Question about Panasonic SA-HE90 Receiver
I get a F70 displaying after playing radio for 5 minutes
After turning on the receiver it gives me an F70 problem then tells me to turn it off...it played for about 10 mins at first then plays for about a minutes now before giving me the same F70
SOURCE: DMR E55 won't read RAM Discs
clean the laser lens do no use a lens cleaner disc you need to dismantle the drive unit and clean lens with cotton bud and a isoproplyn solution also clean the disc turnble and clamp if possible get it done by somebody who knows what they are doing
Posted on Apr 20, 2007
  • 201 Answers
SOURCE: Music playing
If your phone does not have a dedicated Music button it is usually the HOLD button. Try the hold button first (with the phone hung up) if that does not work look for a button labeled music or possibly a soft key (key's labeled by an LCD display)
Posted on Aug 29, 2007
SOURCE: CD player that doesn't play
I had the same problem.
I cut the orange wire which went into the black connecter block
and WOW I had sound...
brilliant
thanks a lot
Andy - North Yorkshire, England
Posted on Feb 24, 2009
cnavarro
  • 2460 Answers
SOURCE: Panasonic KX-T7730-when receiver on hook plays on hold music
walk up to the phone and without touching anything else, press "1".
No music.
Carl
Posted on Jun 26, 2009
jdvillanueva
  • 2098 Answers
SOURCE: The song is playing and running suddenly the song
Hi ahamedfaisal,
Does F61 appear after a minute of playing or shuts down immediately after you power on the unit?
Jdvillanueva
Posted on Mar 16, 2011
Its showing F70 error on display. Only workd on DVD mode, when i turn it on any other mode it just shows F70, switch power off. All fuses are ok, no any visibly damaged components
The fuse is a part of the problem it is for safety measures
the problem is in between the power supply regulators, capacitors and power amplifier circuit board.
usually a regulator or an output transistor can cause this error.
hope this helps.
Aug 08, 2014 | Panasonic SA-HE70 Receiver
What does f70 overloads means
Sounds like either an amp problem or a fan problem. Either one can send a F70 code. Check and see if the rear fan is turning freely, it might just be dirty and can't spin easy
Sep 22, 2013 | Panasonic SA-HE70 Receiver
How to unlock my stereo
if you get to step 4 email the code to me at jtisdale23@comcast.net
gmlogoflat.gif Service Information
bhome.gifbpublication.gifbnumsrchbutton.gifbnews.gifymkbutton.giffeedback.gifbhelp.gif
1999 Chevrolet Chevy K Pickup - 4WD ' Escalade, Pickup Classic, Suburban, Tahoe, Yukon VIN C/K Service Manual ' Document ID: 522597 Radio Displays LOC, LOCKED, or CODE Step
Action
Value(s)
Yes
No
  1. Turn the ignition off.
  2. Disconnect the negative battery cable for 1 minute.
  3. Reconnect the battery cable.
  4. Turn the ignition to run.
  5. Turn the radio on.
Does radio now operate?
Go to Step 2
Important: It will say Theftlock® on the face of the radio.
Does the Radio have Theftlock?
Go to Step 3
Is it possible to get the security code from the customer?
Go to Radio/Audio System Operation
Go to Step 4
  1. Turn the ignition on.
  2. Turn the radio off.
  3. Depress and hold Pre-set buttons 2 and 3.
  4. Write down the first three digits that appear on the radio display.
  5. Depress AM/FM, write down the second three digits that appear on the radio display.
Did you receive the 6 digit Radio Display Code?
Go to Step 5
Send Radio in for repair
5
Contact Delco Assistance to obtain a "Radio Back-up Code".
Go to Step 6
6
  1. Use the hours and minutes buttons on the radio and install the 4 digit "Radio Back-up Code".
  2. Depress the AM/FM button.
  3. "SEC" should display.
Did the radio unlock?
Go to Step 7
Repeat Step 6
7
Important: This will remove the original owner's code. The owner will then be able to reinstall their own personal security code.
Step 6 only unlocked the radio, if the original code is not known, repeat step 6.
Did the radio display?
Repeat Step 7
Jul 29, 2011 | 1999 Chevrolet K1500
How do i program the radio to only give audio alerts for the county in whitch i reside? (sarpy county in nebraska
1. Turn switch on side of radio to "ON".
2. Press "MENU".
3. Press "UP" arrow until "CHANNEL" is displayed.
4. Press "SELECT".
5. Press "UP" arrow until you hear the broadcast of your station.
6. Press "SELECT" to save station selection.
7. Press "MENU" to close menu mode.
To turn Weather/Hazard broadcast on again, press "WEATHER/SNOOZE".
Note you will hear only static on the channels not received in your area.
(FYI - channels are listed 1-7 on the left, and corresponding frequency numbers are displayed on the right side of display.)
At This Point You Will Receive Weather And Hazard Alerts Issued By The NWS.
Dec 24, 2010 | Midland WR-100 Weather/RDS Radio
When i turn on the receiver it immediately gives me a ¨F70¨ error message on the display
hi there,
This is a problem related to the out put section, try disconnecting alls the speakers from the receiver and turning on the unit. If your unit comes on then mostly any of your speaker or associated cabling is getting shorted . If the same problem persists then usually the amplifier needs service attention, refer to a qualified engineer.
Aug 04, 2010 | Technics SA-DX1050 Receiver
Aquiring Signal displays for 5-10 minutes before hearing audio
It's a bad Sirius tuner. You can find them on ebay for 50 or so rebuilt and they are better than new. It's cold solder joints on the antenna input plug. Hope this helps
Jun 17, 2010 | JVC KT-SR2000 SIRIUS Radio Receiver with...
F70 displays after about 5 min of use.
According to Technics reference manual, turn the unit off, unplug for a few, plug in, turn unit on. Consult your "dealer"(authorized repair person, i guess) if light remains on. But doesn't say what f70 means, or associated with.
Unplug and open up the unit, and check the internal fuses on the circuit board. Also check for proper speaker wire hook up. Re-seat the connections. Visibly check the speaker wire runs for shorts, cracked casing, cat/dog chewing. etc.
Hope this helps.
Apr 28, 2010 | Technics SA-DX750 Receiver
Panasonic SA-HE100 5.1 system error code F70
According to the operating instructions, you must take it to a repair facility. There are no troubleshooting suggestions for this problem in the manual.
Dec 15, 2007 | Panasonic SA-HE100 Receiver
Could anybody tell me what F70 means ?
You must have air flow through this unit!...accordianman
Dec 04, 2007 | Technics SA-DX850 Receiver
What is F70???
F70 means Blown Internal Fuse change the internal fuse and that should solve the problem if not you may have to change the output
Oct 30, 2007 | Technics SA-DX750 Receiver
Panasonic SA-HE90 Receiver Logo
21 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
