Question about Samsung SyncMaster 540N 15" LCD Monitor
Funny ha? i had a 15inch samsung lcd when the current flactuate my display did not come back to normal its now dead, but when i remove the vga connector there was a 3 primary color appeared, i tried to replace the vga cable with the good one but nothing changes
    Scholar:
  • 125 Answers
Try to connect to other PC or check the card in your PC.
Posted on May 22, 2007
I recently replaced the battery in my acer aspire 5532. Less than a week later when I turn it on the screen remains black. You can hear the computer starting and the indicator lights turn on but nothing...
Oh, OH!..........................
1) Does the laptop feel warmer than usual?
2) Have you noticed any strange behavior?
Staying up late at night?
Excuses why there are DVD's all over the place?
Refrigerator door is left open?
Any mention, why there is an M1A2 Abrams tank sitting in the living room?
OH,.......I'M JUST KIDDING!
A) Laptop on, take a flashlight, and shine at the LCD screen; at various angles
See faint images?
(Ah HA! Busted! Somebody's holding a thin curtain up inside the Display Assembly!........................Not funny?..................K)
B) I would like you to connect a VGA monitor, to the VGA port (connector) on the laptop.
This test will show us if the laptop is working okay, but the problem is the Video Cable, or inside the Display Assembly.
It also tells us if the graphics chipset is good.
Laptop OFF, monitor OFF, connect a VGA monitor; to the LEFT side of the laptop; and to the Blue VGA port.
This is a general example of a VGA connector (port), and VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for the VGA Cable example.
You can use one of the older CRT types of monitors, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
C)Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings the display should automatically, on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold the Fn key down, and at the SAME time tap once on the F5 key.
The F5 key is the Display Toggle-Over key
Still no?
Hold the Fn key down again, and tap the F5 key once more.
IF, the display shows on the external VGA monitor, then the problem is the Video Cable; or inside the Display Assembly.
[Inside the Display Assembly would be screen Inverter, or LCD screen ]
http://battery-adapter.com/product_info.php/products_id/3408/vAspire+5532+Series
The plastic frame in front of the LCD screen, is the Display Bezel.
Acer? LCD Panel Bezel, or LCD Bezel
http://www.youtube.com/watch?v=9_UtDnQuQUA
Go to 0:45
The green rectangular object that was behind the Display Bezel, and is mounted to the bottom of the LCD screen; is the screen Inverter.
As you can see it's a green colored, rectangular circuit board.
Just showing you location. If it is decided to replace it, I will step by step you through the procedure.
Now a small primer if I may;
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or more than one), or a series of LED's
(Light Emitting Diode)
As far as I can tell the Aspire 5532 uses one (1) CCFL for a Backlight,
https://www.laptopscreen.com/English/model/Acer/ASPIRE~5532/
However, Laura, this is not 'etched in stone'.
If your Aspire uses LED's for a Backlight, it will be stated on the Palm Rest Cover.
A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses; but on a much smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch, or about the width of this capital letter -> O <-
Average length is almost as long, as the LCD screen is in height.
View the last 8 photos,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
A screen Inverter is used to convert the power (Electricity), from the laptop; for the LCD screen, and Backlight.
90 PERCENT of the time, the fault can be attributed to a bad screen Inverter.
CCFL backlighting uses a screen Inverter.
LED backlighting GENERALLY does not.
Primer over.
Please post in a Comment, as to whether the display shows on the external VGA monitor.
We will diagnose from there.
Regards,
joecoolvette
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor icon
Apr 08, 2013 | Computers & Internet
My hp dv5000 screen is blank
Problem can be;
A) Graphics chipset
B) Video Cable
C) screen Inverter
D) LCD screen
Let's diagnose, and find out.
A) Graphics chipset:
To start off with, the Pavilion dv5000 series of Notebook PC's; is NOT known to have a problem with the graphics chipset.
The Pavilion dv2000 series, Pavilion dv6000 series, and Pavilion dv9000 series; does.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port; on the laptop.
The VGA port is on the Left side of the laptop, and located towards the rear.
Scroll down a little for VGA Cable example.
You can use a CRT type of monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not:
Press, and hold down on the Fn key, and at the SAME time tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
Still no? Hold the Fn key down again, and tap once more on the F4 key.
No display on external VGA monitor, suggests a problem with the graphics chipset.
(Most of the time it is a problem with the Mounting, of graphics chipset TO motherboard. If this proves to be your problem, state in a Comment )
Display on external VGA monitor means the problem is the Video Cable, or inside the Display Assembly.
(screen Inverter or LCD screen)
B) Video Cable:
The Video Cable plugs into the motherboard, in an area under the Switch Cover.
(Left side.
Switch Cover is the plastic cover above the Keyboard, and below the LCD screen. Has the Power On Button, LED indicator lights, etc in it)
It then loops by the left Hinge, and goes up into the Display Assembly.
There is a small separate wire that comes from the main Video Cable, and connects to one side of the screen Inverter.
The main part of the Video Cable goes on, to connect to the back of the LCD screen.
Example of Video Cable,
http://www.batterycentury.com/hp-430531-001-cable-p-215726.html
Click on image to enlarge.
The wide connector you see at the top/left, connects to the back of the LCD screen.
The wide connector at the bottom/right, connects to the motherboard.
The single cable (Wire) coming off at the bottom, connects to one side of the screen Inverter.
Just due to normal repeated opening, and closing of the laptop; the Video Cable may become pinched.
This leads to it being pulled on, and may also lead to damage of the Video Cable.
(Stretched/Broken wires)
Procedure is to Physically check the connections of the Video Cable. Visual inspection alone will NOT do. You need to physically see if you can plug the connection in tighter.
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Remove the Switch Cover.
[Switch Cover is just that. A Cover. I will give a link to a free Service Manual from HP Support, towards the bottom of this solution ]
Try to plug the Video Cable connection at motherboard, in tighter.
Once done reinstall the Battery, and attach AC adapter. Plug AC adapter into power.
Turn the laptop on.
Still no? Turn laptop off. (Hold down on Power On button)
Remove ALL power again.
This time check the Video Cable connections at screen Inverter, and back of LCD screen.
The plastic frame in front of the LCD screen is the Display Bezel.
Example,
http://www.ebay.com/itm/447997-001-HP-Pavilion-LCD-Display-Bezel-DV9000-Series-w-Webcam-GENUINE-/170992584210?pt=US_Laptop_Screens_LCD_Panels&hash=item27cff3c612
Service Manual indicates to remove Display Assembly from laptop, in order to remove Display Bezel.
IMHO this = NO.
I think you can remove the Display Bezel, without having to remove the entire Display Assembly.
This video details removing the Display Assembly.
Shows replacing the LCD screen.
http://www.youtube.com/watch?v=NNyvf4KqeIY
What my concern is with removing the Display Bezel, is the integral Hinge Covers that are a part of it.
I believe the Display Assembly can be tilted far enough back, that the Display Bezel can be removed, and carefully ease the Hinge Covers out/off at the same time.
Why not just remove the Display Assembly?
A whole lot less stuff to reconnect, after you have checked the LCD screen connection of the Video Cable, and screen Inverter connection.
After disconnecting the LCD screen from the Hinge Brackets, you just tilt the LCD screen forward, and check the Video Cable connection.
Then slightly tilt the Display Cover back, so the LCD screen can rest against it, and reinstall power.
Connections are plugged in tighter, and this proves to Not be the problem, go on.
(Don't forget to remove ALL power again)
The Screw Covers are made of synthetic rubber, or plastic.
They are held in place by a type of rubber cement.
I like to use a computer pick, (Much safer than a blade!), and lift up at the base of the Screw Cover.
I also like to GENTLY stick them to the Display Bezel for safekeeping. (They like to stick to the tool, your fingers, and it seems passing cars. "Oops, dropped one. Where'd it go? Hmmmm)
If you are careful with them you can reuse them. (Doesn't stick anymore? Apply a TINY dab of rubber cement to them, with a toothpick)
Screws removed, I suggest cut a piece of thick construction paper, that just fits the inside edges of the Display Bezel.
Helps prevent scratching the LCD screen, from your fingernails, when you go to flex the Display Bezel, and remove it
The LCD screen is an Assembly of layers. They are held in the factory aligned position, by the metal Screen Frame which surrounds them.
There are screws that hold the Hinge Brackets TO the Screen Frame, and there are screws which when removed, will take the Screen Frame apart.
ONLY remove the necessary screws which hold the Hinge Brackets, TO the Screen Frame!
More in a Comment.
Regards,
joecoolvette
Feb 24, 2013 | HP Pavilion dv5000t Notebook
Laptop all whit screen
Dell Inspiron 1420 Notebook PC?
The white screen can be fixed. How?
Connect a VGA monitor to the laptop. Connect to the VGA port on the right rear. Example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
You can use a CRT type monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
By default the display should show on the external VGA monitor.
No?
Press, and hold the Fn key down, and at the same time tap the F8 key ONCE.
Still no?
Hold the Fn key down again, and tap once more on the F8 key.
No display on the external VGA monitor, means you have a bad graphics chipset. Replace motherboard.
Display does show on the external VGA monitor, means you have a problem with;
1) Video Cable
or
2) Screen Inverter
or
3) LCD screen
Video Cable:
The Display Panel Cable (Video Cable for Dell), connects to the motherboard by the left Hinge.
Goes under the left Hinge, and up into the Display Assembly.
It then connects to the Screen Inverter, and to the back of the Display Panel. (LCD screen for Dell)
From normal opening, and closing of the laptop, the Display Panel Cable may become pinched in the left Hinge.
This can cause;
A) The connection at the motherboard to come loose
B) The connection at the back of the Display Panel to come loose
C) Stretch the wires inside the Display Panel Cable's sheath, and damage the wires. (Break)
If you are lucky just the connection at the motherboard, and/or connection at the back of the Display panel, may have come loose.
Diagnoses is to NOT just look at the connections, but physically push the connectors of the Display Panel Cable, into the connector at the motherboard, AND back of the Display Panel.
Visually inspect the Display Panel Cable's sheath. Do you see any outward appearance of damage? This means the tiny wires inside may be damaged.
Replace the Display Panel Cable.
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Keyboard Cover.
Unfasten the Keyboard, LEAVING the Keyboard Cable ATTACHED to the motherboard. Roll the Keyboard over, and lay it upside down on the Palm Rest Cover,
http://support.dell.com/support/edocs/systems/ins1420/en/SM/display.htm#wp1129771
[ NOTE*
Two Philips head screws at top of Keyboard. After removing, lift the top of the Keyboard up a little, slide it a LITTLE towards the Display Panel.
DO NOT lift it straight up at first.
There are 3 plastic tabs on the bottom of the Keyboard, that slide into the Palm Rest Cover. If you pick it straight up you will break those tabs off ]
In Removing the Display Assembly, note where number 1 points to.
This is the Display Panel Cable's connection, TO the motherboard.
Note where number 2 points to. Those cables going to the Mini-Card Antenna, HAVE to be reconnected, right back to the SAME terminals on the Mini-Card. Make a mark on the cables, and matching marks on the Mini-Card.
Use the instructions in Removing the Display Bezel.
Use the instructions in Removing the Display Panel.
View the last illustration in Removing the Display Panel.
Note how the Display Panel Cable attaches to the Display Panel, and Screen Inverter
Number 2 points to the connection at the back of the Display Panel
Number 6 points to the connection to the Screen Inverter
The Black connector that is not numbered at the bottom, is the motherboard connector of the Display Panel Cable.
This is a better view of the screen Inverter,
http://www.ebay.com/itm/Dell-Inspiron-1420-1421-LCD-Inverter-Backlight-Combo-/370274752470
Display Panel Cable checks out? Look at the screen Inverter. This small circuit board is located at the bottom of the Display Panel, and behind the Display Bezel. Closer look at link listed above.
Is the cable coming from the Display Panel Cable, plugged in tightly to it?
Does the screen Inverter look damaged?
Post back in a Comment, and we will go from there.
Regards,
joecoolvette
Jun 09, 2012 | Dell Inspiron 1420 Laptop
Syncmaster 216bw monitor..stuck in power saver mode..power light blinking
Did you try this monitor with another PC yet? VGA cable connectors are properly seated?
This model (same chassis as the 223w) is known for haing bad caps in the power supply/inverter board as shown here:
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/Samsung%20223bw/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 26, 2011 | Samsung SyncMaster 216BW Monitor
Samsung syncmaster 2033sw monitor, till now i was using a vga cable for the display, but recently i bought a dvi cable and connected it. but its not detecting the display of dvi cable. if i remove the vga...
LCD Monitors having multiple inputs have option and option to select and switch between the displays from analog (VGA) or Digital (DVI) inputs. Go to the LCD menu and select input source (DVI)
Hope this helps!
CreativeTECH
Nov 15, 2010 | Samsung Syncmaster 2033SW Monitor
I have an ASUS 1005 HA Seashell netbook,and i an
You need a DB15pin male VGA to DB15pin male VGA cable - you cannot use rgb with this netbook. This type of VGA cable is available on Amazon at a very good price and at many different lengths.
Mar 02, 2010 | ASUS Eee PC 1000HE Netbook
I have this monitor hooked to my PC ATI 7500 graphics card with a DVI cable. When the PC initially boots up, the monitor display is blank - it does not display the boot-up messages until the MS Windows...
This is normal. Your monitor has a VGA hook in for regular definition. What it is doing, the monitor always by default looks for the VGA hook first. On my desktop it does the same thing until it finds a signal on the DVI.
Dec 29, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Ghost images
Yes the images where left on the screen for a long period of time which burnt the images you see into the screen
Mar 10, 2009 | Samsung 2220WM-HAS Monitor
I love samsung yp k3
that mp3 has so many problems it is not even funny.
you should replace it with a ypp2!
Jan 23, 2009 | Samsung YP-K3 MP3 Player
Monitor dark only when display PC, normal TV
hi have you checked your PC output? check it with another screen (whichever) and see if the output signal is good if soo check the cable and connections to your LCD check your PC for software configuraitions: 1) TV output 2) good resoulotion 3) media borad is strong enough to handle this LCD if all is good then maybe the TV borad is sending a low voltage/current then the LCD can see good luck
May 01, 2006 | Samsung SyncMaster 1701MP (Silver) 17 in....
Samsung SyncMaster 540N 15" LCD Monitor Logo
46 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
