Question about Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator
Display blinking no ice - Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is blinking on the display?
Posted on Nov 07, 2012
Blinking display
jph, this is a classic symptom of the high voltage board failure. What board did you replace? The high voltage board is the one on the back side of the refer, left hand side. Catriver.
Sep 19, 2007 | Maytag MFI2568AE Side by Side French Door...
Why is it that my refrigerator does not get cold and my freezer is not making ice
SOUNDS LIKE YOU EVAPORATOR FAN HAS EITHER SEIZED----REPLACE; OR WAS BANGING ON ICE AND FINALLY STOPPED ---DEFROST
May 15, 2014 | Refrigerators
Display knippert side by side na 20 min koelkast uitgezet te hebben
It actually is not blinking a Y, the top part of the 8 is blinking which means the sensor in the ice mold has failed. Samsung codes can make different parts of the 8 blink which means defferent things.
Jan 27, 2014 | Samsung RFG297AAWP Side by Side Bottom...
Front panel blinking
I have a Samsung RF265AABP model. I had the same problem, with the right 8 on refrigerator temperature flashing (top bar only on 7 segment display). The set buttons would not change the display either. The refrigerator and freezer both were about the right temperature (41F and -3F).
The problem was a broken temperature sensor wire on the ice maker. The sensor assembly often gets snagged on the ice tray or scoop or something and falls down, making it more likely to snag, and prevents the ice maker from cycling when frozen.
I fabricated a metal bracket to hold the temperature sensor assembly in place, and used a small tie wrap to hold the wire to the bracket, up and out of the way after soldering the broken wire of course.
If you have a volt meter you can do some diagnostics. Remove the cover from the back of the refrigerator to access the control board. Measure the voltages on the power supply, marked +12V and +5V
(yel and red, blk common). If the display reads 88 88 then the power supply is probably fine. Measure the voltages on the sensor connector CN30 at the bottom of the main control board (larger one). The gry wire on the left is common, and you should read approximately the following on the other wires starting on the left:
WHT 2.63 may depend on Pantry temp setting fresh or cold
BLU 3.59 R-DEF sensor refrigerator defrost I assume
WHT 2.55 R sensor, refrigerator temperature I assume
ORG 4.06 F-Def sensor, freezer defrost I assume
RED 3.54 F sensor freezer temperature, may depend on whether ice is frozen or still water in ice maker.
When the ice maker wire was broken, the readings on ORG and RED were 4.30 and 4.05 volts so I assume high readings above 4 volts might indicate a sensor open condition.
Control board access panel removed
Temperature sensor connector CN30
Nov 13, 2013 | Samsung RF267AERS French Door Refrigerator
Temp sensor
Check for broken wires on your ice maker temperature sensor. On my model RF265AABP that was the problem causing display to read 88 88 with one digit blinking.
Jun 29, 2013 | Samsung RB217ABPN Bottom Freezer...
Defrost timer on TFX27PF
HI SCOTT.a bit vague but i'll assume u mean it blinks but it cools for 4 days and then starts defrosting right?(temp drops u mean it gets warmer NOT colder.) well first i would check your condensing uni thoroughly.check if evaporator is iced up or not.ventilation ok.if iced up defrost all 24/48 hours and try .u could get lucky.if same again check heater and t/stat and defrost timer.if not iced up check refrigerant. fan motors. and compressor.good luck ali
Jul 05, 2012 | GE Refrigerators
Freezer, Ice Maker and Water dispenser not working
it has to get down to the proper temperature after the reset the set point is -4 for the freezer and 38 for the refrigerator. the numbers shown o\n the digital display panel stands for the actual temperatures. When the compartmnet tempertures go down, so do the numbers on thge display panel, and finally they reach the set temperatures. Once the system is stabilized , the display tempoeratures are the set temperature.
Jan 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
The control panel light blinking and ice trap door will not close
Sounds like you need a new display pwb. The flapper for the ice works on a solenoid which is on a little board that is behind the display board. When the power is cut the flapper should close as it is on a spring. I don't believe that there is any worries of it catching fire. Have a tech come and replace the board for you.
Sgt 48
Jun 03, 2008 | LG LFX25960ST Stainless Steel French Door...
Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Logo
18 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
