liftmaster 371 Remote Transmitter  Logo
Mary Posted on Nov 07, 2012
How to program spare Chamberlain 953CD remote
If I buy a second Chamberlain 953CD remote, how do I program it to open my garage
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Nov 07, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
Helped
10388
Points
45
  • 1Enter your garage with your remote, and press and release the "Smart" button on the side of your garage motor unit. This button is located near the antenna wire and light lens.
  • 2Wait for the LED light on the motor to start flashing, and press and hold the button you would like to program on your remote opener.
  • 3Hold the button for up to 30 seconds until the main light on the motor unit flashes twice.
  • 4Release the button on your remote and wait 30 seconds for the LED light to stop flashing, which indicates the end of the programming sequence.
    • Mary Nov 07, 2012
      Thank you very much for your help.
    1 Related Answer
    swolfinor
    STEVE WOLFINBARGER
    • 504 Answers
    • Posted on May 26, 2010
    SOURCE: need to re-program a remote, battery needed to be
    THERE IS A SQUARE BUTTON ON THE END OF THE UNIT. PUSH AND RELEASE THEN PUSH AND HOLD THE REMOTE BUTTON FOR ABOUT 20 SECONDS. THE NEXT TIME YOU PUSH THE REMOTE THE DOOR SHOULD GO.
    HOPE THIS HELPS
    Can I use a chamberlain remote with a genie pro garage opener
    you can try to see if it works but probably no- get anather genie remote
    Garage door opener Chamberlain - programming problems
    I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
    - it tooks me 20 minutes and works great
    Have a chamberlain garage door opener that doesnt allow any of our remotes work the main button inside door works service man says we need a receiver 953cd cant find one does this make sense
    open the back of the remote and see what the "dip" switches are mark...1-4 are settings maybe more and make sure the settings for the opener in the rear of it are set on the same configuration. Hope this fixes the problem.
    I have a 955cd hooked up to an old opener with a 953cd opener that works just fine just bought another opener yesterday a 950cb can not get it to program.
    Press and release the learn button and then press the button on the remote. If this does not work press and hold the learn button and as you are pressing it press the button on the remote. Thanks BB
    I have a chamberlain 953CD New will it work for a Lift-master ?
    You may need a C943 as the + can make the siginal different.[Chambelain or Merlin]
    How do I open the 953cd remote to change battery?
    You will find the instructions on this web site.
    http://skylinkremotesonline.com/files/953D.pdf
    Where to buy remote control and reset My garage door opener also
    To erase the memory of the opener so that your old remote will no longer work you need to locate the smart/learn button on the rear of the motor unit. Press and hold this button for 6 seconds. No remotes will now work.
    To program the new remote when you get it, hold the button down on the remote and then press and immediately release the smart/learn button.
    Call any local door opener repair company from the yellow pages and you should be able to buy a remote from them.
    1helpful
    2answers
    8helpful
    3answers
    Chamberlain garage door opener unit-is it compatible with craftsman keypad?
    Hello,Linda well this is your lucky day ,I have installed garage door openers for sears for 10 years and i can tell you that craftsman,chamberlain ,and liftmaster are all the same machine and manufactured under the liftmaster name , if you buy it from home depot it will be a chamberlain ,if you buy it at sears ,it will be a craftsman, and if you go to commercial building supplier it will be a liftmaster! now getting that out of the way even though they are all compatible ,there is one thing that stands in their way and that,s time ,For example if your chamberlain machine is 5 years old and you went to sears last week ,the chances of the frequency being the same are not good , most likely you have the wireless keypad , one way to test the sears keypad against the chamberlain machine is to locate the smart button on your machine ,this button allows for programming of remotes and keypads , to test and see exactly what im talking about take your remote and locate the smart button ,if you have three buttons on the remote press one of the buttons that are not being used on the remote ,above the smart button their will be a blinking light ,if you press your remote button you will notice the light go from a blink to a rapid flash , This is telling you that you are sending a signal for programming to the machine , well the keypad is exactly the same all you have to do is push the enter button on the keypad and have someone watch for the rapid blinking light ,if they are compatible the light will blink rapidly on the machine so all you have to do now is have someone press the smart button once on the machine your indicator light will now be a solid light you will have approx 60 seconds then to put a 4 digit code in the keypad and then press and hold down the enter button on the keypad , at this point you will notice the lightbulbs on the chamberlain machine to shut off and come back on this is to tell you that the machine accepted the code , after thats been done you can use your keypad , you can also find the owners manual to the chamberlain and follow the same instructions to programming the remote , they are identical in programing , if your keypad is not the same frequency you can also tell by looking at the frequency code on the backside of the keypad and also the chamberlain unit usually where the light bulb is will be its code
    Top liftmaster Home Security Experts
    ADMIN Eric
    ADMIN Eric
    ADMIN Andrew
    ADMIN Andrew
    Are you a liftmaster Home Security Expert? Answer questions, earn points and help others
