I am trying to connect my samsung sound bar to my new sharp equos 60 inch LED (Model: LC-60LE600U) an optical cable. I have a direct tv receiver and blue ray player hooked up with hdmi cables. I have tried everything and I get no sound!! PLEASE HELP
I just got this TV 3 weeks ago. I noticed the AUDIO issue too.
Every power up, HDMI change etc, I would have to go into the MENU/OPTION/ and toggle the PC IN/HDMI IN setting to get my Optical OUT AUDIO working.
WARNING:
DO NOT UPDATE TO THE NEW FIRMWARE. :(
Tonight I decided to do the Firmware Update on this AQUOS LC-60LE600U with hopes that my audio issues will be fixed.
WRONG... Now I have NO Digital Optical OUTput, and worse, the trick to Toggle (PC IN/HDMI IN) No longer works!!
So now I am out of luck and NO LONGER can use OPTICAL OUT for any of my Dish Network Satellite TV Viewing.
I called SHARP AQUOS Tech Support , firt Rep sucked , had nothing but stupid responses like , use RCA Audio OUT.
Or just plug your OPTICAL OUT from your Dish Network HopperDVR Directly to my A/V Home Theatre Receiver.
I may have to do that afterall!!!!!!! But this simply Bypasses the PROBLEM and doesnt resolve my TV Optical Out Problem.
Then I called , talked to a Very nice guy named Travis. He explained it.
I hope some of you can explain it to be better, but here is what he said.
HDMI has some kind of Digital Content Protection, LLC provides HDCP (which was developed by Intel) for HDMI.
apparently this is the JIST of this he said. Exoplaining some issue where Powers That Be, (BIG MOVIE CORP) or such want to make it so Digital Audio cant pass from HDMI to OPTICAL as easy???????
I dont get it. So it was never supposed to ....... BUT.. The (PC AUDIO IN/HDMI IN) Toggle trick made it work.
Turns out the NEWER Firmware Fixed it so the Toggle Trick WONT WORK.
I cant imagine this is going on. How many Millons of TV Viewers experience this? There has to be more to it than this.
My HOPE..... is to find the OLD Default Firmware for this TV, cause even though a Hassle to TOGGLE on the AUDIO, better than NO AUDIO NOW ! ARGH!!!
Please, if anyone can provide ANY info or firnware files for our AQUOS LC-60LE600U I would be SO MUCH HAPPIER.
Hope this helps everyone!
Dave in Iowa
Posted on Dec 04, 2013
  • David Voy
    David Voy Dec 04, 2013
    UPDATE: I was forced to bypass my TV Audio by Directing my Optical Audio Out from my Dish Network Hopper DVR straight to my Home A/V Surrond Receivers Optical IN. , id rather have my TV\'s Optical Out pump into my A/V Receiver, but this TV NO LONGER WORKS AT ALL with the new updated Firmware.
  • David Voy
    Since I have Optical Going straight from my DVR to my A/V Receiver, now the people on TV lips DONT 100% sync with my DANM Audio. The TV has no Lip/Audio Sync adustment either . What a DRAG! I hate this Sharp AUQUOS
gymhasafit
  • 31 Answers
SOURCE: 8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Posted on May 05, 2009
SOURCE: HK AVR 645 7.1-Receiver Turns off when sound starts to come through
Hello, I didn't end up fixing the Blu-ray issue, but the TV issue was caused by just inverting the positive and negative cable going into my speaker. Odd enough, instead of just not working, it just flipped the entire system off. I can definitely see that that could be the issue, another one I thought of is, at the time I didn't realize that DVI doesn't play audio, only video and I didn't have a optical cable connected. I decided to avoid the hassle, sell the TV and purchased one that has HDMI. Muuuuch better.
Posted on Aug 08, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Posted on Sep 17, 2009
Testimonial: "worked like a champ!"
  • 336 Answers
SOURCE: I just bought a Blue Ray player but my surround
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Posted on Nov 21, 2009
My LC 60le600U Sharp 60 tv Aquos brand will not stay on. it powers up then turns back off after a few seconds
if this tv is still under warranty i would be filling a claim straight away this is almost always wither a hardware or firmware fault both of which if stock should be covered under warranty.
good luck.
Feb 11, 2017 | Sharp LC-60LE600U 60" LCD LED TV 1080P
LC-60LE600U DUNTKF908WE04
Sounds like corrupted firmware. A firmware update is necessary. Contact the authorized service center for Sharp.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 08, 2016 | Sharp AQUOS LC-60LE600U 60" LED TV...
How do I get please run channel autoscan off the screen
On my older sharp non-smart TV there is a back/return butting on the remote.
Feb 14, 2015 | Sharp LC-60LE600U 60" LCD LED TV 1080P
What's wrong when sharp 60" aquos led hdtv doesn't even power on?
I had the same problem and the power light was blinking a specific code (3 slow and 1 fast). I made a video on how I fixed it.
Sep 14, 2014 | Sharp AQUOS LC-60LE600U 60" LED TV...
No sound thru pioneer equaliser from quatrron tv
There are two way to do this.
1. Connect all your devices individually to the Pioneer receiver. Doing this allows you so have different sound settings for each input. A reason you might want this is that your DVD will need a DTS or Dolby sound setting so that you get the best audio from your DVD, whereas your TV may only be outputting stereo audio. In this case you would set your Pioneer to a stereo setting.
2. Connect your devices to the Sharp display, then connect the audio output of the Sharp to a free audio input on the Pioneer.
Your Sharp LED TV has two ways to do this: a. If you have a digital capable Pioneer sound system, connect using the "Digital Audio Output". You will need a Toslink (Optical) cable for this connection. b. If you only have analog capabilities in your Pioneer sound system, you must use the 3.5mm (1/8 Inch) analog audio output from the Sharp TV to stereo RCA (red and white plugs that are most commonly supplied with home theatre product).
Oct 27, 2012 | Sharp AQUOS Quattron 60 Class LED 1080p...
Help setting up my new tv
Click here to download the user manual to your TV. It has all details.
Oct 21, 2012 | Sharp LC-60LE600U 60" LCD LED TV 1080P
Hi.How can I connect SHARP HT-SB400 sound bar system to TV SAMSUNG UE40C6000 LED? I have RCA cable supplied by sharp, it's that possible? My SAMSUNG operation system is : T-VAL6DEUC-1016.0
You should be able to connect these but you'll need some extra adapters/converters/cables. The Sharp HT-SB400 has analog audio inputs (http://www.sharp.co.uk/cps/rde/xchg/gb/hs.xsl/-/html/product-details.htm?product=HTSB400&cat=10500 ). The Samsung UE40C6000 LED TV has a digital (optical) output and a headphone jack (http://www.samsung.com/uk/consumer/tv-audio-video/television/led-tv/UE40C6000RKXXU-spec ).
With a RCA (F/F) to 3.5 mm (M) adapter, you may be able to connect the headphone audio out to your sound bar directly. This is an example: http://www.cyberguys.com/product-details/?productid=4730 . I'm not sure if this will automatically disable the TV speakers.
The other option is to get a digital audio to analog audio converter. One of these is http://www.amazon.com/Digital-Audio-Analog-Converter/dp/B0013LWK3A . You'll also need the optical digital cable in addition to the RCA audio cable that you have. With this you'll have to follow the manual for turning on the digital audio output on the TV (under the Sound menu) and turn off the TV speakers.
I hope this helps.
Mar 04, 2012 | Sharp Audio Players & Recorders
How to connect sharp HT-SB350 to Sharp LC-42D69U
You may have to use the optical cable connections. Make sure there is an optical out on the tv and on the sound bar. Get an optical cable to connect them and go to the audio setup screen and direct the sound from internal speakers to optical out.
Nov 13, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
1,280 people viewed this question
 Grubhead
Grubhead
