Question about Panasonic TH-42PX600U 42 in. Plasma HDTV
Purple Haze showing on screen when using HDMi inputs
I am getting a purple haze showinf around background images and faces when viewing through HDMI. Happends on both inputs. One I use for a DVD and the other for SKY HD. Seems to occur when it should be showing bright areas suvh as reflections on skin and also shows when there is a dark area in the backgroundMy tv is the panasonic Plasma TH42Only seems to have started occuring since I used sky HD though. Is there anything I can change on the TV settings or is this a fault that requires repair?Hope yoy can help.ThanksJon
  • paddy555 Feb 28, 2009
    Same problem as yours it happened suddenly this arvo to my aquos lcd has it been solved?
5 Suggested Answers
skotkolr
  • 558 Answers
SOURCE: Panasonic Viera
vga board is bad ot the components on it are blown out.
Posted on May 08, 2008
SOURCE: plasma TV with vertical lines
Help! My Plasma by Magnavox is putting black verticle lines on the right side of the screen - comes and goes - and I replaced the entire Direct TV-HD unit - wires, everything - and had TV company repair - and it still came back. The TV repair refuses to take TV back because it does not show up when they come. Although I videotaped it and showed them which has the date and time - they still refused to take it - and tried to get me to sign a paper saying it was working while they were there - which of course I refused to sign - so they left and nastily said they will not be back-find someone else. I still have the lines - and do not know what to do! Can anyone help?
Posted on Aug 21, 2008
  • 10 Answers
chake to make sure it is hooked up right and not lose
Posted on Feb 02, 2009
  • 92 Answers
SOURCE: Green vertical line down the screen!
Most likely the failure of the Screen.
If you purchased the product new, and have the receipt Panasonic will repair it FOC from what I understand, at least 3 years, your TV is no where near that old yet.
If you bought it, but don't have the receipt.....
Posted on Sep 07, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-46PZ85U Plasma TV
Symptom:
TV shuts off unless all the input (phono and HDMI) cables are disconnected. The
symptom may be intermittent.
Cause:
There is an abnormal AC voltage entering the TV from one of the input cables or AC
outlet.
Remedy:
Follow the Testing procedure to determine if there is a problem external to the product.
Concept
Constant symptom
If the TV no longer shuts off when all input cables are disconnected, then one of the
input cables is introducing abnormal voltages into the TV. Panasonic Plasma TV sets
have 3 wire AC plugs.
As a result, abnormal voltages introduced into this TV will cause the TV to shut off for
protection.
Intermittent symptom
If the abnormal input voltage is borderline (marginal), the TV shut off symptom may be
intermittent. However the cause may still be detectable with a voltmeter.
Protection Proof:
Release the protect mode - the TV has to be unplugged to reset this protection circuit.
Threats from the HDMI input:
Excessive voltage from an HDMI cable connected product will activate the Plasma TV’s
protection circuitry. Placing an isolating / buffering connector (sometimes called a voltage
conditioner) between the TV and the HDMI input cable often solves the problem.
Testing -
Unplug all the HDMI inputs from the TV. Turn on the TV. Plug in the HDMI inputs one at a
time. The cable that causes the TV to enter the protection state is connected to the product
that has the excessive voltage (and signal). Avoid connecting this product until an isolating
connector is found.
Posted on Jan 27, 2010
Remove purple haze around edges
The set needs to be focussed and reconverged. The red and blue images combined make a magenta/purple image. Adding green makes it white. Depending on the type of TV, if it's a CRT projection TV then there's an electronic focus control for each of the three tubes as well as the mechanical adjustment of the optical lenses. Given the description, then I'd have a look at the electronic focus first. A sudden shift in focus suggests that something in that circuit has given out. This would cause the red and blue images to go soft enough to create a halo around objects on screen.
Sep 12, 2014 | Televison & Video
Camera works,all lite up and functions work
Purple haze usually indicates an image sensor failure. However, the fact that it only does it with one of your lenses is strange.
May 01, 2013 | Nikon D70 Digital Camera with 18-70mm Lens
My asus laptop display is showing a blue or purple haze bar through the middle.
sounds like you are right there do it before the warranty runs out!
Dec 09, 2012 | ASUS G73JHA1 Notebook
The camera took great pictures then all of a sudden the screen appears as a purple haze -- and the pictures come out as just a purple blurry haze. Adjusting brightness doesn't work. Yet, the shutt
If the LCD displays correctly on previous photos then the problem is more than likely a CCD or associated ribbon connector failure due to moisture/condensation or age/misuse. Good luck with finding a replacement part!
May 31, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
When plugged into laptop, projects images with a purple haze
This will depend on the brand, model, cable connection type and OS of the laptop. Most have a color control which you can adjust.
Dec 05, 2011 | ViewSonic PJ350 Multimedia Projector
It has a purple and green haze around the edges....
Problem: due to dusty LCDs the light is not pass on equally. so you get a unequal color background in your image. your projector is just need service and service of LCDs and inside parts are a purely technical job.
Dec 29, 2010 | Panasonic PT-LB50SU 2000 Lumen SVGA...
Purple and Green haze on television image
Do you have any speakers near the TV, that aren't shielded... ?That's kinda what it sounds like to me.
Apr 10, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Lumix FX12 LCD screen shows purple haze
raegag
wsd*g
jagskfsda
vwomcjcwkjksdfs;adjkfksjcvijsiarue45646514sd5v13sd4f86vaf21g623g4f861++-+sv+svgsfgsg+fgasvcsdgwg
the answer is 123456789654321456789654123 dota boysssssssssss
Jan 16, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
Screen shows a fuzzy purple haze
unistall it and then restart computer works like a charm. dont reinstall it, cause for some reason it comes back up when restart it
Nov 18, 2007 | Toshiba PDR-5300 Digital Camera
Panasonic TH-42PX600U 42 in. Plasma HDTV Logo
156 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
