Question about Lands Phones
Telephone SE655 worked briefly on first day but with loud hiss which developed up to a high-pitched whine. Also when speaking, there was a lot of background noise picked up by the microphone from the room, as if the mike was over sensitive. Now the base station and the second phone do not work atall. Battery checks are full. Ian williamson
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a couple of ideas you may want to explore/try:
  • remove the handset batteries, remove power to the base, remove telephone wire for at least 30 minutes;
  • if your version/unit came with a recessed reset button, press and hold for 5 seconds. All user configurations, settings and memories can and would be erased;
  • with the base still off, re-install the handset batteries, charge the handset for 24 hours;
  • reconnect telephone wire and power to the base;
  • go through the initial set-up/registering and configuration;
  • test by making a call;
  • have somebody call you;
  • ensure that the base is located far away from sources of electrical noise and RFI (radio frequency interference).
Some possible sources of electrical noise and and RFI are electronic lamp dimmers/controllers, lamps with electronic ballasts, Wireless routers, computers and most other electronic devices.
Should problem persist, return unit to point of purchase and demand replacement.
Good luck and Thank you for using FixYa.
Posted on Jan 05, 2009
    Sergeant:
  • 378 Answers
It can be due to ant loose connectivity in the device.or it could also happen if you have changed any setting.and about the hiss and loud sound for that u can lower the volume little bit and check out this should solve the problem.also check that the phone is properly connected to the base station while charging.but if the device is in warranty it is advisable to replace the device.
    Sergeant:
    Novelist:
  • 326 Answers
Justr unplug the device.then shut off the device copmpletely for a minute then recheck it should work.
    Genius:
  • 1,011 Answers
Sir,
Move closer to the base station.
Move the base station at least one metre (yard) away
from any electronic appliances.
Also check the antenna it may be defective.
Thanks
good luck
Is a high pitched whistling sound at idle a vacuum leak or what?
hissing vacuum leak at idle, louder with open throttle ...
? 1:43
https://www.youtube.com/watch?v=tFoybr865n4
Jun 27, 2010 - Uploaded by fenixus
hissing vacuum leak at idle, louder with open throttle ... i know that my camera is poor and microphone suppresses high pitch ...Hi, my kia picanto engine also sound hissing/humming duringidling with open throttle. ... Loud whistling noise 2000 jeep wrangler 4.0l - Duration: 4:01. by Nasrac72 16,158 views.Missing: vt750c
A Whistle or metal sound with firing... - Honda Shadow Forums ...
www.hondashadow.net > ... > Technical Discussion
Jul 11, 2008 - ... under load (accelerating), that there is a small whistle or even 'tap on metal' high pitch sound ... Pics of my 2008 Shadow Aero 750 (VT750C ... loose bolt vibrating
Feb 29, 2012
High pitch whine
Jul 21, 2009
More results from www.hondashadow.net
Dec 25, 2015 | Goes Motorcycles
42PFL9900D/10 Philips LCD Television Hissing Speakers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Televison & Video
LCD Television Philips 42PFL9900D/10 Hissing Speakers
I have a magnavox 37mf331d/37 that has developed a high pitched whine.the longer the tv is on the louder the whine.the tv is 5-6 yrs old
It's likely a capacitor associated with the power supply having gone bad.
It's obviously beyond your expertise to repair it yourself.
Find a trustworthy repair shop and take it there.
Sep 05, 2012 | Televison & Video
Loud hissing through rear (souround sound) speakers
I have the Sony Bravia KDL-46S4100. The high-picthed hiss drives me insane. I have a work around but not a fix. Go into your TV's menu and find BACKLIGHT. Adjust it from 1-9 with the house quiet and find what frequency of the hiss is the least annoying.
Sony Bravia high pitch hiss hissing sound high frequency
Nov 22, 2008 | Audio Players & Recorders
High pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection board..it basicaly a large coil of copper wire....you can take silcon and put on the coil...in effect damping the ocillations...hope that might help
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
