Question about Dynex Blu Ray Player
Dynex blu ray player won't connect to router
I've had it for almost a year now and it's always worked fine. Now when I turn it on, an icon pops up that says disconnected. I go the the network settings and the router shows up fine. I enter the password and tell it to connect. A few seconds later it tells me it timed out. There's nothing wrong with the router. All other wireless devices are working fine with it.
4 Suggested Answers
  • 10 Answers
SOURCE: Dynex router blocks connection of Samsung BD-P1600 Blu-Ray to Net
I'm not familiar with that particular router, but all of them are about the same. You can go in and edit firewall settings to allow a particular IP address to have access. Don't disable the firewall completely, just set it to allow that I.P address to have full access.
Posted on Nov 15, 2009
jamesmarcum2
  • 79 Answers
SOURCE: dynex blu ray sound and no picture
try a new HDMI or try compusite cables they are five cables green blue red white and black or you could try just rca jacks yellow white and black the only problem with rca jacks is it wont be HD but you will have sound and picture
Posted on Dec 09, 2012
Have a netter solution throw the damned thin away and buy one that worth what you pay for. What a piece of sh@#!
Posted on Dec 11, 2016
I SIGNED UP but have been unable to watch anything. Called comcast .my blue ray is not connecting to internet. I haVE wireless THAT'S NOT PROBLEM. Called Netflix 2x's still haven&#
It seems the problem is your Blu-Ray player can't connect to your wireless network. Based on what you said (and based on what the problem usually is), I'm guessing that you don't have the WPA (or WEP) key to your network. If you don't know it, you can log in to your router and look on the "security" or "wireless security" tab. It might be called "WEP key" or "WPA passkey" or "network password" or whatever. That is probably the code that the Blu-Ray player is looking for.
I could get more specific if you posted the make and model of your Blu-Ray player and router (or access point). If you also post the operating system (Windows XP or 7 or MacOS X or whatever) of a computer that is able to connect wirelessly, I can tell you how to get the WPA key off that computer.
Feb 02, 2015 | Dynex Televison & Video
Lg blu-ray bp200 wont connect to wireless network for netflix
Change your network modem/router to WPA-AES only (remove the AES+TKIP setting).
Feb 02, 2013 | LG Super Blu BH200 Blu-ray and HD-DVD...
My remote won't work for my DMP-BD75
If both the remote (which can be tested by a shop for free) AND the front buttons do not work I suspect the unit may have a lock out that disables everything on both except for on off..........
Oct 30, 2012 | Panasonic DMP-BD60K Blu-ray/DVD Player
Netflix will not connect internet on vizio blueray player
see this steps and fix it. God bless you
    • 1 Reset the player if the device stops behaving normally. (Keep in mind that rotation sounds and picture issues during search are normal.) Select the "System" menu from the setup area and choose "Restore Factory Settings" or a similar option. Allow the device to restart and then try the disc again.
    • 2 Insert the disc face up in the tray. If playback fails to start or if it starts and then stops, wipe the disc with a soft cloth and try again. Throw out any heavily scratched discs that won't play.
    • 3 Change the "TV Aspect" to 16:9 in the setup area of the menu if the picture expands left and right or if the picture size is wrong and you're using an HDMI (High Definition Multimedia Interface) cable.
    • 4 Set the wireless Internet router to automatically allow new devices to connect to it if the Insignia player won't connect to the Internet. The player uses only WPS to connect. Some routers that use different automatic setup protocols won't work.
    • 5 Make sure that the connection between the player and the television uses an HDMI cable if you're watching a Blu-ray movie. Some Blu-ray discs will only play over an HDMI connection. Also, remember that some Blu-ray discs won't work with PiP (Picture-in-Picture).
Oct 15, 2012 | Vizio VBR220 Blu-Ray Player
Adapter inactive
It is not the problem with the router. It is the problem with the wireless adapter on your computer. Open Network connections and look for Wireless network connection. If it is not there then open the Device Manager and look for Wireless network adapter under Network adapters. It seems that wireless adapter on your computer is not working or it is not detected by your computer. If you have external wireless adapter then unplug it and replug it.
Nov 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I have a Toshiba BDX2100 Blu Ray player. I've owned it since October 2010. I've not had any problems with it until a couple of days ago. It won't turn off unless I unplug it, and it only opens...
Do you have the Blu Ray player plugged into a surge protector, sometimes surge protectors can cause odd feedback in certain electronics and cause them to be buggy. If this is the case, take it off the surge protector and plug it straight into the wall and see if that fixes the problem. If this isn't the case or doesn't solve the problem there could be a number of reasons this is happening, there could have been a surge that fried some internal components causing the player to not function correctly, or it could have just had a hardware malfunction. If this doesn't help I would recommend calling the manufacturer of the player to see if they can provide you with additional info
Jul 18, 2011 | Video Game Consoles & Games
My Toshiba BDX 2500ku won't turn on...Ive used it before...now it won't even open...please help....its only about 4 months old and we've only watched about 2 movies....
check the back of the player to see if the power cord has come loose, some units have a removable cord and it can get pulled.
Jun 20, 2011 | Toshiba BDX2000 Blu-Ray Player
My toshiba BDX2700 has an integrated wifi connection. It connects to my home networrk. For 2 weeks it worked just fine and now it won't connect. Or, actually, it says it "connects" to the...
Seems like the DNS on your router has failed to provide address info for your BR player. I would first try this:
  1. Unplug the Blu-Ray player
  2. Unplug your router for 20 seconds
  3. Plug your router back in and wait for the Wifi symbol or WLAN light to turn on
  4. Plug in and turn on the Blu-Ray player
If that fails, I would double check the WiFi settings on the Blu-Ray player, make sure that you have the SSID and passkey correct.
If that still fails, I suspect that your router's DHCP table has a problem with it. You may need to consult your router's manual for instructions on how to clear the DHCP table. The easiest way to do this is to perform a factory reset on the router. You will have to redo any configurations you may have applied to the router such as WiFi name (SSID) and pasword.
Mar 13, 2011 | Toshiba BDX2700 Blu-Ray Player
Nov 15, 2009 | Dynex 4-Port Ethernet Broadband Router...
Dynex Blu Ray Player Logo
196 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
