HP deskjet F4100 won't print kept saying install cartridge
But cartridge is installed properly. i've cleaned it and reinstalled it but the Ink levels kept on blinking red.
    Novelist:
  • 126 Answers
When you look at the cart. you will see little contact points, the same are in the cart. holder cavity. Sometimes these contact points get ink on them and can not read the cart. Start the process of installing the ink cart. When the holder is positioned to install the cart. -- disconnect the power. This will keep the holder in this position so you may try to clean the contact points. Use a Q-tip and a high alcohol base cleaner. DO NOT SOAK - but dip the Q-tip into the cleaner and then gently rub the tip across the contact points in one direction -- say from left to right -- not back and forth. You should turn the tip after each pass and you may need a couple Q-tip to clean the contact area. After you are done, no more ink on the Q-tip, let the cleaner dry ( about 1 min depending on the alcohol base) then take a dry Q-tip and wipe off haze if any. MAke sure everthing is clean of the area and power on, do ink install process and try to print.
Posted on Jan 05, 2009
How do I check ink levels on my HP deskjet D4160 Printer
When your printer was installed, it came with a CD with a complete software package for your printer to report (ink levels/diagnostics/etc) to the computer. If it was installed in Windows 7 (and below) it would be found at "Start" (button) > "HP" > Deskjet D4160 > Deskjet D4160. In Windows 8 look for HP. Once you've opened the application it will query the printer for its status. One of the icons will show the "Estimated Ink Levels".
If you can't find the software installed or the CD you can find it at HP's (US-English) support page for your D4160 is at the link below. Persons from other countries you can find their language at HP.com/support. There you can find everything you need.
Ink Jet Notes:
·Printers can be set to "economy" (default or individual job) to save ink if high quality is not an issue.
·Follow the user's manual or print using all cartridges at least monthly to insure the cartridge jets do not get fouled with dried up ink. Once fouled its toast. I've never been able to clean one.
·New printers come with minimal ink in the cartridges.
·"XL" (high volume) versions of your printers ink cartridge is cost effective if you print frequently.
In His Grace
Elton
HP Support
Mar 03, 2015 | HP Deskjet D4160 InkJet Photo Printer
F4100 cannot print, replace ink. Not printing test page.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
Jun 14, 2011 | HP Deskjet F4100 All-In-One InkJet Printer
Printer will not print,machine says ink cartridges not in place,not so new cartridges in stalled
Good day,
The printer cartridges might not have been installed/inserted properly.
Here is a step by step instruction http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01367400&lc=en&dlc=en&cc=us&product=3390949
Keep me posted!
Jas
Feb 18, 2011 | HP DeskJet F4280 All In One Printer InkJet
Why won't my photos print centrally or borderless with my HP Deskjet F4100 printer?
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command.
Nov 12, 2010 | Office Equipment & Supplies
Light flashes cartridge change, and change the cartridge and still flashing hp deskjet 920c
Make sure Orange protective cap (tape) has been removed from the bottom of the ink cartridge.
Either ink Cartridge is not installed properly or the function for detecting the ink level is disabled. Make sure that you install ink cartridges at correct position as indicated by the label on the print head holder. Press PUSH mark until ink cartridge click into the place.
Hope this will solve your problem.
Thanks for using Fixya.
Oct 21, 2010 | HP DeskJet 920c InkJet Printer
Installed HP Deskjet D4160 on my Windows XP system. Worked well a year ago. Lost drivers when computer was cleaned. Reinstalled the drivers and it will print colors and graphics but will not print black...
Doe's it have a color and a black ink cartridge? Got unplug the cartridges and plug them back in. Go to the folder where the printer is installed in program files. Find printer toolbox program and run it. It should tell you ink levels.
May 24, 2010 | HP Deskjet D4160 InkJet Photo Printer
HP Deskjet 722c appears to print but the page is blank. New toner cartridges have been installed
If the clean test page shows streaked or broken colors, the printer or cartridges are not functioning properly. Note that HP cannot guarantee the quality of refilled or remanufactured cartridges. Follow the steps below to solve the problem:
  1. Remove and reseat the cartridges. Try printing again.
  2. Check ink levels, and if a cartridge is low on ink or out of ink, replace it and try printing again.
  3. Clean the cartridges. Depending on what printer you have, you can either print another clean test page or run a cleaning utility. Check your User's Guide for instructions. Try printing again.
  4. Clean the contacts, then try printing again. Click here to see how .
  5. Align or calibrate your cartridges (depending on what printer you have). Check your User's Guide for instructions.
  6. If none of the steps above have helped, clean the nozzle plate manually. Click here to see how .
  7. If the problem still has not been solved, replace the cartridges or service the printer. Click here to see how to decide which to do .
Feb 13, 2010 | HP DeskJet 722c InkJet Printer
How do I check ink levels on my HP deskjet D4160 printer?
Here is what I found on the Web. You can click on the link below, to see Full Instructions. If you find this helpful, pls rate me.
http://h10032.www1.hp.com/ctg/Manual/c00687555.pdf
View estimated ink levels
Follow these instructions to view the estimated ink levels of the print cartridges that are installed in the printer:
1. Open the printer Toolbox.
2. Click the Estimated Ink Level tab.
Note If the print cartridges were used before being installed in the printer, the
estimated ink levels will not appear on the Estimated Ink Level tab.
The Estimated Ink Level tab also contains print cartridge ordering information. To view
this information, click the Print Cartridge Information button.
Thanks and good luck.......
Pls rate me
Jan 01, 2010 | HP Deskjet D4160 InkJet Photo Printer
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
291 people viewed this question
jasbo
jasbo
