Question about Refrigerators
TFG28PF parts drawers & door fixtures
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Exactly which parts do you needed? I can direct you to my supplier for the parts that you may order.
Posted on Nov 07, 2012
How to change gas fixture
Your going to have to research that some & come back with
some terminology we understand
There is no part called a gas fixture
Nov 18, 2012 | 1999 Ford Explorer
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
Washer is reading ddo. what does that mean?
Hi
Error DDO means dispenser drawer open. This error appears when the washer senses that the dispenser door is not closed. If the dispenser door seems to be closed then it seems to be an issue with the magnet. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch & signals the washer that the drawer is closed. This magnet might have moved from its place and that's why you are getting error DDO. Pull the drawer out and check the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Hope this helps... Please post back if you need more information.
Daniel
Jan 13, 2011 | Frigidaire Washing Machines
Why does oven light keep burning out on my Whirlpool Oven?
First, be sure that you are using the correct lamps, they must be aplliance bulbs, rated for use in ovens. Secodly, some oven light fixtures are equipped with a lens, and if this is missing the lamp can be exposed to very hot conditions, such as during auto-clean cycles, If you are not sure if there should be a lens, take the nameplate info to the manufacturers website, and look up a parts diagram. The nameplate can usually be found on the frame of the drawer below the oven door. Replacement lenses are relatively inexpensive, and the parts department at any appliance showroom can help you.
Also, opening and closing the oven door roughly, can break the element, especially when hot or cooling down. I hope that this is helpful, Rob
Jan 01, 2011 | Whirlpool Ovens
Replacement parts for Dovetail Fixture kit No. 23460 &Router Guide Bushing Kit No.23458 ?
I would call bosch if it is their fixture or go online to thier parts to see if you can locate the part
Dec 14, 2010 | Bosch Tools & Hardware - Others
CD DISC IS NOT SPINNING
Check the cd drawer sometimes the position switch is not detecting the drawer completely closed.
It could be an obstructing object stuck behind the drawer door who prevent the drawer to close completely.
Spider Guy
Jan 11, 2010 | Audio Players & Recorders
I have an outside spot light with a motion detector controlled by an inside switch. I want to change outside fixture & install dimmer switch in place of wall switch. I removed outside fixture. There...
First, let me say that if you're not entirely comfortable doing high voltage electrical work, you might want to call an electrician. It's not impossible for you to get hurt or killed or burn down your house. At least be sure to turn of the circuit breaker while you're working on it.
The blacks and whites twisted together are passing through power to other parts of your premises and are always on, so be sure to keep them twisted together. The red is the one that will take power from your light switch and send it to your light fixture.
At the fixture, connect the white to white and red to black, the same as before. At the light switch, connect the black to one side of the switch and the red to the other. When you turn on the switch, it will permit power from the black to travel down the red to the fixture, and from the fixture, the circuit will be completed through the white.
Sep 12, 2009 | Leviton (102-5G108-RW5)
I was changing a light fixture in my bathroom,
hello, all you have to do is to get a new breaker with the same amperage or amp's example 15 amp's of the breaker that's blown and pop out the old one and put in your new one , in the future when working with electricity always manual trip the breaker before working for your safety and the safety of the equipment .good luck
Mar 22, 2009 | Your One Source Homeline Circuit Breaker
Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
On TCD18PAD BWW refrig with freezer (drawer, not door) on bottom, water accummulates in bottom of freezer and freezes into ice which some how thaws with water flowing out bottom of drawer door onto kitchen...
You have a clogged defrost drain tube. On the back of the refrigerator in the center, about two feet above the floor, is a 7 inch by 7 inch square steel cover held on by four screws, one at each corner. The defrost drain tube emerges from the bottom of this cover and terminates loose in the drain pan below the refrigerator. Remove the cover. Underneath is the plastic defrost drain tube fixture, which is held by two screws. Remove the screws and take off the drain tube fixture. This fixtue is clogged. Run hot water and dish detergent through it and blow through it at the big end to remove the clog. Reassemble. That's it. You don't have to take the refrigerator apart. One caution. When the refrigerator has a clogged drain tube, the defrost water will back up and freeze around it. So you may need to empty your freezer and unplug the refrigerator for eight hours or so first before you perform this procedure to allow all the ice around the clogged drain fixture to melt.
Aug 31, 2008 | GE Refrigerators
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
