Question about Dell Inspiron 1525 Laptop
Dell inspiron 1525 says limited or no connectivity
My laptop internet connection was working perfectly fine. 3 days ago i lost internet connectivity. I repaired the connection, that didn't work so then i reentered the wifi password for the wireless connection I am using. It worked. Then about 10 minutes later I lost wireless connection. I tried repairing it and it will connect from time to time for a few minutes. As of right now it is no longer letting me use the internet. There is a red x over the wireless network connection and it will search for a connection but nothing will connect. When it is searching it says it has excellent connection, but then the red x will appear again. My boyfriend uses the same wireless connection on his laptop and it is working fine for him. I also connected to the wireless connection on my sprint hotspot and used the internet on there and it would connect. I have no idea what the issue is and I have a ton of homework and studying to do! Please help. I have not installed anything on my computer!
  • joecoolvette
    joecoolvette Nov 07, 2012
    May be the Wireless Module that is the problem; 1)http://www.getpartsonline.com/wm3945abg.... 2)http://support.dell.com/support/edocs/sy... You stated repaired connection, which leads me to believe you reinstalled the drivers. Dropped now leads me to believe the Wireless Module ('Wireless Card'), is bad.
    Top Expert:
  • Dell Master
  • 23,236 Answers
Could be an issue with the router. Try resetting the router.
Posted on Mar 08, 2017
Nic61
  • 1073 Answers
SOURCE: Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Posted on Dec 05, 2008
SOURCE: Wireless internet problem,help please
Please disable firewall if you have on your computer and then check for the issue
Regards
Syed
Posted on Jul 18, 2008
mycomputertu
  • 35 Answers
SOURCE: can't connect using wirless internet with dell inspiron 2200
There is no switch on an Inspiron 2200. I would go to Dell's website and download the drivers for your model # and then uninstall the existing adapter. then try installing the new driver and let me know what happens.
Posted on Feb 19, 2009
  • 73 Answers
SOURCE: Inspiron 6400 detects networks but does not connect to internet
Make sure you are connecting to your own internet connection through your wireless router and not on your neighbor's.....limited connectivity means you are out of reach or signal is blocked....
Posted on Apr 11, 2009
Geekman
  • 32281 Answers
SOURCE: My Dell Inspiron 1525 has been connected to
Sometimes when you boot up the wireless card does not get an IP address from the wireless router. If you have an wireless icon on the task bar with a red X on it then right click on this icon and click Repair, if not go to the Control Panel - Network Connections - right click on the wireless connection and Repair. This will force the wireless router to issue the wireless card with new IP address.
If this doesn't work check the Device Manager to see if the wireless card is enabled and functioning, if not reinstall the wireless driver and configure it to match the wireless router settings.
Posted on Jun 24, 2009
How do you change limited internet access to full access
Limited access usually means you have full access to your network through your hotspot, but the hotspot is not connected to the internet or it cannot get a signal.
Sep 25, 2012 | Dell Inspiron 1525 Laptop
Hello, I have Dell Inspiron 1525 Laptop and wireless Internet doesn't connect. I see the wifi light is ON and I see in Internet connection it shows my profile as connected. But if i browse internet does...
Please connect your computer directly to your DSL / Cable modem and check if your internet is working fine, if not turn off your modem and restart after a minute or two.
Now check again if the internet is working by directly connecting your laptop to your modem. if it is not working, contact ISP. if it is working, turn on your router and check if your wireless connection is working.
If you wireless connection is still not working, please check if you have plugged the modem to the internet / WAN port behind your router.
Also try logging to your router page (refer to manual for procedure) and try changing the wireless channel.
Dec 24, 2010 | Dell Inspiron 1525 Laptop
Hi, I have reinstalled my window XP SP3 but after reinstalling window my wireless(Adapter name: dell wirless 1395 WLAN mini-card) is not working properly. I have installed latest driver on my Dell...
Verify that you have the correct type of authentication in wireless- if your router is set to WPA2, then you would have to go under the connection properties > security tab to change it to match that setup. If that does not work, then the issue may be that the wireless card is defective and starting to fail.
Nov 22, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 laptop not detecting battery
Looks to me like the battery is bad, try another battery if you can and see if the laptop charges it. If it does then the battery is bad, if it doesn't then its something with the motherboard.
May 21, 2009 | Dell Inspiron 1525 Notebook
Network Adaptor Not Working After Windows Vista Re-installation
Go to Dell's website and go to Drivers and find your computer and download the network adapters driver and install it.
Dec 30, 2008 | Dell Inspiron 1525 Laptop Jet Black
Wireless connection/will not connect
try gettin a disc what is got the internet on or a wire think
Dec 01, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1525 Laptop Logo
114 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
