Question about Marantz SR5006
No audio coming from 5.1 setup for new marantz SR5006.
I used the setup wizard and microphone to configure the speakers and calculate distances. All tested correctly, but I am getting no audio from any of my components. I've manually turned the volume up and down, and tried changing the surround sound settings to no avail. I must be missing a relatively simple setting, but I can't find it. Any help would be greatly appreciated.
5 Suggested Answers
SOURCE: I can not get surround mode on my Marantz 5200 receiver
Check surround mode on the on-screen menu of the amp
Posted on Feb 29, 2008
SOURCE: Marantz SR8500
Check the settings on your dvd player!. It might be set to PCM
instead of HDMI.
Posted on Mar 10, 2008
robotek
  • 1512 Answers
SOURCE: Marantz Surround SR7500 Receiver (don't know if anyone has this model)
Hi 3303k
Strange dramas you are having there. I would suggest first, that you switch the unit off overnight(unplug at the wall) to allow for a fulll hard reset. Then fire it up in the morning again, and see if it behaves itself. I found a user manual for you online here
It is a good amp that you have, and hopefully resetting it will sort it out for you. If not, please do get back to me here and we shall look deeper..
Thanks for using FixYa, a FixYa rating would be great for looking into this for you. Happy to help further :)
regards
robotek
Posted on May 08, 2008
  • 11800 Answers
SOURCE: Hello, I have recently purchased a
You don't get the OSD on the screen because either the HDMI cable for the TV isn't plugged in the OUT plug (the one on the right) or the tv isn't set on the correct AV source (it should be n HDMI1 - if you have plugged the cable correctly on the tv).
Posted on Aug 21, 2010
How do I connect the audio from a Panasonic to p50-s1 to a marantz nr1403 so that I get surround sound audio?
The Audyssey setup does not use any audio from the TV. Audyssey is started automatically when you plug in the calibration microphone. Once you start the setup, it will output a calibration tone to each speaker. (Read the Audyssey setup instructions.) There is 1 digital audio optical input on the back of the NR1403. You will need a optical digital cable for the connection. Once connected, you'll need to use the input setup menus to select that digital sound input to go with the video input you are watching. Check page 15 of the manual.
Jan 01, 2015 | Marantz Audio Players & Recorders
Reset Marantz sr5006 to factory settings
Hold the 'display' and 'zone select' buttons, then press power. Display should blink all segments. Let go of buttons, and your good to go
Jan 22, 2013 | Marantz Audio Players & Recorders
Won't log into pandora
http://us.marantz.com/DocumentMaster/us/PressReleases/PandoraProblem-M.pdf
Dec 01, 2012 | Marantz SR5006 AV Receiver with Networking...
I have a 5.1 surround sound system hooked up t a Marantz SR7400 receiver. All of the speakers work fine, but my Subwoofer, which is a M&K mx-105, doesn't have any sound coming out of it. It's silent...
hi,
try one thing
go to the setup of the Marantz and surf for speaker configuration. check the status of sub woofer is it ON or OFF ( YES or NO). if OFF(NO) make it ON(YES).
ok
Jan 27, 2011 | Audio Players & Recorders
No voice detect in microphone & speaker
  • Hi, these instructions will help you with the Audio problem. These are the steps to setup and 'restore' the Audio Drivers. Part (1) Click on the "Start" button, go to and click in the (right, pane) Control Panel. Scroll to find, "Hardware and Sound, select "Audio Devices and Sound Themes” click, “Playback” Next, click on the Active "Speakers.” Click “Configure” to "Audio channels" the (Speaker Setup) "wizard,” appear! Select (Test) click, Next! Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. “The (Advanced), “not recommended!” In the Controller Information (block), click on, Properties to "update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: “Click the "OK" to all change; 'Save,' and apply!” before exiting. “Rating the solution is appreciated, thanks”
Apr 24, 2010 | Compaq Creative Sound Blaster PCI 128...
We got a new computer and it comes with a built in webcam but when i try and use the cam on msn it wont work...it just goes all fuzzy. what can i do to fix it?
Configure a webcam can take the course, however, a series of simple manipulations can improve the performance of your equipment.
Launch the Configuration Wizard
Close your audio or video conversations.
Then, in the main MSN window, go to:
Tools> Adjustment of audio and video
Adjust the picture
Once the setup wizard started, let yourself be guided by it.
Select your webcam (its name should appear in the list) and click "Next."
A window appears and prompts you to set your webcam. Check the layout and image sharpness. If the image is fuzzy, adjust the lens of your camera until the image is sharp. Then click next.
Adjust the sound
Once the camera set, the wizard offers to adjust the sound. To do this, select your microphone in the selection, either the webcam or a microphone plugged into the microphone on your computer.
Then select the speaker output of your sound card to hear from your speakers.
The wizard will then adjust the volume of your microphone. To do this, move the cursor until the sound obtained is satisfactory. Then click "Finish". Configuring your webcam is complete.
Dec 30, 2009 | Toshiba Satellite A135-S2276 Notebook
Microphone socket no longer works(since new
These are steps to ‘setup’ and ‘restore the "Audio Drivers.” Part (1) Click on the "Start" button, go to, and click in the (right, pane), the Control Panel. “Scroll to find, "Ease of Access (or) Speech Recognition Options.” Next, select Replace sound with visual cues." In the See also: (Category), click, on “Audio Devices, and Sound Themes.” Click on the, 'Playback' button, select the 'Active' Speakers.” Select, Configure to: "Audio channels" The (Speaker Setup) "wizard,” appear! Select (Test) click, the “Next” button. Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). “Select 'Enhancements', "Apply" changes. “The (Advanced), “not recommended!” In, the (“Controller Information”) block, click on the, Properties to "update" Drivers. “Check to see if, Device usage: (enable) if not? “ Change it.” *Note: Click "OK" to all changes “Save and Apply!” “Did this solution help?”
Dec 19, 2009 | Toshiba Portege 4000 Notebook
Logitech QuickCam Express: Microphone not working
If you have windows messenger follow below
Windows XP
Windows Messenger is a native Instant Messenger application to Windows XP. This application can be used to set the output device of your choice. In turn, this information will carry over to the MSN Messenger 7.5 application settings.
Launch Windows Messenger and execute the audio tuning wizard.
  1. Go to “Start”.
    Select “Run”.
    Type “msmsgs” and click “OK”.
  2. In theWindows Messenger, click “Tools” and select “Audio Tuning Wizard”.
  3. Follow the steps which are provided by the “Audio Tuning Wizard” and select your desired Microphone & Speaker device.
  4. Once this process is complete, close the Windows Messenger application.
    The configuration change made through Windows Messenger should now be set in the MSN Messenger 7.5 application.
Mar 08, 2008 | Logitech QuickCam Express Web Camera
Marantz SR5006 Logo
216 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
