Not recognice by usb hard - Computers & Internet
  • Will Godwine Nov 07, 2012
    USB hard drive does not respond in windows?When you plug it in, does the drive make any noises?Or can you feel the drive vibrate in your hand?Is there DATA on the drive, that you'd need?I might be able to help, just need more information.
  • 27,725 Answers
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Posted on Nov 08, 2012
Usb devices is malfunctioed and window does not recognice it
Try this USB device in another computer to see if it works, if so then backup the data off this USB device.
Next try reinstalling the USB driver in your laptop.
Apr 17, 2012 | Computers & Internet
DRIVE NOT RECOGNICE
test all leads from motherboard to hard drive ide/sata including electrical extensions make sure all are securely seated with no dust built up also make sure the ram modules are securely seated with no dust in the sockets and test cd/dvd usb and floppy are all working a computer needs all current and data to travel to and through every working devive and to have an end to work properly even somethig as small as a faulty fan can cause this problem
hope this helps you
Aug 06, 2011 | Computers & Internet
I have dropped my Packard bell 2,5" silver 320 GB
Hard drives are sensitive. The accident that happened was the reason why your hard drive is acting like that as of this moment. You cannot do anything for that anymore. But, I can suggest that you buy a new hard drive which is shock or drop resistant. There are hard drives which have that kind of functionality. It's not easily damaged even if it's dropped.
Mar 22, 2011 | Computers & Internet
My laptop dose not recognice my mouce...... it says device unknown.......... the mouse works on any other system......... i have a 64 bit vista .... what do i do
Check whether you are having the USB controllers installed correctly or not. To check this navigate to device manager and in that check for the USB controllers , then right click the USB controllers and then uninstall them , then goto "Action" Tab and perform "Scan for Hardware Changes" then the USB controllers are installed properly.
Oct 21, 2009 | KEIO PS2 Optical Scroll Mouse
Error code 16
Code 16 is a hardware or firmware failure you need to Surf a little and reveiw the home page. Hold on ill get the address to take you too the solution
http://www.simpletech.com/support/support_downloads.php
This may resolve the problem and grant you access to your HD
Oct 18, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
My computer dose not recognice my usb cable for my ipod
make sure u make a 2.0 usb cable. also plug the usb cable at the back of your computer not in the front usb. try again
Aug 14, 2009 | Apple iPod MA446LL/A MP3 Player
Dell laptop mic problem
hi.  please follow this steps> control panel>sound and audio> sound> troubleshoot> it will follow the steps .. it will recognice the whether mic is in working condition or not.. if it did not recognice there is problem in the mic . u need to replace it..  if any assist i am there to solve .. thank u..
Sep 13, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
258 people viewed this question
David Payne
David Payne
