Hi I have a Honeywell VC4613-30 valve actuator to be fitted it has the letters A and B on the inlet and outlet ports, which one goes to the boiler side . Tom
  • 70 Answers
Is there a small directional arrow on top of the valve and on the pump valoot
Posted on Jan 05, 2009
Hose connections from pump to filter etc
what are you asking?
do you want to know how to plumb the individual pieces of equipment?
If so, skimmer port at the pool will go into the suction port of the pump, the port directly into the hair & lint pot.
discharge off the top of the pump will go into the Inlet of the filter valve, then the outlet of the filter will go to either a heater inlet port then outlet of the heater to the pool return inlet ports. If no heater, then from filter outlet directly to the pool return inlet fitting.
Good luck
Jul 10, 2014 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
1 of the valves are leakink on the boiler im lead to belive its the pressure 1 not the temp 1 as the water is cold we told the plumber he replaced 1 of the valves unsure which 1
hi i need to know what boiler, all pressure valve work on temp, and what is the boiler do i.e........ does the pressure rise when the heating is on, does the pressure goes up in the red around 3bar???
Feb 16, 2011 | Plumbing
Replace honeywell V8034F1051 zone valve
why not just but the head or come to that the motor in side , cheaper option
Jul 12, 2010 | Honeywell Heating & Cooling
Laars Endurance ebp have hot water but not heat
check the valve actuator honeywell zone valv
May 15, 2010 | Heating & Cooling
Hi! My hot water taps from the wash hand basin and mixer bath has low pressure. I`ve got a combi boiler in the first floor. Can I install a single impeller pump connected from the hot water outlet from the...
In a word no. Combi boilers work on balanced pressure.ie the mains cold supply to the boiler should be around 1 bar minimum which would give a hot water pressure of the same 1 bar. Assuming the cold water pressure is fine, it sounds like you have a restricted flow on the hot side. If you live in an area with water problems the hot water systems pipework calcify over time effectively reducing water flow. Unless any flexi hoses are kinked, check if there are any filters in the appliances that may be blocked.Also check all valves are fully open and if possible check if there are any restrictions at the valves. Failing all that and the taps are in good order it is possible to fit a pump before the boiler but this may only be a temporary fix overall.
Apr 04, 2010 | Plumbing
I have a Glowworm 30 cxi and the light is flashing, the pressure is 0.4.... i have no water or heating...help please
Under the boiler a little right of center there is a blue/other colour knob. Turn this anticlockwise [as you look up] [twist from right to left] This is the mains inlet tap to let water into the boiler and create the pressure shown on the guage 0.5 bar is the absolute nin.
allow the water to flow in until the guage reads about 1 bar then turn off the knob -not too tight as these are plastic
If you allow too much pressure- do not worry, there is an automatic relief valve.
If the boiler persists in loosing pressure, look for a leak in all pipes to & from radiators. If no leak then check the pressure relief valve outlet pipe, it usually goes through the wall to the outside. Look at the end for water drips & if there are drips replace valve
Oct 12, 2009 | Water Heaters
Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
No hot water honeywell st6400c
HW valve was stuck in the open posiion and the micro-switch was not working so thats why boiler and pump were not starting. Bled system to below the level of the valve to be changed, and replaced valve with a drayton ( easy quick change of valve head if needed no screws )
Sep 07, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
239 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
