effect repair. You need to have it looked at.
Jul 14, 2014 | Powerware 9120 UPS System
SURT10000XLI
usually shows up where there is NO GROUND or batteries dead
Mar 25, 2014 | APC Computers & Internet
Complaints
nothing fixya site can do for you
this is between you and the bus company
Mar 19, 2017 | Cell Phones
I have a 4500 John Deer tractor that typically won't start in cold temperatures (i.e. 39 or below) otherwise it starts promptly. I've pushed the key in to heat the glow plug a minute or more.
The 4500 John Deere tractor sounds like the glow plugs are not working. Checked voltage at the glow plugs to make sure that there is 12 DC volts.(Might have to remove main wire from the glow plugs to check!) If no voltage at glow plugs there maybe a bad fuse,relay or wire connection in the glow plug circuit. If there is 12 DC volts at the glow plugs, it is possible that the glow plugs need to be replaced.
Jan 01, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Micromax x225 is showing low signal
Ever looked at the power specifications of a mobile charger?? well if not, then have a peek... u will read that the output voltage is 5V DC........ the computer USB also has a voltage output of 5V DC........... any USB based electronic device needs this power to get started.... The laptop coolers u get basically work on this power from the USB... U'll notice that the USB ports have 4 terminals.... the extreme outer side are the POWER terminals +ve and -ve..... the middle 2 are the BUS lines IN and OUT.... a BUS is something electric conductive that allows the flow of 0's and 1's or rather high and low voltages to pass(Basic IT theory).... so this 5V DC can be used for doing anything; charging the mobile phone battery to lighting up entire rooms with LED's, making laptop coolers, etc......... Every mobile phone which has the USB connectivity option gets charged when plugged in... so sometimes even if u dont have the Mobile charger dont panic, find a computer and plug in the USB... not only micromax x225 mobile but, there are almost 80% mobiles which charge by connecting it to pc. Only nokia phones don't get charged. it is a good feature don't worry
Feb 24, 2012 | Nokia Cell Phones
Surt10000xli not switching on
my ups surt10000xli ups shows internal faulty LED On, i have checked main board but couldn't find the fault. please tel me the fault
Feb 15, 2011 | APC SURT1000XLI 1000VA 700W 230V UPS...
APC SURT1000XLI 1000VA 700W 230V UPS (SURT10000XLI) UPS System Logo
638 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
