Check if the signal cable for the display is connected and whether there is any kink that may break a wire inside the cable. If the circuit for display inside the computer is broken, most of the time you would hear beeping when turning on the computer.
Rotating blinking lights in the display is probably an indication that the Wrinkle Prevent option has been selected. Wrinkle Prevent will continue to tumble the dryer without heat after the cycle has ended to help prevent wrinkles from setting in. When this option is selected by pressing the Wrinkle Prevent button on the control panel, the display will count down the estimated cycle time; when the cycle ends, the display will show lights blinking in a circular (or actually rectangular) motion.
To deactivate, simply press the Wrinkle Prevent button again so the light is not illuminated.
I am assuming you have a laptop. There are a wide range of "no displays". problems. Here are a few:
1. On start up you have three lights on the front of your computer. 2. Power Light. Is it solid whit? 3 Battery light. It does not light up unless you have battery problems 4. Hard drive light. Is it blinking? 5. It is very important that it is blinking 6. If it is blinking you are having problems with your video assembly. 7. If it is not blinking, you have problems with you operating system. 8. Please advise to narrow down the problem
To open the door you need to remove the panel below the door (three screws at bottom of machine) then reach up by the door lock and there will be a plastic tab hanging down, that will be the manual release for the door, just pull it down. Wile you're in there see if the technicians packet is taped to the inside wall of the washer, it helps to explain the workings of your machine. If the display is blinking, is it blinking a code? like F11 or FdL? Knowing the code will help in troubleshooting the problem. Good luck.
You
should be able to see the reasons in the front panel, remove the
front cover and you will see a small display with some information
passing slowly. Sometimes is just the redundant power-supply that is
disconnected.
The blinking lamp light refers to the lamp door not being closed. There is a little lever behind the main panel and if that's not shut, the lever won't be pressed in and therefore the light blinks. If it's a failed lamp, the lamp indicator light will be a solid, not blinking.
I HV A PROBLEM WITH SONY-KV-HA21M80 TV. WHEN THE SWITCH ON POWER ON AND GETTING OFF. FRONT LED IS BLINKING 4 TIMES. WHAT COULD BE THE PROBLEM. PLS HELP ME ON THIS.
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
