Question about Philips MWD2205 DVD Player/VCR
How to set the clock on the magnovox 2205 dvd/vcr combo
    Top Expert:
  • Philips Master
  • 14,553 Answers
Consult the owner manual or if lost Google the model number with "manual" to try to locate it---last resort call philips with the model number as I bet they are because of the time change getting a lot of calls for help.
Posted on Nov 07, 2012
jpc1994
  • 35 Answers
SOURCE: code for magnavox vcr/dvd player
I am going to assume you are talking about a code for a universal remote control.
It could be one of these:
434 934
The website with the most codes I have seen is http://dogbytecomputer.com/codes.htm#DVD CODES
Posted on Aug 13, 2008
WhIzAtIt
  • 136 Answers
SOURCE: Philips MRV700VR DVD Recorder / VCR Combo
Crack the top open and look inside for any foreign matter. Usually the cause is debris in the IR path that detects start and end of tape or the loading mechanisim is faulty.
Posted on Sep 24, 2008
  • 3 Answers
SOURCE: how to set the clock on vcr/dvd.
Make sure the antenna//cable TV connections are correct. Channels are set. If this unit is connected to a cable/satellite box, select the local PBS station on them to set the clock automatically.
There's an Auto Clock Setting. "This Unit can set the time and date automatically by reffering to a PBS station.". But I never had to do that, I just went to Setup and it already knew what the date and time was.
"Note: The clock may set itself automatically after you connect the antenna/cable signal and plug in the power cord. Only the analog PBS channel signal is effective for auto clock setting. The unit receives the clock data at 12:00 A.M./P.M. from the PBS channel when the power is off.
1 Press [SETUP] and use the up and down arrows to select "General Setting", then press OK.
"General Setting" menu will appear.
2. Use up and down arrows to select "Clock" then press OK.
"Clock" menu will appear.
3. Use up and down arrows to select "Auto Clock Setting", then press OK.
4. Use up and down arrows to select "Auto" then press OK.
5 Press SETUP to exit.
6. Press STANDBY-ON to turn off the unit.
This unit will search for the time only when the power is off. Leave it off for several minutes to give this unit time to set the clock.
If the unit chooses an incorrect PBS channel, set the PBS channel manually by following the steps below:
1. Select "Manual" at step 4, then press OK.
2. Use [the number buttons] or up and down arrows to enter your PBS channel number, then press OK.
3. Press SETUP and turn off the unit.
If this doesn't work, let me know and I'll type up the instructions for what to do if you need to actually set the clock manually.
Mathis...
Posted on Feb 19, 2009
SOURCE: dvd/vcr magnovox mod dv220mw9 has serious apparent tracking probl
how can i hook up magnavox vcr dvd player to whitehouse tv using warner cable connection only.
Posted on Mar 22, 2009
ltfrc
  • 227 Answers
SOURCE: Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Posted on Jul 25, 2009
I have a 2004 sansui 13 in screen tv vcr combo no manual. How do you program the vcr to record?
MAIN MENU ON THE COMBO ,,UNDER SETUP ,,SET UR CLOCK ,,AND YOU SHOULD FIND IT ALL THERE
May 15, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Little leaps
I need the code for an Apex DVD player
Jan 16, 2009 | LeapFrog Little Leaps Grow With Me...
Change clock
how do I change the time on my sansui vrdvd4000 dvd player / vcr combo
Nov 06, 2008 | Sansui VRDVD4000 DVD Player/VCR
I cannot reset the clock on my Toshiba 392 DVD and VCR combo
If I remember you will only get the System Setup if the unit is set to DVD only it will not allow this in VCR mode I will need to double check and get back with you
Sep 26, 2008 | Televison & Video
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Setting the clock
Use an Aiwa Hifi Remote Control...Turn on the L300 (without any DVD on the player). Wait until in the TV appears "No Disc" Open the tray and put a DVD from other region (not zone 1), don't close the tray!!!. On the remote control of the Aiwa press the "Clock" button, in some remote control you must do a button combination like "Shift+9" (Is the combination to see the clock, do the combination fast), and in other model of Aiwa remote control doesn't appear the clock button, you must try with the "random" button. If you do it right, in the corner of TV where "No Disc" appears it will say "adjust complete".
Jun 15, 2008 | Sansui VRDVD4005 DVD Player/VCR
I have a Magnovox tv/vcr combo that I am trying to use the antenna on but it will only let me switch back and forth between Aux or channel 3. I do not have the remote. Is that my problem? Will a universal...
Yes a universal control should solve your problem but I would try to connect my tv to my vcr or dvd and my antenna to my vcr or dvd as well then change your channels thru your vcr or dvd!
Mar 28, 2008 | Televison & Video
Tv Codes
Information for:
Magnavox TV/DVD combo - 0247
Pioneer TV - 0120, 0719, 0808, 0002, 0502, 0610, 0519
if this fails, try 7300 or 0073; do you have cable or sat box?
if this fails, try 0711
-Tha Mp3 Doctor
Jan 03, 2008 | Philips PM435S Remote Control
Magnavox dvd vcr combo
YES..............All of these Magnavox TV/VCR combo units have fusses in them. Be aware of the fact that some of these fuses...do NOT look like fuses. THey're small round BLACK parts which have an F on top of them. They are SOLDERED to the PC board.
I'm very familiar with these fuses. BERNIE
Nov 09, 2007 | Philips 20DV6942 20 in. TV/DVD Combo
Philips MWD2205 DVD Player/VCR Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
