Question about DISH Network IR Remote Control
On tv 2 the remote controls the volume and power but will not change channels or do anything else. went to system info in tv 1, pressed sat and power. This did not help. Batteries are new.
  • Official Brand Answer
  • 263 Answers
Hey, Jane!
I can definitely help you with this. Go to the System Info screen like before, but on the TV2 remote press the 'Record button and see if the number in 'Secondary Remote Address' changes. If it doesn't, let me know here, and I will assist you in programming it!
Tommy Faust
DISH Social Media Representative
Posted on Nov 07, 2012
  • 374 Answers
SOURCE: 3.0 IR problem - new batteries in, SAT button stays on
You can check the obvious like ensuring all batteries are oriented correctly or a new set of batteries but when you are done you will more than likely still need a new remote. Call Dish at 1-888-333-3474 and have the CSC send you a new remote. There may or may not be a charge depending on your service plan and when the system was last serviced. thanks for using Fix Ya and let me know if you need further assistance.
Jim
Posted on Nov 11, 2008
  • 374 Answers
SOURCE: remote 132578 stopped working. checked batteries
Your best bet will be to get a replacement remote for this because the remote will soon develop other issues and cause you greater frustration. Why not nip this all in the bud now. Thanks for using Fix Ya.
Posted on Mar 01, 2010
SOURCE: my bell tv remote isn't working for sat but works
It would be best to call Bell technical support before going out and buying a new remote control, they can help you re-address the remote properly. 1888SKYDISH
Posted on Jun 03, 2010
  • 222 Answers
SOURCE: remote won't change the channel or anything else
Take off the batteries, open the back or your remote, lift the circuit board, clean the back of the circuit board the one that is painted green with cotton balls slightly damp with rubbing alcohol, and clean the black thingy at the back or your remote pad as well, let dry put it back together and try if it works
Posted on Jun 12, 2010
CheriT Dish
  • 146 Answers
SOURCE: My dishnetwork remote control 1 doesn't work. It
    • All DISH Network IR remotes
1. Goto System Info screen. You can enter the system info screen by either pressingthe system info button on the front of the DISH receiver box or by pressing thepower button once then the up arrow on the front of the receiver. If theseoptions are unsuccessful you can also open the smart card door on the front leftside of the receiver and pull out the smart card. 2. Onceyou are on the system info screen, hold down the SAT button until all modelights light up. 3. Entera number between 1 and 15 using the numeric keypad on the remote. 4. Pressthe pound (#) button 5. Oncethe SAT button blinks three times, press record. Note: If successful the number selected in step 3 willappear in the System Info screen under Remote Address.
Posted on Dec 30, 2010
4.4 IR/UHF PRO only controls volume on tv, will not change channel
I've reviewed your post, carl_heflin, and would be happy to help with that! Below are just a few steps for you to go through to get that accomplished.
  1. Go to System Info screen.
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button.
  5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
If you have any questions, just let me know and I'll look forward to speaking with you!
Sep 20, 2011 | DISH Network IR Remote Control
Remote will not respond. New batteries installed. I can change channels at receiver, but the remote will not do anything, even though all the led's on the remote will show lite when pushed. 6.4 ir/uhf...
Is the remote for TV 1 or TV 2. If it is for TV 2, the blue tab with the number 2 should already be on the bottom of the remote. If it's for TV 1, you need to remove the blue tab from the bottom of the remote and flip the tab over (should be a green tab with only a green 1 on it). Once you change the tab, see if you can change channels. If you can't, follow the instructions below.
At your TV 1 location on your receiver, press the System Info button to display the System Info on your TV. At the bottom of the screen, you should see Primary and Secondary Remote Addresses. Make a note of the remote addresses. With the new remote, press the record button. If this is the TV 2 remote (blue tab on the bottom), the secondary number may change; if TV 1 remote (green tab on the bottom), the primary address should change. Exit from all the menus on the TV screen till you are back to your TV picture - then try the remote.
If the above steps do not work, try the instructions below to manually program the remote to the receiver.
  • Remote to the receiver:
Aug 16, 2011 | DISH Network IR Remote Control
Cannot program Dish IR remote l03602
adeline_roll
You didn't specify if you are trying to program the remote to your TV or receiver. Is it a replacement remote or did it just quit working? I have provided instructions on how to program to your TV or receiver.
Address to receiver:
Remote: All Other Remotes
  1. Go to System Info screen (depending on receiver - press System Info button on receiver panel or pull smart card out till System Info screen appears on TV screen).
Remote: Basic Remote (Television Only)
  1. Turn the Television On.
  2. Press and hold the TV Power button for three seconds until the LED flashes.
  3. Press and release the TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off.
  5. After the television turns off, press and release the OK button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Please let me know if you have any other questions or problems. Thanks.
Ray Calo
DISH Internet Response Team
Jun 23, 2011 | DISH Network IR Remote Control
My remote is fully deprogrammed, how I can turn to turn on and off the TV and box
Hi, Cheri Torres with DISH Network Customer Service here. In order to help you reprogram your DISH network remote to your TV to control your TV functions such as power on/off of TV and volume, I would need the model number of the remote and the brand name of your TV. You should be able to locate the model number of your remote on the back of the remote at the top usually a 2 to 3 digit number with a decimal point. I will list here for you the instructions for reprogramming your remote to your DISH receiver to control your receiver functions. If you would also like me to help you get your DISH remote reprogrammed to your TV please email me directly at Cheri.Torres@Dishnetwork.com with your remote model number and the brand name of the TV. I hope you find this information useful and if you have any further questions or concerns feel free to email me.
Instructions for addressing the remote to your receiver.
  1. Go to System Info screen.You can do this by either pressing the system info button on the front of the receiver or you can press the power button once and then the channel up button once on the front of the receiver.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number to something different then what is already listed in the small white square.
Apr 19, 2011 | DISH Network IR Remote Control
My old Bell receiver 's remote was an IR Remote. How do I program the new UHF PRO Bell remote?
mikecrans175
I have provided the instructions on how to program your remote to your TV and addressing the remote to your receiver below. I hope this helps.
Remotes: Basic (Television Only)
  2. Press and Hold the TV Power button for three seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote:
Ray Calo
DISH Network
Mar 14, 2011 | DISH Network IR Remote Control
My dishnetwork remote control 1 doesn't work. It worked fine yesterday. There is no problem for the battery. When I want to change channel or press guide button, sat light is on but I don't see response...
Nov 30, 2010 | DISH Network IR Remote Control
My remote wont work
sorrycory27
I'm not sure what the remote is not operating on: TV or receiver? I have provided instructions on how to program the remote to your TV or readdress the remote to your receiver.
Readdress remote to receiver:
  5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Program remote to TV:
If you have any other problems or questions, please post to this site.
Ray Calo
DISH Network
Nov 14, 2010 | DISH Network IR Remote Control
Remote on tv 2 is not working, except to turn the tv on and off and volume. Menu or guide will not work.
velvia_w
Since the remote is not changing channels or bringing up your Program Guide, you will need to readdress the remote to your receiver. I have provided instructions on how to do this. Before readdressing the remote, you might check on the receiver if the antenna (on the back of the receiver) is secure and straight up and down, not at an angle. I hope this helps.
Ray Calo
DISH Network
Oct 23, 2010 | DISH Network IR Remote Control
My remote wont operate my sony TV volume
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | Sony RMT-D155A Remote Control
Echostar IR remote (Dish)
to set remote to tv
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
Apr 30, 2008 | DISH Network IR Remote Control
DISH Network IR Remote Control Logo
63 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
