Question about HP Computers & Internet
Computer has a sticky key
The four key does not register
  • 130 Answers
You can try either pressing it many times in a row, or gently prying up the key and pulling it to the left or right, then once you have the key off you can clean the pad underneath and then replace the key by pressing it straight down until you hear the snap.
Posted on Nov 07, 2012
Re: Microsoft wired 600 keyboard/sticky keys... Wanting to know how do I enable sticky keys on my Microsoft wired 600 keyboard pls?
Sticky Keys is a software function. I am assuming you are using Windows - open the Control Panel, select the Ease of Use Center, select Make the keyboard easier to use. In here, you can turn on and setup Sticky Keys.
Dec 21, 2016 | Microsoft Computers & Internet
I seem to have locked my keyboard and can only use the one on screen, since this computer is touch screen
By the sounds of it, you have enabled your computers Sticky Keys. To disable the Sticky Keys, go to Control Panel -> Accessibility Option and disable everything.
Note: Sticky Keys are enabled by pressing the shift key five consecutive times.
Feb 27, 2015 | Dell Computers & Internet
Shift key is not working
You might consider using, at least tempory, a external usb keyboard with a touchpad, you can get get them at Wal-Mart for around $20.00
Otherwise consider taking it to a computer shop and have them test the keyboard and if need be order you a new one. If this computer is still under warranty then I would would talk to the support team that you purchase it from. Good Luck.
Mar 28, 2014 | Computers & Internet
Turn sticky keys off
My asus computer won't type anything. I think I turned sticky keys on. What is the solution? Thank you
Jan 05, 2014 | Acer Computers & Internet
Dell latitude D610 sticky keys
Hello there...This is a simple task.u only need to press shift key 5 times, then a pop-up window would appear asking u to enable or disable the sticky keys.u can then select whatever u feel like...
Jan 22, 2013 | Dell Latitude D610 Laptop Computer -...
The.spacebar.stopped..working.
If your space bar isn't responding when you press it, or if it responds sluggishly, it's possible that you have inadvertently enabled the "Sticky Keys" or "Filter Keys" accessibility option in Windows.
When these options are enabled, your keyboard response time will be dramatically slowed and may require more than one tap to register a keystroke.
Fortunately, it's easy to disable these functions and return your keyboard to normal working order.
Click "Start" and select "All Programs."
Click "Accessories" and select "Ease of Access."
Click "Ease of Access Center."
Click "Make Keyboard Easier to Use."
Click "Set Up Sticky Keys." Deselect the checkbox that says "Turn on Sticky Keys When Shift is Pressed Five Times." Make sure the box that says "Turn on Sticky Keys" is not checked. Click "OK" to save your changes.
Click "Set Up Filter Keys." Uncheck the box that says "Turn on Filter Keys."
Click on the checkbox next to "Turn On Filter Keys When Right Shift Is Pressed For 8 Seconds" to deselect it. Click "OK" to save your changes.
Click "OK" again to save all of the keyboard accessibility changes you have made.
Hope this helps
Oct 29, 2012 | Gateway LT2021u Netbook
When using the Cap key it puts in a /. How do i
mcdevito75 here, A key may be sticking on your key board, but first use the computers stick key feature. From your home page type in search Sticky keys, this should allow you to bring up your computers sticky keys solution. Hope this helps.
Jul 17, 2010 | Gateway 2520915 Keyboard
I have paid for my stardefender4 game but i haven' been able to register it
Search CD-key file on CD or your game folder or search it on internet.
May 21, 2010 | Computers & Internet
My honda cbr 600rr 2005 will not start the hiss system is flashing when key is in ignition ,and when you turn the engine over it just will not fire up help
1. Obtain a new transponder key.
2. Grind the key in accordance with the shape of the original key.
3. Apply 12V battery voltage to the ignition pulse generator lines of the engine control module (ECM).
4. Turn the ignition switch ON with the original key. The immobilizer indicator comes on and it remains on.
*The code of the original key is recognized by the ECM.
*If there is any problem in the immobilizer system, the system will enter the diagnostic mode and the indicator will remain on for approx. ten seconds, then it will indicate the diagnostic code (page 20-5).
5. Disconnect the red clip of the inspection adepter from the battery positive (+) terminal for two seconds or more, then connect it again. The indicator remains on for approx. two seconds, then it blinks four times repeatedly.
*The immobilizer system (HISS) enters the registration mode. Registrations of all key except the original key inserted in the ignition switch are canceled. (Registration of the lost key or spare key is canceled.)
NOTE:
The spare key must be registered again.
6. Turn the ignition switch OFF and remove the key.
7. Turn the ignition switch ON with a new key or the spare key. (Never use the key registered in previous step.) The indicator comes on for two seconds, then it blinks four times repeatedly.
*The new key or spare key is registered in the ECM.
*If there is any problem in the registration, the system will enter the diagnostic mode and the indicator will remain on for approx. ten seconds, then it will indicate the diagnostic code (page 20-6).
CAUTION:
Keep the other transponder key away from the immobilizer receiver more than 50mm (2.0 in).
8. Repeat the steps 6 and 7 when you continuously register the other new key.
NOTE:
The ECM can store up to four key codes. (The four keys can be registered.)
9. Turn the ignition switch OFF, remove the inspection adapter and connect the ignition pulse generator connector.
10. Turn the ignition ON with the registered key.
*The immobilizer system (HISS) returns to the normal mode.
11. Check that the engine can be started using all registered key.
If that doesn't work,You will need to go to a dealer and have the keys reprogrammed.
Jun 04, 2009 | 2005 Honda CBR 600 RR
Computers & Internet Logo
15 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
