Question about Breville Blenders
Blade for Breville Wizz model BBL500
Chopper blade keeps breaking when cutting food
EwingElect
  • 276 Answers
SOURCE: seek chopper blade Multiquick MR 4050
Hi. If you're in Australia I may be able to help, otherwise refer to http://braun.com/default.html to locate your local supplier of spare parts.
Posted on Mar 31, 2009
SOURCE: Chopping blade for Braun Vario 300 watt chopper
just google blades for mr300 and a few places come up im trying to find one for mine too! average price 7.50
Posted on Oct 05, 2009
  • 5 Answers
SOURCE: Blade won't turn in Cuisinart Duo Blender -- not motor
You have to unscrew and disassemble the blades - pretty easy, just take two rags and grab the blades with one (so you don't cut yourself), and then turn the rubber piece on the other side COUNTER CLOCKWISE, opposite of what you would do to loosen. the rod that runs in the middle that's connected to the blades on mine was all corroded, so I sprayed it down with WD-40, took my Dremel to it and smoothed out the corrosion, added some fresh grease ($2 tube goes a long way), washed the other parts with some Dawn and dried completely, reassembled and it runs much better! Not sure how long it will last, but I have a feeling that one time I ran the blender for a long time instead of pulsing, and the grease that came with it couldn't handle the heat from it turning so long. Anyway good luck!
Posted on Jan 15, 2010
pappapumpdaf
  • 635 Answers
SOURCE: grease build up around blade and where it attaches to base
Grease can only creep into the blender vase if the oil seal has worn out, or the blenders blade shaft is worn and wobbling. Try cleaning all parts in alcohol to soften the seals. Rebuild kits and replacement blades can be found here (http://www.brevilleusa.com/breville-parts/blending.html)
Posted on Mar 09, 2010
  • 1739 Answers
SOURCE: BIBC1030 Blender: I won the Wolfgang Puck Immersion Blender/Chopper ...
Replacement parts for Wolfgang Puck Immersion Blenders are available here:
http://www.wpcookware.com/categories.asp?cat=26
If you do not see the model number for your product or parts are not shown, suggest you contact their Customer service at 1-800-275-8273 to determine if the required replacement part is available for your model. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
Posted on Apr 01, 2011
Where can I get the Pica Tutto blade, Blender blade, aerator blade, puree blade for the Miallegro Mi Tutto 9080
Miallegro don't appear to offer spares for their own products. If you buy a new one for $70, you will have spares of what you have already. http://www.foodprocessorsstore.com/product/miallegro-9080-mitutto-450-watt-immersion-hand-blender-stainless-steel-with-whisk-and-chopper-attachment-5-speed-turbo
Or you could ditch the brand and buy Braun or Kitchen Aid
http://www.foodprocessorsstore.com/product/braun-mr320-multiquick-3-hand-blender-450-watt-220-volt-not-for-american-voltage
http://www.kitchenaid.ca/en_CA/shop/countertop-appliances-1/countertop-appliances-2/hand-blenders-3/-[KHB2351OB]-2100856/KHB2351OB/
Our Location Address:
Idea Team Work,LLC
8725 NW 18 Terr
Suite 404
Doral FL, 33172
Telephone:
1-888-Miallegro (642-5534)
Mar 08, 2016 | Miallegro 9080 Mitutto 450-Watt Immersion...
Making a high pitched noise while blending; is motor breaking down?
there are some Breville Blender troubleshooting tips here
http://brevilleusasupport.com/bbl550xl/troubleshooting . Tied in with that, a high pitched noise could come in from a few directions:
Some blenders will use reduction gears to get more torque and power out of a high RPM, lower power motor. If this is the case, the whine could be from the motor, though if you hadn't noticed before, that would not be reassuring.
Per the troubleshooting, check that the blade is firmly attached, and that the coupling from jug to base is firm. If there are gaps or loos spots, there can be buzzing or whining between sort-of-spinning parts and shafts or bolt threads.
Check the motor base for dried spilled-on margarita mix or marinara sauce or what have you. they try to seal this pretty tight in a blender, but it has to spin, so food spills can get in the gap and cause friction and resistance, which can in turn cause whining noises from parts not expecting the load. If you do any cleaning or poking there, make sure you unplug the blender first. Shocks are not fun.
likewise, make sure that blade rotates easily from turning the coupling on the outside of the jug. If not, the bearing may be siezed or contaminated. That you'd likely want to fix by replacement.
Hope this helps!
D
Nov 19, 2015 | Breville Blenders
Hello, I didn't see model #BBL600XL which is what
The jar has to be on for it to blend.
If you replace the jar first check the printing on your old jar. If your jar has blue print you will need a new jar and blade, Breville redesigned the jar and now the old blades don't work with the new jars. You tell the difference between the jars by the print color, old is blue, new is white.
BBL600XL/06A jar part number
BBL600XL/14A blade part number
Contact Breville at 1-866-273-8455 for service center locations.
Mar 23, 2011 | Breville BBL550XL 5-Speed Blender
Hello. I need two parts for my Breville Classic BlendMaster Model CBL-10. I need the removable centrally located inner lid and also the blade assembly features patented stainless steel twin cutting...
Breville CBL10 has been a fantastic appliance but now electrical section works at slow speed only so I will get rid of it, however the glass jug complete with lid, blade etc is still perfect. Does anyone need this part? I am in Rockhampton.
Jan 23, 2011 | Breville CBL10 BlendMaster Classic Work...
Grease build up around blade and where it attaches to base
Mar 09, 2010 | Breville BBL600XL. 5-Speed Blender
Breville Blender
I need the blend jar for Breville Blender electronic Model BL3. I did not notice that a stainless steel spoon was in the blender. When I switched it on the crossed blade broke off.
Oct 15, 2009 | Breville ikon Hemisphere Blender - Silver
Oct 03, 2009 | Braun MR 300 MultiQuick Blender
Seek chopper blade Multiquick MR 4050
Mar 21, 2009 | Braun MR 4050 HC MultiQuick 2 Speed...
Chopper blade are broken
www.viewpointdirect.co.uk
Sep 21, 2007 | Braun MR4050 HC Blender
Blenders Logo
32 people viewed this question
Top Breville Blenders Experts
Mike
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
