Question about HP "officejet 4500 all-in-one inkjet printer"
Every time I try to print any document, the printer will take in the first page, pause then spit the page out blank. It will then pull in a second page and stops halfway through the feed process, never to finish the printing process.
    Master:
  • 545 Answers
Your best bet would be to uninstall the printer, then shut down, and then reinstall with the most up to date drivers. Pay attention to the model you select, as it is important that it matches the driver.
Posted on Nov 08, 2012
3 Suggested Answers
SOURCE: To send a fax, does the print page face up or
It goes face down in that machine....here's a tip...if you open the cover and look underneath, you will see the scanner section (narrow glass, with a lamp or LED underneath). This is obviously what "looks" at the page as it is scanned. You will see nothing like that on the top section (or cover section).
Posted on Jun 15, 2009
SOURCE: hp 1040 ran out of paper/after restocking now prints blank pages
Even though the toner was shown at 1/2, I had the fax machine operator install a new cartridge. Problem solved!
Posted on Aug 25, 2009
I have a hp 1320 laseret printer.when I order to print. this printer prints two pages. I could not solve this problem. would you please help me?
What document you are trying to print?
If it is Excel or Word document you have created a second blank page, reopen the document and delete the second empty page.
Nov 17, 2014 | HP LaserJet 1320 Printer
I have just bought a Xerox Phaser 6500. Prior to this I had a phaser 6125. The problem im having happened with both printers which makes me think somewhere along the line my settings are wrong. If I...
You may have the "separator page" option turned on in your print driver. This option will insert a blank page after each print job to separate one print job from another. Simply uncheck the box by the separator page option and you should be back to normal !
Oct 21, 2013 | Xerox Phaser Office Equipment & Supplies
Prints blank page
Have you checked the print que
Printer problems can be a real hassle.
From time to time, due to document layout or settings on your computer, in your software of choice, or even on your printer, a blank page may get "printed" with the rest of your document.
Fortunately, this issue is a simple one to troubleshoot.
Click "Print Preview" when you are finished with your document and ready to print.
Observe your document.
If you see an extra, blank page, you have created a second page.
To delete the second page, close Print Preview, go back into the document and eliminate any blank lines in your documents that you may not need.
You may also find an inadvertent page break at the end of your document.
Place your cursor on its symbol and delete it.
Locate the symbol by clicking on the Show Formatting paragraph icon in the toolbar.
Circumvent this "ghost page" if you do not see a second (or additional) blank page in Print Preview.
Specify the number of pages you wish to print, within the Print dialogue box.
This is typically done by selecting the "Print From" option, then entering the page numbers desired.
If your document happens to be ten pages (without, of course, that final blank page), then enter in the "Print From" field the numbers "1-10".
This will print only pages 1 through 10, without an eleventh (blank) page.
Jul 11, 2013 | HP Deskjet 5940 Photo InkJet Printer
Prints blank page first then freezes on the second page.
Blank or partial page printed
1. Clean the ink cartridge. (a) Complete the ink cartridge cleaning procedure.
2. Check the media settings. (a) Make sure you select the correct print quality settings in the printer driver for the media loaded in the trays. (b) Make sure the page settings in the printer driver match the page size of media loaded in the tray.
3. There is a blank page in the file. (a) Check the file to make sure there is no blank page. Something on the page is missing or incorrect (b) Check the margin settings Make sure the margin settings for the document do not exceed the printable area of the device.
4. Check the color print settings. (a) Make sure Print in Grayscale is not selected in the print driver.
5. Check the device location and length of USB cable. (a) High electromagnetic fields (such as those generated by USB cables) can sometimes cause slight distortions to printouts. (b) Move the device away from the source of the electromagnetic fields. (c) Also, it is recommended that you use a USB cable that is less than 3 meters (9.8 feet) long to minimize the effects of these electromagnetic fields.
6. Check the ink cartridges. (a) Make sure the correct ink cartridges are installed and the ink cartridges are not low on ink.
Dec 20, 2017 | HP Officejet 4500 All-in-One -...
Printer has started spitting out one clean page for every page that is being printed. That is, if I have a two-page document to be printed, it spits out four pages, two pages without anything on them, and...
Go to START, Printer & Faxes, right click your printer and select properties. Under the advanced tab, click seperator page, delete whatever is in the box and click OK. This should stop the blank pages from printing.
Hope this helps
-samson39
Jul 26, 2009 | HP Photosmart C7280 Printer
Prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
Mar 17, 2008 | HP Photosmart 2710 All-In-One InkJet...
Printing Blank Sheets
What document you sending? word ?
does demo and conf page come out from printer OK ?
Try installing drivers again
Sep 26, 2006 | Konica Minolta magicolor 5430 DL Laser...
HP "officejet 4500 all-in-one inkjet printer" Logo
62 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
