Question about Lexmark P4350 All-In-One InkJet Printer
Lexmark 8300 enable bidirectional communication
rjwharris
  • 102 Answers
SOURCE: what it means Enable Bidirectional Communication
To enable bi directional printing:
Open Printers and Faxes in control Panel
Right Click on the Printers Icon
Select PROPERTIES
In the Properties dialog box select the PORTS tab
Near the bottom there is a check box to enable Bi-directional printing
Make sure it is checked
Click OK to exit the dialog box
Posted on Feb 21, 2009
  • 53 Answers
SOURCE: Lexmark X2500 is giving Bidirectional communication error message
Make sure that the "Enable Bidirectional Support" checkbox is checked: Go to "Control Panel"->Printers->Right click on the print Object->Properties under "Ports" tab, enable this check box if not already enabled. If you using vista make sure you do this from an "Admin" account, you may also need to select the "Run as Administrator" option after you right click on the "PrintObject".
Posted on May 14, 2009
SOURCE: when trying to print says enable bidirectional communication
I came up with a work around solution and for $9.99 I'll tell youo how I did it......
Posted on Jun 22, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: My Lexmark x5495 will not print. I get the message
    Go to Control Panel > Printers and Faxes > right click on the Lexmark 5400 Series print object > Properties > Lexmark 5400 Series Properties window pops up, click on Ports tab > place a check mark in Enable bidirectional support by clicking in the box beside it. Hit Apply and click Ok to save the settings. Try to print. If problem persists, disconnect the printer usb cable from computer, uninstall the software completely by clicking on Windows logo Start menu > All Programs > Lexmark 5400 Series folder > Tools > Uninstall. Restart pc. To reinstalI, I recommend you use the software you can download from the Lexmark website. Just click on this link: http://bit.ly/cgn74X. Download and install the software. Follow the instructions. Try to print again. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
    Posted on May 04, 2010
    printmastert
    • 3344 Answers
      Verified Fixya Pro
      SOURCE: how do I enable the
      Follow these steps:
      • Go to Printers and Faxes(XP)/ Printers(Vista and Windows 7) in Control Panel. Right click on the Lexmark 5600 Series print object and click on Properties(note: image below is just an example).
      • In the Properties window, go to Ports tab.
      • Enable the bidirectional support as shown in the image below(must have a check mark). Hit Apply then OK to save the settings.
      If bidirectional support option is grayed out or cannot be enabled, problem may need further troubleshooting. Contact Lexmark technical support for further assistance. Thank you for choosing Lexmark.
      Posted on Sep 15, 2010
      Hellow i cant find enable bidirectional communication in controp panel after printers
      Go to Start, Settings, Control Panel >
      Double-click on the Printers folder > Right-click on the printer icon and select Properties > In the Properties screen, click the Port tab. You'll see the "enable bidirectional support" option at the bottom of the window.
      May 06, 2011 | Lexmark P4350 All-In-One InkJet Printer
      Keeps telling me to enable bidirectional communication
      Hi:
      When you first loaded the print driver there should have been a box to check to enable bidirectional communication. Most Lexmark printers require this to work properly
      Andrew.
      Feb 27, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
      How do I enable the bidirectional communications for a Lexmark printer series x5650es
      Follow these steps:
      Sep 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
      CANT ENABLE BIDIRECTIONAL COMMUNICATION X4550
      I have tried to set up this wireless printer on my laptop (windows vista basic). I run through installation and get message - installation complete and the green indicator light is fully on. When I try and print I get message Printer cannot communicate with computer - please turn on 'Enable Biodirectional Communication' in printer properties. I go to control panel/printer/propertie/ports/ and I see Enable Biodirectional communication - the box is grayed out and I cannot enable it. Any suggestions?
      Jan 22, 2010 | Lexmark X4550 InkJet Printer
      Lexmark 3500-4500, enable bidirection printer
      Bi-directional operation is a facility of the BIOS port you might use. it usually refers to a parallel port which can be set in the bios as uni directional or bidirectional so in the bios under PERIPHERAL DEVICES you would set to bi-directional.. so it is not something you can set in the printer settings. when it connects to the port the printer tests to see if it can use bidirectional transfers or not. If it can't it just means its a bit less efficient so will take long to transfer data. A similar error message might be issued for a network/wifi connection if a FIREWALL prevented communications. Or if you had used an OLD driver meant for a different older parallel printer. your printer is too new and should be wifi connected. You may have used a wifi ad-hoc pc-printer direct connection which could be causing the issue. preferred method is always printer-router-pc non ad-hoc using tcp/ip ports. so check your firewall settings http://support.lexmark.com/index?page=content&id=SO3908&locale=en&userlocale=EN_US
      Oct 03, 2017 | Office Equipment & Supplies
      When trying to print says enable bidirectional communication
      Jun 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
      My x5470 says enable bidirectional communication when I print
      In this case click on start and then go to Control Panel on control panel click on printers and then right click on the lexmark default printer which has a check mark on it and click on properties.......... On the properties window click on "Port" Tab and then check the option which says enable bidirectional support..................
      Good Luck............
      May 27, 2009 | Lexmark X5470 All-In-One InkJet Printer
      May 10, 2009 | Lexmark All-in-One Printer with PictBridge
      What it means Enable Bidirectional Communication
      Select PROPERTIES
      Feb 17, 2009 | Lexmark X2470 All-In-One InkJet Printer
      I purchased a Gateway laptop p-series computor I tried to instal my 8300 printer I get the this message communication not available the printer cannot communicate with the computer please turn on...
      If you have an XP OS, click START Menu then click "Printers and Faxes". A window will open with a list of printers installed in your computer. Right Click the printer icon for your 8300 printer then select properties. Go to "Ports" Tab, you will see the check box for "Enable bidirectional support".
      Sep 25, 2008 | Lexmark Office Equipment & Supplies
      Lexmark P4350 All-In-One InkJet Printer Logo
      180 people viewed this question
      Top Lexmark Office Equipment & Supplies Experts
      Don  Farrell
      Don Farrell
      Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
