Question about Belkin (F5D7230-4) Router (587009)
Belkin F5D7231-4 and ADSL2+
I have a Belkin 802.11g (Model F5D7231-4) router which works fine. I am moving to a new house and have had iinet Naked ADSL2+ installed. I have connected router and can connect wireless but cant get through to internet. iinet say the connection should be fine, so as router is pretty old, was wondering if that model router will work with ADSL 2+, or in fact I need to get a new router.
Appreciate advice
  • Craig White Jan 26, 2009
    I have the same problem.
I dont know...
however I would run ipconfig command on your PC. Make sure the default gateway corresponds to your router`s IP (if you indeeed have it conected to it)
And also make sure that your modem is set in Bridging mode and your router in PPPoE a
and the appropiate password input into it.
Posted on Feb 10, 2009
Using belkin gigabit powerline adapter with a wirless router
Try to configure the 2 routers to work with one another when they are next to each other using standard ;an cable. Once working the powerline should work fine. If you try to configure them when they are apart you have 2 things that could be causing problems to take out the powerline to begin with, then when they are working close, move them apart
Nov 05, 2017 | Computers & Internet
Belkin Router Signal Weak
Wireless configurations are tempermental over larger distances. Some routers do have the ability to increase the signal strength to over come this, but a good location is key.
The more obsticals in the way the slower the connection will become. Closed doors, being buried under books, underneath desks, can all cause the signal to come through a slower speeds to compensate.
Make sure your router is in an elevated location to help with a less blocked signal.
Are you using a Wireless-N adapter on your computer? If not, you might need an extender because Wireless-G does not have the same range as -N.
With the model number of your Belkin router I might be able to assist more.
Jan 20, 2010 | Linksys Wireless-G Broadband Router
IPod Touch cannot join the network
Is your wireless network secured ?
If it is password protected then you will need to check the wireless settings of the router.Make sure that you are using the correct password to connect to the network.
Click Here for step by step solution
Oct 28, 2009 | Belkin Computers & Internet
Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 29, 2009 | Belkin (F5D5231-4) Router
My wireless router cannot connect to my new server modem.
Try to power cycle the network.
1. Power OFF the router then modem
2. Wait for 5 minutes
3. Power ON the modem first and wait for the light to be steady.
4. When the lights are steady on the modem, turn on the router.
Jul 14, 2009 | Belkin (F5D8231-4) Wireless Router...
Blue screen and Fatal Error
Have you tried plugging other devices into the same USB port? Try this to determine if the problem is with the port.
Apr 18, 2009 | Computers & Internet
Belkin wireless adapter
Sometimes wireless phones will interfere with the signals. If the router or PC is anywhere near a phone, it might have a problem. I have one wireless network card that gives me fits like that. I have yet to get a PC working with it. I have other wireless cards that work fine. I also switched to 5GHz phones, which helped my old laptop. Check to make sure there's not a conflict with the encryption used by either the dell or the router.
Jan 19, 2009 | Dell Dimension 2400 PC Desktop
Belkin Universal Wireless Extender Set-Up Problems
Have you tried restarting and resetting the router as well ?
Feb 06, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin (F5D7230-4) Router (587009) Logo
233 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
