Question about Daewoo L700C 17" Flat Panel LCD Monitor
Power Failure A couple of days ago, my monitor refused to turn turn on and the green power indicator light flitted off/on. After rebooting the computer, it did turn on. However, since that time, lines of "interference" seemed to occur during the boot process (only on the Windows XP boot screen) but not during normal operation. Today, it refuses to turn on at all. I've connected another monitor to the cpu which seems to be working fine. If I simply replace the power cord, is that the most likely source? I don't see any bent pins or connections, and I'm not sure how to check the fuse.
  • debryon Dec 19, 2007
    Daewoo L710 flat panel One year of use
    blank screen
    green power light blinks off and on
    computer works great with another monitor
    changed power cords with no difference
    Thank you for any input
    Genius:
  • 2,985 Answers
If you mean the Monitor is powered by an external power supply Then that indeed is an option worth trying Simply get a multiple voltage one and set it to the voltage of the existing one. There may be internal problems such as the inverter But this will be a repair shop job.
Posted on May 25, 2007
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
My westinghouse LCD LCM22w3 is not turning on. The switch light will turn on for a few seconds but then turns off. I have no imput signal
Helo,
This is a very common problem with the LCM-22W3 monitors. The problem is caused by a failure of the filter capacitors in the power supply board. Here is a link to a repair guide that shows how to open the unit and what to look for and replace to repair the monitor. This is a very easy repair.
http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-22w3/
Jan 26, 2013 | Westinghouse Computers & Internet
Monitor light is green but display is black
your power supply board, probably has some bad caps in it
Jun 12, 2010 | AOC LM729 17" LCD Monitor
Green light blinks then monitor shuts off
Yes,
The problem you are having is caused by a failure in the power supply board. We repair these units in our shop all of the time. We have an article posted on our web page at: http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/ that gives full repair details and parts lists. If you don't want to do the repair yourself we do offer a repair service, more details on that can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this information helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Mar 12, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
ViewSonic LCD Monitor Went Blank
It is probably a bad INVERTER and / or backlight fluorescent bulb.
Jul 02, 2009 | ViewSonic Computers & Internet
The screen is black even though the green light is on
try with another cable, pc if nothing. need to get service.
May 30, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Cintiq 12WX screen not working :(
may be the power chord is damged go to a nearby shop and tell tham to give you a new power chord of monitor and then try it should work fine
thank for visiting fixya
have a nice day
Feb 19, 2009 | Wacom Cintiq 12WX Interactive Pen Display...
Won't turn on
This is a problem with either the power supply or or logic circuit. It could also be caused by a failure in the back light circuits. One of these problems has caused the power supply to go into protection mode and will not turn on due to bad voltages sensed in the feedback circuits. Return to dealer for service. Hope this helps you .
Dec 26, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Daewoo L700C 17" Flat Panel LCD Monitor Logo
141 people viewed this question
Top Daewoo Computers & Internet Experts
Michael Galve
Michael Galve
Saleem Baig
Saleem Baig
JonSnell Electronic
JonSnell Electronic
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
