Question about Apple iMac G5 Desktop
IMac won't recognize the files on a PC
IMac won't recognize PC files
  • 86 Answers
In order for a Mac to open files generated on a PC, you must have a program capable of reading these files. The new version of Microsoft Office defaults to saving files in a new format which is not compatible with earlier versions. This can be rectified by 'Back Saving' files to an earlier version of Office in the 'Save' menu.
If you have files that you know can be opened with an application that is installed on the Mac, ctrl/click (right click) on the file and chose 'Open With' from the drop down menu. This will allow you to choose the application.
Posted on Jan 05, 2009
HOW DO YOU IMPORT VIDEO FROM A SONY HDR-HC3 ON AN IMAC IF THE CAMERA IS NOT RECOGNIZED??
you need a third party application /codecs that recognises the sony protocol e.g. mts ext that can transcode those files either into mov,mpeg2 etc environment so that the imac recognise them
May 18, 2014 | Sony Handycam HDR-HC3 HDV Digital...
My SanDisk is a portable USB/ compatible to IMAC?
although your mp3 player may not officially be imac compatible, it should still plug in and be recognized by your imac just fine, you just wont be able to use any software that may or may not come with the mp3 player, however given that its not a zune (microsoft product) and that its not an ipod, it should work perfectly fine, and you should be able to simply drag and drop your music onto the mp3 player when it is recognized by your imac. just be sure to copy the files over to it while its plugged in by using the file browser of your mac.
Feb 20, 2014 | SanDisk Sansa m240 MP3 Player
Imac won't recognize camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Dec 14, 2012 | Canon PowerShot A570 IS Digital Camera
I cannot copy files FROM my Western Digital 500GB
Check the file system of your hard drive. If your PC is recognizing it, check if its a FAT or NTFS. If it is NTFS then you have to reformat it using your Mac and choose FAT. Mac OS recognizes NTFS as a read only drive. If you plan using it with your PC and MAC you should format it using your mac and choose MS-DOS in disc Utility. You cannot format the drive using your PC Computer with a FAT file system because of the capacity. Only Mac can format it with a FAT file system.
Aug 23, 2009 | Western Digital My Book Essential 500GB...
Got a new imac moved ms office file to my book -
Try to change the File system of the hard drive to FAT. It is currently in NTFS. Mac recognizes NTFS file system as read only. You must use the disc utility and format it with a volume format of MS DOS.
By changing it to MS DOS (FAT) you can use it with Mac and PC. Readable and writable.
Aug 04, 2009 | Western Digital My Book Essential Edition...
I have a Sony ICD-SX35 recorder which my iMac will not recognize. Any clues out there???? I need to convert the dvf files into MP3 or WMA format but that can't happen before my Mac recognizes the...
I took the advice of one of your correspondents by connecting my Sony ICD-SX365 recorder to my iMac with a simple audio cable by inserting the output jack in the recorder's slot for headphones and the input jack in the iMac's slot for microphones. I used the freeware program Audacity to import the track onto the computer and Switch to convert the file to mp3.
Apr 15, 2009 | Sony ICD-P28 Digital Voice Recorder
Want to copy files from Tascam 788 to IMAC's Garage Band
The problem is thus. You have a multitrack recording saved in a format that your portastudio recognizes and you want to use it on your imac. If you can copy the file to the imac as a file, a translator, if one is available, will make it usable by the mac. You won't be able to play it and record on the imac because maintaining the recording as multitrack would require one output from the portastudio and one input on the imac for each recorded track.
Bummer dude. The kluge method would be to play/record 2 tracks at a time (or however many outputs and inputs are available) and hope for some semblance of time alignment, after which you can fine tune it and then start your editing.
Apr 09, 2009 | Tascam Electronics - Others
Lacie RUGGED 250GB not recognized by my PC
I think the migration assistant (in the utilities file in your application folder) can transfer files direct via USB.
Jan 23, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Officejet 6110 all in one - printing problem with Mac Os X 10.5
I suspect this is not the printer problem. The problem may be the operating system issue. (Memory management)
Regards
Rafique
Jan 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Apple iMac G5 Desktop Logo
77 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
