Question about Tally T6218 Matrix Printer
Error messege in printer tally T6218 (paper out) what is soultion
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
Tally t6218 prints and stops with no errors
The power supplies are known for shutting the printer down without any error if that is the symptom, replace the power supply.
TALLYGEN 084435 POWER SUPPLY ASSY T6218 Refurbished
If not let me know exactly what it is doing.
Dec 28, 2015 | Tally T6218 Matrix Printer
Error message PAPER OUT and PLATEN CAL required Tally 6218. Please help me. Esli mojno po ****** otvet daite.
You will need to calibrate the paper and platen.To do that,you will need to enter technical access and disable disable four fault error by pressing LF and enter button simultaneously until tech access appear on control panel display,then press tof + enter to override four fault.Now you can clear the fault message.,then go to calibration procedures.
Oct 11, 2011 | Tally T6218 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Tally Printer the error is some times Hammer
In the T6215 Maintenance Manual the fault message: Hammer Voltage has been replaced, in the T6218, with:
Hammer Voltage 1
There is a new fault message for the T6218. It is:
Hammer Voltage 2
Explanation: A high resistance coil fault has likely occurred in one or more of the hammer coils
Note: This fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Corrective Action:
Check the hammer bank for defective hammer coils.
Confirm that hammer drive board is functioning properly.
Apr 05, 2010 | Tally T6218 Matrix Printer
Error messege
Check paper out switch behind tractor assembly. It may be bent and also make sure that the green bar (if used) is installed carrectly between the tractors.
Jan 05, 2009 | Tally T6218 Matrix Printer
Error in eject page
dont use LF use FF to forward a form. if you use LF then set the topper form again.
Feb 03, 2008 | Tally T6218 Matrix Printer
Print stops after 2 pages !
Hi my tally printer 6218 giving Ribbon motion fault, what could be done to remedy this error message ?
Jan 19, 2008 | Tally T6218 Matrix Printer
Hammer voltage 2
it prints for about two minutes then starts slowing down and then stops printing showing an error of : hammer voltage 2
Sep 05, 2007 | Tally T6218 Matrix Printer
Paper motion fault
This info is from the Maint. Manual for T6212/T6215/T6218.
xotihxffu1saaaaasuvork5cyii=Sensor is located below the upper left tractor item 99 below. Clean it and make sure the V is facing your holes in the paper. If that isn't the problem? see below how to meter sensors procedures...
Jan 24, 2007 | Tally T6218 Matrix Printer
Tally T6218 Matrix Printer Logo
117 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
