Question about Kyocera KM-1505 Copier
6400 what does it means exactelly "c6000 and c6400" in KM1500??
  • Idriss B
    Idriss B Jan 06, 2009
    thanx jpd8 for your help :)
    I already solved the "c6000" problem by "163" solution...but after several days it shown again.
    Novelist:
  • 126 Answers
Hello, the c6000 is the Fuser heater 1/2 defective --- but is you are getting the c6400 --- is a zero cross signal error which means defective PWB. You must replace the engine PWB or the power source PWB and check for correct operations.
The cheapest route would be to replace the fuser but with the c6400 code I believe you would just be throwing your money away.
Posted on Jan 05, 2009
How do I reset xerox C6000?
C6000 km-1820.3gp - YouTube
? 0:55
www.youtube.com/watch?v=Ef0WwaTXgtQ
Oct 6, 2010 - Uploaded by natasmanda01 Cancelamento dos codigos de erros c6000, c6400 e c6020 da kyocera ... HOW TO RESET AND HARD RESET KYOCERA HYDRO XTRM ...
Printer Resetter: Solving error C6000 on Kyocera Mita printers
pritner.blogspot.com/2013/08/solving-error-c6000-on-kyocera-mita.html
Aug 8, 2013 - c6000. error. Error Message Check Ink U041 · Xerox WorkCentre C2424 DADF Error ... SSC Service Utility Software to reset Epson printers.
Oct 19, 2015 | Xerox Phaser Office Equipment & Supplies
What is c2704 in konica minolta c6000
I think that is the code for the black charger unit. It might be the charger itself or a board problem. Make sure the black charger is seated correctly.
Nov 01, 2014 | Konica Minolta Bizhub Press C6000 Copier
Have error: C6000 on call for service c6000
The error code(C6000) Maybe the broken fixing heater wire. In fixing warm-up, the time to reach 50 degree(C)/122 F exceeds 10s, the time to reach the primary stabilization exceeds 10s or the time to reach secondary stabilization exceeds 24s. Or the Fixing heater M or s installed incorrectly. Check and re-install if necessary or replace the fixing heater M or S
Aug 23, 2014 | Kyocera Mita KM-2050 Printer
IC 601 controller is connected to my konica minolta bizhub C6000 printer but display is showing controller is not connected
check the cable between the print controller/firey and the copier, also is the print controller/firey set up for a c6000
Feb 07, 2014 | Konica Minolta Office Equipment & Supplies
C6000
http://fix-your-printer.blogspot.com/2012/05/solving-error-c6000-on-kyocera-mita.html see this
Feb 17, 2013 | Kyocera TASKalfa 180 Copier
KM-2035 error call service c6000
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
Aug 23, 2009 | Kyocera Mita Office Equipment & Supplies
Km1500 kyocera troubleshooting code c-7 and 980
That code indicates that there is a problem with the waste toner bottle either being too full,
which means that it must be either emptied or replaced,
or that the sensor that senses the amount of toner is defective.
The only thing that you can do is change the waste toner bottle,
Your manual will show you the steps on the procedure for it.
I hope this resolves your problem.
Regards,
Jeep Brainy
Aug 14, 2009 | Office Equipment & Supplies
Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Sep 25, 2008 | Kyocera FS-1118MFP Laser Printer
Kyocera KM-1505 Copier Logo
580 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
