Question about Nintendo Guitar Hero Wireless Guitar - Wii for Wii
Guitar strums by itself, tilt star power is not sensitive enough
Anyone have a problem with the guitar strumming by itself?, sometimes right finger is nowhere near the strum nor the frets nor the neck, and itll strum once or twice just because I maybe slightly moved the guitar. Also it seems as if I am forced to push the star power button, because when tilting upwards it registers only 1/3 of the time. Is my guitar bad? or is anyone having similar problems?
  • Anonymous Jan 07, 2009
    i have the same problem with mine but it dose it all the time only when i am in a song though and it is getting very angrvating
    Problem Solver:
  • 14 Answers
Please read my solution here -
Posted on Jan 05, 2009
Why is there a faint crackle from the amp when I strum?
Assuming that the problem goes away when you plug a differebt guitart into your amp, you have a loose ground somewhere in the guitar.
Aug 09, 2015 | Music
If I strum harder on my guitar a buzzing noise comes out of the amp. Also every sound I try on the amp sounds very twangy and painful to the ears. I use an overdrive pedal with it, but every setting is...
If you don't want distortion, get rid of the overdrive pedal... Twangy USUALLY comes from the GUITAR and NOT the amp... test it on a different amp to decide... Buzzing CAN be caused by "fret buzz" which is due to IMPROPER guitar setup such as neck bend and string height.
Start using ONLY clean channel on the amp and NO reverb. If you verify that the guitar sounds bad on a different amp, take it in to have it setup properly.
Feb 10, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
My guitar from band hero won strum
have u ever droped or spilled water on it beacuse the inside what makes the strum bar work can break really easy. buy a new one
Mar 29, 2010 | Nintendo Guitar Hero Wireless Guitar - Wii...
I have a Wii Guitar Hero 5 Guitar strum bar squeaking badly.
Easy fix for an adult with average mechanical skills -- take the guitar apart (see below) and lube the strum bar with a bit of petroleum jelly. They SHOULD assemble these at the factory with some sort of lube, but it seems that they don't. Ours started squeaking badly after only two weeks.
First, taking apart your guitar will VOID THE WARRANTY, so if you don't want to do that, contact the manufacturer to see what they'll do.
If you are no longer under warranty (or don't mind voiding it) remove the Wii remote: 1) Remove the Wii remote. Press the UNLOCK lever that's under where the Wii remote sits to remove the two parts that make up the guitar "body". They pop out first at the base near the 4-way directional. Just pop them back in (neck area first) to re-install. 2) Remove the "tuning" block by clicking the switch on the back to UNLOCK and pulling away from the neck. 3) Remove the 10 screws from the back of the guitar. NOTE: one is part of the strap hub on the neck. Also, the two at the very top of the neck are slightly smaller screws, so keep them separate from the rest. 4) Flip the guitar over and remove the tree screws from the cavity that holds the Wii remote. NOTE: one is under the "Warranty Void if Removed" sticker. 5) Using a flat plastic tool (like a plastic putty knife) CAREFULLY separate the two halves of the guitar body. I found it easiest to start at the bottom, where the strap connects. NOTE: (A) the bottom strap connector will come out as you separate the top of the body from the bottom. (B) Work your way to the neck slowly and carefully. You'll get there. (C) be sure to note how the spring loaded clip fits at the very top of the neck, it will fall out when you separate the two halves. When you put it back, the slanted part faces the top of the neck. *** WARNING: there's some wires, etc. inside. be sure not to damage anything as you take this apart. 6) Once inside the removal of the strum bar is pretty easy. Just take out the 4 screws from the circuit board. Next, remove the 4 screws that hold the bushings the strum bar fits into. 7) Once you have the strum bar switch out of the bushings, lube them with a bit of petroleum jelly. I just dipped a Q-Tip into the stuff and twirled it around inside the plastic bushing. Be fairly generous... you don't want to take your guitar apart again in a few weeks. Be sure to put all screws back in (two in each plastic bushing, 4 in the circuit board). Also, the screws were different sizes inside, so be sure to keep straight which screws go where. 8) Now just reverse everything you took apart. Your strum bar will be smooth as silk. Start at the very top of the neck (don't forget the little spring loaded latch--slanted part toward the top) and work your way to the bottom (don't forget to replace the strap holder.)
HINTS: Before you go crazy on the disassembly part, take some digital pictures as you go. Then if you get stuck and can't figure out where something goes you'll have something to fall back on.
We've been using our guitar for a couple of months after lubing it and it still is smooth and squeak free.
Feb 16, 2010 | Nintendo Guitar Hero Wireless Guitar - Wii...
Wireless guitar button light up but doesn't strum
I believe that it is an internal problem with the guitar, and the easiest and probably best thing to do is return it.
Jan 19, 2010 | Activision Guitar Hero III: Legends of...
My wii Guitar Hero controller seems to strum of its own accord in the middle of a song... is this a sensitivity issue, and if so any ideas on how to fix it?
You may need to dis-assemble the guitar to ensure that no damage has occoured to the strum bar internally as sometimes when this gets over used it has a habit to randomly strum on its own. Good Luck.
Nov 15, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
Guitar hero wii controller plays notes of its own accord
I had the exact same problem on the wii guitar before, and tried replacing it which did no good. Then I realized on the solo part the touch slider was what kept strumming itself, so I turned off the slider and it worked! To turn off the touch slider, you have to go into a song and go to options and turn it off, which will keep it turned off until you change it. I'm not sure why it does it, I guess dust gets on it or something.
Hopefully this helps and have fun! :D
Jul 09, 2009 | Activision Guitar Hero World Tour Guitar...
On the guitar hero stratocaster there is a lower touch pad of frets. However, I bought the controller used and don't have instructions. How is the lower touch pad used?
Having a 13 year old solve this is not right but anyways the bottom frets can be used for people who have trouble reaching the top ones are they can be used for like rockband solos and on solos you don't need to strum.
Jul 08, 2009 | Activision Guitar Hero World Tour Guitar...
Guitar wont read
You may have seen this already, but I went to and found the instructions listed below. It looks like that if all of your attempts fail, you can request a warranty replacement. I really hope this helps in your guitar woes.
Try the following:
  • Verify that your guitar is connected to the PS3 by looking for the red indicator light above the strum bar.
    • If the indicator light is not lit please refer to the following page for directions on how to sync your guitar to the console.
  • Try disconnecting and reconnecting the wireless dongle, then restarting the system.
  • If the buttons are not functioning in the game or behaving oddly please press the lever on the back of the guitar at the base of the neck and remove the neck from the guitar. Then plug the neck back into the guitar.
  • Check to see if the guitar button in question is functioning in the Playstation 3 XMB (the strum bar should scroll you up and down, the fret buttons act like the buttons on the controller and are labeled on the side of the neck, etc)
  • If the strum bar is registering extra hits try keeping a finger on the strum bar while playing the game instead of flicking it with your fingers/hand.
  • Try replacing the batteries in the guitar.
If after trying all troubleshooting options you find that your Red Octane product is still non-functional, then you can submit a warranty replacement by selecting your country from the drop down below for the warranty submission information for your region. You can also call us at 1-800-205-4713 in the US and Canada, but please note that this is for new warranty replacement requests only.
If your country is not listed in the drop-down below or you need help with an existing RMA then please click on "Ask a Question" in the tab above to submit an incident to us, and we will be able to help you with your issue.
Jun 24, 2009 | Activision Video Game Consoles & Games
Nintendo Guitar Hero Wireless Guitar - Wii for Wii Logo
671 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
