Question about Kenmore White Electric Stove
Oven problem not turn on - Kenmore White Electric Stove
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 07, 2012
Maytag gas range oven wont cycle
it could be the thermocouple . or thermostat .
Feb 09, 2016 | Maytag 30" Free Standing Gas Range -...
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
How to turn oven on on a Kelvinator Cookarama Oven (Older model)?
You need to hold /push the oven control knob in quite firmly while you press the igniter. When it lights up keep holding for about ten seconds then gently release it.
Jun 02, 2014 | Kelvinator Refrigerators
HOW TO CALIBRATE OVEN TEMPERATURE INDICATOR AND THE OVEN TEMPERATURE ON THERMADOR PRD304EG RANGE
If you remove the knob, you will see the very center of the male part the know attaches to has a small flat head screw in the middle of it. Buy turning this screw in and out, you are micro adjusting the temp when the oven cycles on and off. Its best to have a digital thermometer set up within the oven so you can see exactly when the oven cycles on and off. It's going to fluctuate about 20-30 degrees. So set your oven to 350, let it turn on and watch carefully when the red light shuts off it should be between within 30 degrees from where you set it, up or down. If its too low,turn in( could be out, I forgot) the screw in the center of that know with a mini flat head screw driver. If you turn it and the light goes back on, you turned it up. If it does not go on in an quarter turn, you went lower. Once your digital thermometer matches up closely whith what your oven says, your good. 25 degrees isn't much to be gentile whith turning that middle screw, you could miss your mark and be off even more very easealy.
May 16, 2014 | Thermador PRD304EG 30in Pro Grand...
Fisher & Paykel Thyme main oven not working
You could try reseting the clock to the manual position.
If in Automatic the oven won't turn on until set time.
Mar 18, 2013 | GE JB870 30" Free-Standing Electric Double...
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
Oven willnot turn on....broiler works
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 07, 2010 | GE Profile JGP636 Gas Cooktop
Gas oven knobs seizing when oven hot
hi my name is mark, yes most manual gas valves can be disassembled and lubed. you will need gas valve grease. remember a little goes a long way and shut off the gas to the unit before disassembly.
Feb 21, 2009 | Cooktops
Kenmore White Electric Stove Logo
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
