Question about Nokia 6500 Classic Cellular Phone
Overheating during conversation
Every time that I am on the phone for more than 2 minutes the phone just starts to overheat, most of the times I need to turn it off since it burns my ear.
  • 65 Answers
I would conntact the company directly! Either by e-mail or phone number, refer to your maual for the number in the help section. Are these the correct batteries for this unit? Sometimes if you have the incorrect battery , this may be the problem, check your manual for the correct ones to use, there are different batteries for use in different phones. I wouldn't use the phone until you get an answer.
Posted on Jan 05, 2009
2000 Lincoln LS Overheating
The water pump is wearing out and causing the leaks also could be having issues with the impellors because of the wrong mixture that you had in it. Might have ice damage. It needs to be replaced. Check the hoses to see if any have seperated. And last, there is some variance in temp when the rpm changes during driving. This is normal. Temp does affect how the engine performs. In order to be sure though, you cannot go by what the dial on the dash says. You need a reliable engine themometer. OBD readers can access that.
Jan 31, 2014 | 2000 Lincoln LS
Compucessory CCS 60062 shredder overheated
These units take about 24 hours to recover... unplug unit and let it sit for 24 hours...the unit will reset once plugged back in after.
Dec 24, 2013 | Compucessory CCS 60062 Shredder
My 2005 Dodge neon starts to overheat and the fan does not turn on
items needing checking
fan, relay ,2 fuses
coolant temp sensor
Jan 18, 2018 | Cars & Trucks
Car dies, after short time, it will start
For car running hot and overheating issues,i suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems :----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Feb 06, 2012 | 2000 Hyundai Accent
Engine overheats
have you changed the thermostat it sound's like it's intermittently sticking !!!
Sep 19, 2009 | 2002 Chrysler PT Cruiser
Overheats, and wont switch gears at times.
Well overheating and not starting are possibly 2 different issues. Oil is not the cause of overheating. Thermostat, water pump, electric fans and viscous fan are causes for overheating plus the sensors that control the fans. Not starting could be caused by the overheating but most likely its a fuel or ignition issue.
Jul 29, 2009 | 1997 Mercedes-Benz E-Class
I have a 1999 hyundai elentra and it overheats all the time. im wondering how i can fix this problem? i have no other problems just the engine overheating during the summer. i just spent $1500 on it and i...
Well could be a couple of things. It could be the thermostat "sticking". Or it could be like a couple of vehicles that I've had where a small radiator leak has caused it to overheat. I would try flushing the radiator and see how that does. What I would recommend though is Prestone Super Flush be used to flush all the **** out. And when you refill the radiator use a tube of radiator stop leak (the powder type). You can use the pellets, but the powder seems to work a little better. What I've always done is to put the Prestone flush in the radiator and let it circulate through the system with the heat on the highest setting. After maybe 10 minutes remove the lower radiator hose making sure that you have on long sleeves and are using long rubber gloves so as not to scald yourself, because it will be scalding hot. Once all of it is drained out, I just used a hose and let the water run through there and circulate and come out at the disconnected radiator hose, maybe another 2 minutes. After that, put the radiator hose back on. Add the powder stop leak product and add radiator fluid until full. If this does not stop the overheating then you may need to replace the thermastat but I would start here first. It has worked with me on (3) different vehicles.
Jun 08, 2009 | 1998 Hyundai Elantra
Beeps like a fax during conversations
you might have your phone connected to a fax machine. also sometimes cordless phones pick up other talk.
Nov 15, 2008 | Uniden Cordless Phone
Overheating engine: termo guage at the middle during idle
The Temp gauge should read in the middle of the gauge at operating temperature. This is normal. The radiator fan should come on after idling (not driving) for 20 minutes. The fan should also come on when you turn on the AC. Are you experiencing overheat problems?
Please reply if you have overheating issues.
Oct 16, 2008 | 1994 Toyota Corolla
Nokia 6500 Classic  Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
