I have kenwood ks-200-ht subwoofer
Is the out put on it have a crossover
2 Suggested Answers
  • 9 Answers
SOURCE: hi, I have the Kenwood Subwoofer KS-201-HT, my
usually subs have outputs 4 ur monitors however if ur sub is active @ ur monitors are passive then you need 2 connect sub 2 ur tape loop with rca connections,usually you use the send signal from ur reciever which would norm connect to ur tape input , if the sub is passive then u connect direct to speaker output on amp then monitors to the sat connections on sub
Posted on Oct 13, 2010
I have an Kenwood 12" sub woofer everything looks good but it will not do anything
The assumption is that it is a passive speaker with no crossover circuit. If you connect a good 9 volt battery to the speaker and neither hear or see a sound or movement the next step is to confirm with a multi-meter an open voice coil circuit.
It is possible to repair a broken wire but not likely a burnt- open voice coil.
Hope this helps?
Apr 03, 2016 | Kenwood KFC-W3003 Car Subwoofer
I have Kenwood SW 900 . need to know its out put. Kept for long period
Do you mean the Kenwood SW-200 subwoofer or the SW-200 power meter? The subwoofer can use 50W RMS at 4 Ohms. It's rated at 60W. The power meter reads in two ranges: 20W and 200W.
Kenwood has the manual for the subwoofer on their support site. The direct link to the manual is http://kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/sw200.pdf .
I hope this helps. If you are looking at a different Kenwood product, please clarify which product you have. I can't find a SW 200 receiver from Kenwood.
Mar 08, 2016 | Kenwood Car Audio & Video
Cannot get the subwoofer to play...all other speakers work fine...my Kenwood receiver is VR-309...the subwoofer model is Kenwood SW32-HT... I have also used the setup mode to make sure the Subwoofer is...
After making sure that your subwoofer is receiving power, as most models have their own amplifier, make sure that it actually is turning on. There is a possibility of a faulty power switch. Lets rule that out first.
Once the switch is on and the proper power connection is verified, turn your attention to the setup menu on your receiver. Navigate to the LFE/Sub output level. Adjust it up all the way. Then navigate to the crossover setting. Turn it up all the way. If the subwoofer also has it's own control panel including a crossover, turn that up all the way as well. Then with an input on the receiver that has a subwoofer output set up such as for DVD, play some audio. Or likewise you can also use the receivers' test tone capability that will pan each channel individually with a wide band pink noise signal that also includes a signal sent to the subwoofer output.
If this procedure does not produce results then send me a message including your subwoofer model and your observations of your systems' operation.
Jun 10, 2011 | Kenwood VR-309
Hi, I have the Kenwood Subwoofer KS-201-HT, my question is how do I connect it to my receiver?
Oct 12, 2010 | Kenwood SW36HT Subwoofer
How do i connect it to a the subwoffer sw 50 ht
on the back of your receiver is a subwoofer pre-out, connect one cable here, and connect the other end of this cable to your subwoofer - line level in. (depends on your subwoofer and receiver) but that's how mine is connected. yours will be similar.
Feb 10, 2010 | Kenwood VR-505 Receiver
Powered subwoofer will not work anymore
Make sure you are pluged into the sub pre out and not the six channel line in,its a easy mistake to make.
hope this helps.
CABLE GUY.
Jan 06, 2009 | Kenwood Audio Players & Recorders
I just bought a KDC MP-235 to put in a 95 camaro with bose amplified speakers. I ordered a amplifier intergration component to reduce the output of the 50 watt per channel head unit as to have better...
Yes, the Kenwood KDC MP-235 has two (2) line level outputs (RCA types red & white). However, these outputs internally passed through an electronic crossover/filter making them appropriate for subwoofer amps only.
If your unit is an MP-235CR, then the same outputs would be for the rear amp (not subs) and are full range (unfiltered).
If indeed your unit is an MP-235 and if I may make a suggestion, still connect the Kenwood to four (4) speakers. It would not be technically correct to leave the internal amps operating with no load (speakers) connected. Additionally, you would be getting 200 watts (4 X 50) more to your system (since it is already there).
If your Bose amp & speaker are subs, then no issue, however if the Bose is for a full range of speakers, then only the woofer part would be working efficiently.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 15, 2008 | Kenwood Car Audio & Video
161 people viewed this question
 Grubhead
Grubhead
