Question about Brother OEM Brother OP4CL OPC Drum Belt Unit W/B Transfer Belt, Drum Unit (oop4cl) for HL-2700CN MFC-9420CN
OPC Belt reset
Can I reset
  • Brother Master
  • 783 Answers
Sir/Madam
I suggest You watch official video In Brother Printer Official Website For Your Brother Printer Issues:
How do replace thebelt unit With Video Instruction Brother
I Hope You Resolve Your Brother Printer Issue and Brother Printer Problem By Now,
Or
In case You still need Brother Printer Help assistance Then I suggest You Follow Us On For:
Brother Printer Support
Posted on Feb 14, 2014
I just install a new opc belt in a xante colourlaser 1200 printer, it still say install opc belt.
You probably need to go into the menu structure and find the resets menu. It could be under machine info or maintenance. When you have found the reset menu or parts life, you should be able to reset the OPC Belt.
Jan 11, 2015 | Xante Office Equipment & Supplies
How do I reset the OPC belt on MFC-9420CN using the menu?
hl-2700" OPC Reset
press GO and "+" at same time
press "+" until OPC BELT appears
press "SET"
that will reset the counter on the expensive OPC.
Since the "MFC-9420CN" is build on the same chassis and engine, the "OPC belt reset for the 9420CN" is as follows:
Press 1 and 7 at the same time
Press 1 to reset the life counter.
Oct 20, 2010 | Brother MFC-9420CN All-In-One Laser...
Reset replace OPC belt
Here's the link on how to replace the Photodeveloper Cartridge on the Lexmark X500/X502: http://bit.ly/bzQQtH.
Here's the link on how to reset the photodeveloper (OPC) count on the X500/X502: http://bit.ly/9BxHqz.
Hope this helps.
May 25, 2010 | Lexmark X502N All-In-One Laser Printer
OPC belt is replaced and has 100% life but the OPC
make sure all components are properly seated. also try turning the printer off and waiting a few minutes and turn back on.
Aug 19, 2009 | Brother MFC-9420CN All-In-One Laser...
Replace belt CG
Set Belt CG The OPC belt cartridge needs replacement.
Replacing the Optical Photoconductor (OPC)
Belt Cartridge
Replace the OPC belt cartridge at least once every 12 months, or when
the control panel display indicates that replacement is necessary. The life
of the OPC belt cartridge for the T8106 is about 60,000 images (15,000
color pages), at a 5% toner coverage rate on letter-size paper.
1. Turn the power switch off.
2. Unlock the lever to open the front
cover. This releases the pressure on the
toner cartridges.
3. Unlock the lever to open the top cover
fully.
4. Pull the green OPC belt cartridge lock
levers up until they unlock.
5. Pull the used OPC belt cartridge
upward and out of the printer carefully
to avoid spilling toner.
6. Discard the used OPC belt cartridge
Caution! Do not touch or wipe off any powder that is on the OPC belt, nor expose
the OPC belt to light.
7. Remove the two shipping pins from the
new OPC belt cartridge.
8. Remove the protective sheet that covers
the photosensitive belt.
9. Slide the new OPC belt cartridge downward
into both green lock-lever guides
and into the printer carefully.
10. Push the green OPC belt cartridge lock
levers down until they lock.
11. Close the top and front covers carefully
until they both lock.
May 28, 2009 | Tally T8106 Laser Printer
OPC Belt needs replacing
Try pressing 1 and 7 at the same time
The LCD will show "OPC belt 1. Reset 2. Exit
Select 1 to reset the life counter.
This is supposed to be done when replacing the drum unit...but I've found that I can get 1.5 to 2 lifespans from a single unit.
Jan 31, 2009 | Brother MFC-9420CN All-In-One Laser...
NO OPC BELT on MFC-9420cn
The opc sensor is not sensing the belt. Open the front cover and remove all the toner trays. You will see the green OPC and the sensor is located in the left upper corner. Also open the top cover and remove the OPC. Clean the sensor with a soft bristle brush. Also make sure the OPC left side is free of toner deposits. This may incorrectly trigger the OPC position sensor. Hope this helps.
Jan 14, 2009 | Brother MFC-9420CN All-In-One Laser...
MFC-9420 Replace OPC Belt message stays on after replacing belt
As far as the OPC belt - don't replace it until you start seeing ghosts and image defects! Reset it by:
Dec 06, 2007 | Brother MFC-9420CN All-In-One Laser...
Brother OEM Brother OP4CL OPC Drum Belt Unit W/B Transfer Belt, Drum Unit (oop4cl) for HL-2700CN MFC-9420CN Logo
195 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
