Question about HP Photosmart C6180 All-In-One InkJet Printer
Printer says 'cartridges missing or not detected'
I've tried taking out the cartridges and putting them back, but the message is the same. The don't appear to have run out of ink.
  • 65 Answers
Sounds as though you have a bum sensor, you may have to take it back to the store where you purchase it, or buy new cartridges and try them, you may have gotten some bad cartridges, it happens! Even tho they are new? Are they the correct ones for your unit????
Posted on Jan 05, 2009
Error message: "cartridge missing" ... not true!
take the cartridge out and put it back in, sometimes they don't line up right, or communicate properly with the printer, or there is a malfunction with the cartridge
Nov 16, 2011 | Dell 926 All-In-One InkJet Printer
I get the message that the print cartridge is missing or not detected. Have tried taking cartridges out and putting them back in, replacing with new cartridges
What you could try is to remove both ink cartridges and close cover.
Turrn off printer and unplug from electrical outlet.
Wait at least 15 minutes for printer to reset.
Plug back in printer, turn on and wait until printer stop .
Install both ink cartridges.
Jan 11, 2011 | HP Photosmart C4180 All-In-One InkJet...
HPPhotosmart C4250 mgs "Printer Cartridge missing or not detected
There may be debris that is blocking the communication between the cartridge and the printer, especially if you are using a remanufactured cartridge. Remove the cartridge and unplug the printer from the power supply. Take a little bit of rubbing alcohol on a cotton swab and wipe off the contacts on the cartridge as well as the contacts inside of the printer. Allow both to dry for a few minutes before plugging the printer back in and re-installing the cartridge. This should clear up any miscommunication between the two.
Mar 15, 2010 | HP Photosmart C4280 Aio Printer
I keep getting the error message "An ink cartridge appears to be missing, not detected, or incorrectly installed" I am sure that I have installed both ink cartridges correctly though. Any thoughts?
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 20, 2009 | HP DeskJet F4280 All In One Printer InkJet
I installed new cartridges and I'm still getting a message. "cartridges replacement required" It's a Lexmark X2650 printer
did you put in new cartridge or refill the old? If you bought new ones you could have gotten one with a bad chip. I would take it back and exchange it for a different.
Oct 01, 2009 | Lexmark X2650 All-In-One InkJet Printer
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Missing black ink cartridge
Unplug the printer from the wall. Also remove the power brick for 60 seconds. This will reset any error messages you get from the printer. Plug everything back in and power on the printer. Take out the Dell black cartridge and reseat it. Put it back in and do the same for the color cartridge. When you close the printer it should try to print an alignment page.
Aug 11, 2009 | Dell A960 All-In-One InkJet Printer
Keep getting message "Print cartridge(s) missing or not detected"
If these are new cartridges then you can try wiping the contacts and the pins with a dry paper towel then re install them. do not us tissue as some of them have lotion on them. If these are remanufactured cartridges return them for an exchange.
Mar 21, 2009 | HP PhotoSmart C4280 Laser Printer
Cartridge not detected or missing message.
did you remove the tape from the new cartridge ?
Dec 23, 2008 | HP PhotoSmart C4280 Laser Printer
Print Cartridge Missing
had cartridge refilled put back but comes up no cartridge
May 21, 2007 | Lexmark Optra S 2450 Laser Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
