when installing the moto 56k modem for my netone connection my os windows xp warns me that the driver was not digitly signed and appears a window stop instalation or continew any way. when cliks on continew any way the system restarts. whats to do?
you have to uninstall that fo your system to work properly again. there is no fault whatsoever if you use a digitally unsigned product however there are random effects that may occur, in your case, you pc would restart.
1 remedy is for you to find another driver for that. may be look for a newer version driver for your modem. if it still wont work, you might cosider to look for a replacement modem..
Need to open UDP PORT 3658 so I can get EA game to connect on my Wii. How do I do that? Also have...
(More)
Need to open UDP PORT 3658 so I can get EA game to connect on my Wii. How do I do that? Also have several TCPports they recomend opening.
I have been told that internet will run better if I occassionally disconnect & reconnect my...
(More)
I have been told that internet will run better if I occassionally disconnect & reconnect my modem. Is this true? If true, what is suggested frequency - days, months, years, centuries?
I used to connect to the internet without problems. (I'm using motorola fax modem installed in my...
(More)
I used to connect to the internet without problems. (I'm using motorola fax modem installed in my laptop.) But last night, I had a terrible time connecting so I gave up. There's always a message: Error 777 saying that the modem is out of order. What should I do?
