Question about Intel D101GGC Motherboard
BIOS ROM checksum error
Below above message other problem described is
'Detecting floppy drive A media...
INSERT SYSTEM DISK AND PRESS ENTER
The motherboard is Intel Desktop Board
D101GGc
  • Anonymous Mar 16, 2014
    p4 system,xp3 pro,no floopy drive,phonix bios corupted
    Champion:
  • 254 Answers
Have you a hard disk in the pc ?
somehow your hard disk has stopped booting (virus , bad hard disk boot sectors)
you may have to reinstall the OS
hope this helps
Posted on Jan 05, 2009
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Award Bootlock Bios v 1.0 Bios Rom Checksum Error Detecting Drive A media Insert System Disc and Press Enter I have a GA-7VT600 1394 motherboard. How do i fix. Thanks Richard Let me know if you need more...
if you are getting this message it only means that you need to update your bios version, go to manufacturer site and get latest bios update for your motherboard
Nov 23, 2009 | Intel Motherboard
When i boot the computer what comes on the screen is (''award bootblock bios v1.0'' copyright(2) 2000, award software, inc bios rom checksum error detecting floppy drive A media insert system disk and...
it means your boot sequence is first booting your floppy drive or your hard disk is not detected.i think you should check the cmos set-up.you can set it by pressing delete while the pc is booting.disable floppy drive seek.also the boot sequence.the os installed is maybe corrupted, is also one of the problem. refer to the manual if you have.
May 16, 2009 | Computers & Internet
BIOS CHECKSUM ERROR
Normally a bios checksum error is caused by a dead cmos battery. In a laptop that can be a pain - some are specialty batteries, some soldered directly to the motherboard, etc.
Start the laptop and enter the bois, there usually will be something to tell you what key to press, most of the time it is f2 or f10. Once in the bios set the date, time and boot order, then save and exit the bios. If it boots ok then try to determine what type of battery and it's location on the laptop to replace it.
If you let me know the make and model of laptop I will try to help determine that info and also where you can get the battery. That will more than likely be from eBay....
Hope this helps
May 02, 2009 | DFI CB61 Motherboard
The following message appears as soon as I turn PC on; BIOS ROM CHECKSUM ERROR Detecting Floppy Drive A Media... Insert system disk and press enter My OS Microsoft Windows XP SP2 Bios : Award Bios...
There should be a jumper beside your bios batery there should be 3 pins move the jumper to the last 2 pins for 5 seconds and put it back that should do it
Mar 23, 2009 | Computers & Internet
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
Checksum error
Hi Oliver, the most common error related to the message,
(Bios Rom Checksum Error). Someone has left a floppy disk in the floppy drive. Once the floppy disk has been removed press the reset button on the PC, your windows will start normally. Next place to look is in your bios.
Open your manual to page 27.
Enter your bios & go to the title Advanced BIOS Features. Check First, Second & Third boot devices they should be as follows. Floppy disk drive, CD-ROM drive & primary hard disk drive. If both of the above are ok than try clearing the cmos/bios by resetting the cmos jumper (JP1) location on page 5. Descriptions of page five on page 6. CMOS settings on page 9.
When your system restarts re-enter your cmos & reset up your bios settings. Lastly if none of the above has fixed the error message, than remove the cmos battery & check its voltage. It should maintain 3volts. If yours' is lower than 3volts replace the cmos battery. There is one other possible fix. It’s an option not given lightly. Flashing a cmos/bios is not recommended unless all other options have failed.
Bios link for the EliteGroup P4VMM2 V8.1
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=436&DetailName=Bios&DetailDesc=P4VMM2%20%20(V8.1)&CategoryID=1&MenuID=82&LanID=0
Main web site;
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=52&LanID=0
Good luck Oliver!
Mike
Aug 23, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
Please help
Try pressing F2 / Del key during startup. That should bring the bios setup. Now Restore that defaults & install OS on your HDD. If you are not using Floppy drive, disable the onboard floppy controller from BIOS.
Jun 20, 2008 | ASUS P4SP-MX Motherboard
Intel D101GGC Motherboard Logo
392 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
