Question about Keurig Elite B40 Coffee Maker
Power on kuerig but no flashing cup lights - Keurig Elite B40 Coffee Maker
    New Friend:
Did you flip the top up that holds the k-cup and then back down again?
Posted on Dec 07, 2012
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: After I brew a cup
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Posted on Sep 04, 2011
Why kuerig vue will not brew complete cup
Sometimes Air gets trapped in the system.Unplug Maker, Remove Water Reservoir, Tip unit at about 45 degrees over the sink to partially drain. Place back on Counter, refill reservoir and replace on Maker. Plug it in and turn it on. make a couple of large cups of hot water then give it a try with coffee
Jul 27, 2014 | KUERIG Keurig Platinum B70 Brewing System
How to fix my kuerig it has water come through the kcup with out making a cup selection? and if it does once in awhile let me make a choice of cup size it gives me 1/4 cup then when I close it again i
The scope of electronics on that unit would need to be serviced by a authorized personnel . Take it back to the store for a refund, or purchase a new one. AC
Jun 09, 2014 | KUERIG Keurig Platinum B70 Brewing System
How do use that vinegar to the descale my kuerig machine
The BEST way that I found to fix my Kuerig after the dreaded DESCALE sign came up . Very simple and it works. All that you need is a STRAIGHTENED OUT PAPER CLIP
1..Unplug the machine
.2. Take off the water tank
.3. Lay the machine on its back
4.open the handle as if you were going to put a Kcup in
5. You will see a metal prong shaped like an arrow head . .Using a flash light makes it much easier to see There is a hole on each side of the metal prong
6.. Stick the paper clip in and out and rub it around for about 15 seconds Do that to each hole
. 7.. Up right the machine , put the water tank back on - fill with water and plug in . After it heats up , the problem should be solved. I brewed about 10 cups of plain water to try to clear out the debris . Then back to my COFFEE :)
Nov 10, 2013 | Braun Tassimo Coffee Maker
Kuerig keeps brewing without pushing button
my kuerig has water come through the k cup when I close the top without pushing brew cup size and if it does let me make a selection it brews 1/4 of cup I have descaled it 4 times locked in the water reservoir cleaned the needles turned it on and off any other suggestions to try would be greatly appreciated thank you
Nov 08, 2013 | Keurig Coffee Makers & Espresso Machines
My kuerig onecup won't turn on
Internal breaker has fractured and needs replacement.
Aug 26, 2012 | Keurig B60 One Cup Coffee Brewer
Cusinart coffee pot single serve with kuerig cups switch won't turn on
The problem is often that the machine develops a leak in the hose that is right over the transformer...the water drips onto the transformer and kills that... then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig One Cup Coffee Brewer will not turn on
heatman101
Sep 01, 2011 | Cuisinart Keurig B50 Single Cup Coffee...
My light won't go out and I descaled it then one light on the cups only lit up and it only gives a little water it's the kuerig i don't know the model
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 08, 2011 | Keurig B60 Coffee Maker
Keurig Elite B40 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
