Question about Kenwood Kmix Kmx51 Stand Mixer
I have a KMX51. The mixer head cannot swing up anymore.
The lock does not release when the small lever is lifted. How to fix? Does anyone has a mechanical drawing
How do you tilt the back up on the k45 kitchen stand mixer?
To raise the head you move the locking lever back & lift the front of the motor unit up. To lower it you also move the locking lever to the back and then lower the head and release or push the locking lever forward to lock the head down while using it.
Mar 16, 2015 | Food Mixers
Mixing head
Slide the locking lever toward the rear and lift up the head.
May 16, 2014 | KitchenAid Artisan Series Tilt-Head Stand...
Mixer head won't lift up as the silver lever is locked
Put some pressure on the lever and at the same time give it a thump on the top at the front end with the heel of your hand.
Jan 23, 2014 | KitchenAid KSM150PS Artisan Series Stand...
I a viking professional 1000w mixer - i can't get the attachements to attach to the planetary. someone gave me this, so i'm thinking there is a part missing, although i'm unable to locate anything from...
Contact Viking customer support at vikingrange.com and describe your problem. They can get you the correct part quickly. I looked on their web site for an exploded diagram, but didn't see one. They'll help you with this and I'm sure that the costs associated with repairing your mixer will be minimal.
Best regards, --W/D--
Jan 30, 2011 | Viking VSM700 Stand Mixer
My KitchenAid tilt head lock keeps coming loose while beating small amount of dough allowing the head to wobble gradually bad? This is the second mixer with same problem! I've heard some people talking...
In my case the lock was not engaging fully because the internal mechanism was bent too short. I'm not sure if this happened over time or if it is just a manufacturing defect. If your mixer still has some up-and-down play to it when the lock is engaged, then you might have the same problem as me
To fix it, search this site and others for instructions on how to remove the motor cover. I found this video useful: http://www.youtube.com/watch?v=VeCiivPt7hk
With the cover removed you have access to the locking mechanism. In my case, the latch is connected to the locking lever via a bent S-hook. The hook was just slightly too short which kept the latch from engaging completely. If you remove the two screws holding the hook in place and that allows the lock to close completely, then you have the same problem as me. (You'll feel the difference immediately. When fully locked, there is practically no wobble in the mixer head.)
I lengthened the hook by placing it against a flat surface and hammering the bend out a bit.
Jan 05, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
The flat coated beater has worn off the coating why and how to fix it
Hi ARADAM, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number and select a file listed under Owners Manuals and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 22, 2009 | Food Mixers
Beater rubs bottom of mixing bowl.
JOE:You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals:KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC.You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height.I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
If this solution has helped you, please rate it, thanks!.hslincoln
Nov 21, 2009 | KitchenAid Food Mixers
Replacement of lock and unlock lever
Look for my posts on "Removing the motor cover". The lock is under the motor head. Its easy to find and fix.
Jan 02, 2009 | KitchenAid KSM150PS Artisan Series Stand...
I can't find out how to tilt the motor head on the K45SS model Kitchenaid mixer. The user guide indicates there is a lever to tilt it but there is not one to be found. Help!
On my kitchenaid stand mixer, the lock lever to lift the head is located on the opposite side of the speed control. If there is no lever there, check to see if there is a spot that looks like there should be a lever there, if there is, but the lever is missing, you might have ended up with a mixer with a manufacturing error. In that case, your only option is to take it back to the store where you bought it.
Dec 23, 2008 | KitchenAid K45SS Classic Stand Mixer
Kenwood Kmix Kmx51 Stand Mixer Logo
353 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
Treefrog15
Treefrog15
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
