Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia KDL-40W4500 turns off
Have a new Sony Bravia KDL-40W4500 which is turning off onto standby mode, and is flashing 8 times.
Help please!
  • Anonymous Mar 16, 2014
    four lines appeared near top third of screen, looked like interference but I'm now sure it is electronic/lcd fault. Perhaps dry joint on a driver pcb?
  • Anonymous Mar 31, 2014
    So my Sony Bravia wont Turn on at all, I did everthing I could, but still no answer
  • 4,234 Answers
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
Whenever I turn my sony KDL40V3000 on it
Power supply problems. check SMPs and other feed back voltage signals.
Apr 05, 2010 | Sony BRAVIA KDL-40V3000 Television
My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
Oct 09, 2009 | Sony Bravia KDL-26S3000 Television
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
13 red standby flashing lights -- turns on, then turns off
Are you sure about the 13 flashes. Error code only goes to 8 flashes.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia KDL-46Z4100 Standby light flashing 13 times
This sounds like a power source problem! (faulty transformer) I would pack it up and take it back for a new one!
This is a problem you can not fix yourself unless your a pro!
Please rate my response!
Jan 15, 2009 | Sony BRAVIA KDL-40V3000 Television
Have a new Sony Bravia KDL-40W500 keeps turning off into standby mode with 8 flashes.
There is some confusion on the model (KDL-40W500 vs. KDL-40V2500), so I will direct this toward the 40V2500.
On the KDL-40V2500, an 8X blink means the scan processer has gone bad, and the BU board needs to be replaced. If the problem is intermittent, the the AU board might be the problem, but if it all the time, bank on the BU.
A competent repair shop should be able to help you, or you can try calling Sony directly for assitance.
Hope this helps you...
Jan 05, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Oct 11, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
1,749 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
