Question about Samsung LN40A450 LCD TV
SAMSUNG 46" LCD : How do you determine which board is bad? I know what I'm looking at and for. I'm not seeing any bulging bulbs / bad caps / burnt or blown areas on the board. Which board do I re-order?
  • Samsung Master
  • 1,684 Answers
Hello Jon,
Before you start ordering and swapping parts check with Samsung, that model is covered under the terms of the class action lawsuit settlement over bad power supply boards. The power supply boards cause the exact symptoms that you are having. They should repair the unit free of charge for parts and labor. Here is additional information on the settlement along with contact information.
http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Posted on Nov 07, 2012
  • 192 Answers
SOURCE: LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Posted on Jun 03, 2007
  • 2318 Answers
SOURCE: LN-T4061f samsung lcd no backlight, no sound, no picture
Replacing the capacitors would be a good start. Replace all the ones with the same capacitance and voltage rating even if they do not look bulge.
Let me know if you require further assistance.
Posted on Mar 14, 2009
Shuttle83
  • 1139 Answers
SOURCE: audios fine but picture is black
Hello taasmost9, This problem indicates an issue with the inverter which operates the backlight. It appears that your inverter is malfunctioning. If you have a background in electronics, it is possible for you to repair this yourself if not you will do more damage then good so I would like to suggest that if you do not have a background in electronics that you have a qualified TV technician work on and repair this problem. If you do have a background in electronics you will need to measure the voltages at the inverter and determine that power id present at the inverter's input and at the output to the backlight. You will need a schematic and a multimeter for this task. After finding the component you have a choice of replacing the component or replacing the entire inverter module (this is up to you depending on the cost of each procedure). I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 14, 2009
  • 608 Answers
SOURCE: Samsung 46" LCD LN46B650 started showing vertical
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Posted on Dec 10, 2010
eagle338
  • 4889 Answers
SOURCE: I have a 46" Samsung LNT4661FX / XAA LCD TV. My
The 6V difference would matter depending on the location of the capacitor. If there is no voltage regulator circuit and if its in the circuit that goes into the main A/V board then I would thing that it has damaged if not fried some components into the A/V circuit. If you can get me a picture of the circuit where the caps are I can have a look and tell you if its due to that.
Posted on Jan 20, 2011
The TV won't turn on. The red on/off light is flashing red.
bad bulb most likely, cheap fix. look up tv model on amazon or ebay. bulb replacement should come out on search.
Dec 02, 2015 | Sony QUALIA 005 46 in. LCD Television
Samsung 46 LED get sound no picture
it sounds like your back light inverter has gone. if its a led it could be built in on the power board. so check for bulging or leaking capacitors on the power board.
Jun 24, 2014 | Samsung LN-T4665F 46 in. LCD Television
Describe your LN-T4671F 46 in. LCD Television Problem When I turn the power on, the TV clicks on and off several times before it finally powers up and the screen comes on. Is this a common problem, and if...
Good day!! That problem is usually cause of bad/faulty capacitors on the power supply board..So you have a better chances and easily locating the faulty capacitors if it is look like leak/bulged on the top.. So please try to follow this instruction on how to do that.. 1. Open the back cover of your TV. 2. Look at the power supply board..Its normally connected to the power cord.. 3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors.. 4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value.. 5. Some of the capacitors not bulged so its better if have a capacitance meter.. Hope it helps you..
Sep 13, 2011 | Samsung LN-T4671F 46 in. LCD Television
My tv keeps turning off by itself
Good day to you!!!
that problem have 2 causes its either power supply or main board..
let us see...
if you have multimeter that's better if none just look at the capacitors if bulged on the top..if bulged please replaced with the same value..
watch this videos to give some idea:
if you don't have bad caps there is a big possibility that your main board is bad..
if the main board is bad you only have to do is to order the new board and install it..
Thanks for using fixya,,...
please don't for get to rate my answer if help...
Aug 06, 2011 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
I hear sound no picture
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
Failed SAMSUNG's; http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Jun 25, 2011 | Samsung LN-T4665F 46 in. LCD Television
I have a sumsung LA40M81BD lcd tv simple problem the tv is always clicking on and off and wont show anything on it. you have to switch it off from the switch on the wall.
Good day!
you have a better chances if you have failing capacitors on the power supply board.
How can you find it?
Just look the actually image of it and see if it is look like leak or bulged on the top.
If you found replaced it with the same type,ratings and value.
Thank you and don't forget to rate my answer.
May 29, 2011 | Samsung LN-S4692D 46 in. LCD HDTV
WhenI turn on my Samsung LE46N8 there is a clicking noise for approx 20secs. before the picture comes up. Once started there are shadows obscuring the picture which last for approx 10 - 15 mins then once...
You likely have a power supply problem. If you can take the back off of the set and trace the AC cord to the power supply look for bulged capacitors on the board. Capacitors are cylinder shaped components standing upright and the bad one will have a bulge or domed at their top instead of flat. If you see any this way you could replace them by soldering in some with equal value of microfarads and voltage or match the part number on ebay (Model search on ebay) and replace the whole module if you can't solder. The module unscrews and unplugs.
May 20, 2011 | Samsung LN-S4692D 46 in. LCD HDTV
My TV constantl clicks on and off. Meaning the blue light comes on and goes off and the TV never boots up all the way to come on to watch TV?
I am having the same issue with mine, I do know that it is either the backlight inverter board that is bad or the power supply board. In my research and repairing tv's I have come to find out more than likely it is the power supply board. Try and take apart the back of the tv and see if you can see anything noticeable that is wrong, such as the norm of bulging capacitors. Usually its a great first step in repairing your own ps board.
Jan 10, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
Samsung LNT4661FX/XAA 46 in. HDTV LCD Television - When tv is turned on it makes a clicking noise for about 15-16 clicks. Progressively worse. Finally comes on
Capacitors are bad on the power supply board, they will probably looked bulged at the top. I've enclosed an example.
Jan 02, 2011 | Samsung Televison & Video
Samsung flat panel tv cuts off - requires a restart every 20 minutes or so
Most likely you have bulged capacitors on the power supply board. If your handy with a soldering iron it will probably cost you about $10.00 in parts. If the caps are bulged, you will know by the tops of them will be bulged.
Dec 21, 2010 | Samsung LN46B550 46 in. LCD HDTV
Samsung LN40A450 LCD TV Logo
159 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
