Question about Samsung Refrigerators
RF4287HARS is the model number.everything is working but I am getting a flashing 1 E on my panel. what do I do?
    Top Expert:
  • Samsung Master
  • 9,472 Answers
Take a look at this webpage.
Posted on Nov 07, 2012
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: I have a RF4287HARS -- the touch pad is flashing 1-E and nothing works but the light
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Posted on Oct 19, 2012
Ice buildup in bottom of freezer compartment
Here's a link to a great website that will help you understand what might be causing your freezer to have that ice build up. I could explain it here, but if you look at this link, they've already done a wonderful job.
http://www.appliance411.com/faq/defrostproblem.shtml
Jun 08, 2016 | Samsung RF4287HARS French Door...
Freezer freezes food, but why is ice cream melting?
Hi
It would be helpful for the model as some samsung models are single cooling and some twin cooling,please supply the model and i will be able to help.
Bryan
Dec 29, 2015 | Samsung French Door Refrigerator Right...
Model # RF4287HARS/XAA
No it's a whole assembly the plastic clip is broken. Give me a model number I'll track down the part for you.
Oct 05, 2015 | Samsung French Door Refrigerator Right...
A samsung fridge RF4287HARS has error codes 40E, 21E and 22E
Hello Jerry Fuller,
All your codes point to the same circuit pack.
Main Control Board ...DA41-00884a
PCB "CN76" low voltage condition... Low Voltage condition
(PCB = Printed circuit board)
CALL...
If you have any questions or comments relating to Samsung products,
55 STANDISH COURT MISSISSAUGA,
ONTARIO L5R 4B2 CANADA
Please contact the SAMSUNG customer care center.
SAMSUNG ELECTRONICS CANADA, INC.
TEL : 905-542-3535 FAX : 905-542-3835
1-800-SAMSUNG (7267864)
www.samsung.com/ca
owners manual
Samsung RF4287HARS User Manual
Service MANUAL (CODES on page 60)
Samsung RF4287HARS Service Manual
Feb 13, 2014 | Samsung RF4287HARS French Door...
We had a short power loss the other night and now the LED display panel has flashing I E, called Samsung they want to set up a service call. Is this serious and how can I get rid of this?
TURN POWER OFF AND UNPLUG UR OVEN..WAIT FOR A WHILE AND PLUG IT BACK IN AND SEE WHATS HAPPEND...MOST OF THE TIME ITS JUST A AUTOMATIC RESETTING INSIDE THE OVEN...
HOPE THIS WILL SOLVE THE PROBLEM..IF THE OVEN IS STILL UNDER WARRENTY..THEN GET SAMSUNG SERVICE AND GET IT FIXED...
Oct 18, 2013 | Samsung RF4287HARS French Door...
Samsung rf4287hars control panel blinking
This could be a temperature sensor problem. My RF265AABP model had a broken ice maker temperature sensor wire that caused it to read 88 88 with the last 8 blinking. See my detailed posts under this model for more info on diagnosing it.
Aug 11, 2013 | Samsung RF4287HA
Computer panel is not working and 1 E is flashing on the dark screen. The refrigerater and freezer are working.
Error is with your ice maker sensor. Unplug unit for 5 minutes and shut of your ice maker code should go away
Aug 10, 2013 | Samsung RF4287HARS Stainless Steel French...
Samsung DMT - 400 delicate light blinking
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Oct 18, 2012 | Samsung RF4287HARS French Door...
Refrigerators Logo
105 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
