Question about Kitchen Ranges
Boiler works but not the oven
Model # 36725, 36729
    Problem Solver:
  • 8 Answers
Do you mean broiler? If the burner in the top of oven comes on but not ththe bottom burner, the fuse to it is probably burnt out. Check your fuses and see which are good or not.
Posted on Nov 07, 2012
How do I reset my Kenmore electric range when the oven and boiler are used the error code is F 30. Model #96412
I think that error is caused by a bad oven temperature probe (temp sensor). Either an open or a short; I forget which. You might want to check the wire and connectors to it; maybe unplug the connector and re-plug it back together. If you have an ohmmeter, you can check its resistance at room temperature - it should be between 1080 to 1100 ohms at room temp.
Oct 27, 2014 | Kenmore Kitchen Ranges
Sears model 317 B6034 top burners work. also the boiler works. The oven (bake) does not work. How do I inspect for the fuse and what ignites the oven?
you have a bad bake ignitor.i don't know what number you sent but it's not the model number,open the draw below the oven door and look at the frame where the door closes into and you'll see a tag with the model and serial number,call your parts store,give them the model number and tell them you need a bake ignitor
Jan 20, 2011 | Ovens
The oven will not ignite.. the burners and boiler will
Most of the time it is a weak ignitor. I have a training video HERE
Jan 28, 2010 | Kitchen Ranges
My boiler is working not my oven
You do not give much information, such as the model number, or if it is even gas or electric. If it is electric, the oven element is the most likely cause. If it is gas, the oven glow bar ignitor is the most likely problem. (Oh, by the way, that's broiler, not boiler)
Dec 05, 2009 | Maytag Ovens
Both boiler and oven elements stopped working at the same time both elements look fine
This is probably your electronic control board. Call us with the brand and model number and we can send the proper part to you that you need to repair it. 972-859-0929. We hope this solves your issue.
Aug 25, 2009 | Ovens
Maytag gas Stove MGR5710 bake oven does not work. boiler works
Usually I always find it's the ignightor. They are not to hard to replace. It's #5 on this looooong link
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MGR5710ADW&productCategoryId=0124002&brandId=3048&modelName=GAS-RANGE&diagramPageId=00005&componentDescription=GAS%20CONTROLS&documentId=X2906551&backToLink=Return%20to%20Sub%20Components%20list
Or go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
enter your model number and it'll kind of show you how to get it apart. Good luck.
Scott
Jan 23, 2009 | Thermador REF30 Electric Kitchen Range
Oven/boiler stopped working after poping sound
I'm sue what you heard was the broil element shorting (actually) opening up. I take it this is a electric oven? If it is. Look at the element really close with a flashlite and you should see a break or disscoloration where it made that sound. Elements ususall cost about $40-50 and are easy to replace in most models. Good luck. Scott
Jan 23, 2009 | Kitchen Ranges
Amana oven arg7300LL oven and boiler do not work?
If it is the same as my Amana, it has a small switch in front of the thermostat switch. It is only a $15 part to fix it. I am searching for the thermostat and your question came up. I am sorry it is so late in response to your question. I am sure you have fixed it by now.
Dec 22, 2007 | Amana RanARG7302 Gas Kitchen Range
Amana oven not working and boiler also
Check the oven sensor it may be the problem. Also check the lock assembly. When in self clean does your bake come on too? It should come on with the broiler.
Dec 21, 2007 | Amana RanARG7302 Gas Kitchen Range
Bizzare Oven
i will call ge technical and see if they have an issue after holidays would of you reply to me with a complete model and serial number
Dec 14, 2007 | GE JKP15 Electric Single Oven
Kitchen Ranges Logo
18 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
