Question about Panasonic Microwave Ovens
My Panasonic microwave oven model NN-S215MF/WF is working except the glass tray will not rotate in any direction.Can anyone help?
NN-S235MF/WF
jerryg50
  • 1667 Answers
SOURCE: Microwave oven NN-S573
The usual cause is the tray motor assembly, or the power supply that feeds it. These parts are available from the parts rep for Panasonic. Contact Panasonic for details.
There are serious safety issues when servicing microwave ovens. I suggest to have the oven professionaly serviced by an experienced service tech for these products.
Jerry G.
Posted on Jul 26, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Panasonic Microwave Model NN-S454 glass tray does not rotate
I would suspect that you have trouble with one of the door switches or its mount.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
See: http://www.microwavedisplay.com/safety.txt and
http://www.microwavedisplay.com/disassembly.txt
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
You can order other parts for this brand at Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Mar 06, 2009
freetek
  • 5568 Answers
SOURCE: Hi, I have a Panasonic
If you have 15 minutes and a screwdriver (don't know which type is used on your unit), I would unplug from the AC, remove the housing so you can see the floor of the frame and the control devices, look for a fuse to replace, keeping your hands and fingers clear of any bare terminals. This unit may have two fuses; one for the high voltage circuit for the magnetron, another for the other parts such as the control circuitry. The first fuse will be 15-20 amperes, the second much lower. If the fuses are visible and close to each other, make sure you know which fuse belongs where; they will have much different ratings for current.
Since the light and turntable are working, the lower value fuse is obviously OK, so if you find two fuses, remove and replace the higher value fuse.
If you do this, turn it on and the fuse blows again, then it is time to replace the unit with a new one since the other parts that can fail require a little technical background and a multimeter. The cost of having it done by a pro will likely amount to more than the unit is still worth.
Posted on Aug 01, 2010
heatman101
  • 43501 Answers
SOURCE: glass tray of my microwave
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 06, 2011
flsty
SOURCE: I need a new door inner glass for Panasonic NN-A772SBBPQ microwave/combination oven
Think about calling up the Sears 800-4MY-HOME line... the parts dept can look up your model with the LIS and have the part sent to your address and a Tech to install it for you if you don't know how, plus if you do pay for a tech repair for like $40 they do a clean and prevenative maitnence check on any other appliance you may have thats acting weird.
Posted on Mar 07, 2012
Panasonic Oven model No NN-C784MF/WF
I would keep the items in. Usually, oil is sprayed on which can cover anything that is in oven at that production step. Won't hurt anything one way or the other.
Mar 12, 2014 | Microwave Ovens
DOOR WILL NOT CLOSE ON NN S752 WF PANASONIC MICROWAVE OVEN
it looks like theres a faulty door lock mechanism have it checked out and replaced!
Sep 25, 2011 | Panasonic NN-P295SF Microwave Oven
I have a microwave oven purchased from dubai ( model:nn s 235 wf). The problem is that its not heating when we put any thing into it.
You may find the magnetron is not being supplied with the high voltages required to make it work or it has failed.
Call a repair centre.
Feb 25, 2011 | Panasonic Microwave Ovens
Overheating Panasonic NN-E225M
i have seen tisquite a lot, simply try and keep open space behind and ontop and u will be ok.
Jul 05, 2009 | Panasonic NN-T993SF Microwave Oven
Wiring Diagram for Microwave Door Switches
It took me a while, but I was finally able to get the FULL service manual that covers these models:
NN-S252BF
NN-S252WF
NN-S262BF
NN-S262SF
NN-S262WF
The wiring of the door interlock switches is shown on page 10.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Jan 15, 2009 | Panasonic Microwave Ovens
Need nn-c988w Microwave manuel
http://service.us.panasonic.com/OPERMANPDF/NNC988B.PDF
hello , here is the manual for that model nn-988w / nn988b , thanks for voting FIX YA !
Jan 03, 2009 | LG LRM1230W Microwave Oven
Glass turntable
PANASONIC WILL SELL YOU THE PART ALL YOU NEED IS YOUR MODEL NUMBER
Dec 07, 2008 | Panasonic NN-H965 Microwave Oven
Panasonic NN 9859 Membrane switch
Yes, you are correct. The membrane switch for this model was discontinued. The correct part number for the membrane switch is A630Y5460HAP for model NN 9859.
Mar 26, 2008 | Panasonic NN-T888S Convection/Microwave...
Microwave Ovens Logo
91 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
