I have ibm monitor, when i connect it to my pc. it shows the message no connection check signal cable. pl. help
  • 43 Answers
Either the video card is not working inside the computer, you're using the wrong video card, or its resolution and/or refresh rate is set higher than the monitor can handle.
Posted on Jan 05, 2009
My new moniter of aoc is not working and showing message that No Signal i cheacked power cod and cheacked other power cods but still showing same mssage
Usaully when monitors show message that means the monitor is working fine what you have to check if the cable going to the computer is good and connected properly and if so you have to troubleshoot your pc.
Regards
Mar 07, 2015 | AOC Computers & Internet
Problem with the monitor
hi,
first of all,try to connect the cable to other device(laptop) to see if is working,because if you receive the message"No signal" then the monitor is working but the cable/signal did not cross to the monitor,then is working with other device then try again or check if you can connect the monitor with different port if you monitor has one vga/dvi or hdmi.
Aug 25, 2014 | Acer Veriton M460 Micro Tower Core 2 DUO...
S24a300b problem, not detected by pc. message on display say "check signal cable".
Check signal cable means that your monitor wire is not connected properly.
So remove your cable connect it tightly once again.
Tightly connect with cpu and power supply.
Thanks for using fixya
Aug 19, 2011 | Samsung S24A300B Monitor
Acer x136w monitor, no signal. Connected parralel conector to back of computer. no signal..tried everything I know to do. Even stupidly pirchased driver whiz. nothing. ready to through monitor into th e...
No signal message on your LCD monitor screen means that your monitor is not receiving any signal from your PC graphic card. This problem "no signal" have nothing to do with the drivers installations. Have you check whether your graphic card is faulty or your cable connection properly connected/secured? ie VGA (D-sub). As far as I know there are no parallel connectors for PC Monitor connectors only, VGA(D-sub), DVI or HDMI cable interface.
Try to connect your monitor to another PC, just to test whether the LCD monitor is functional.
Hope it helps.
Mar 19, 2011 | Computers & Internet
My proview pl 926wbi comes on with a black screen and a no signal message then shuts off.
Check that the cable is firmly connected and plugged into the right connection on the computer. Make sure that the monitor is reading from the right input, (i.e. if it's a blue connection it should be set to VGA/Analog, if white then it should be DVI/Digital) or at least set to Automatic.
This can be configured on the monitor by pressing its' Menu button.
Feb 28, 2011 | Proview PL926WBi 19" LCD Monitor
I show on monitor "no signal" Check Signal Cable
Check that the "data" cable between your computer and your monitor is tightly connected at each end.
Connect the VGA-output port from a laptop computer to the monitor, to see if the monitor works when connected to a different computer.
Connect a different monitor to the VGA-output port on your computer, to see if that monitor works.
Failing all the above, the video-card on your computer is the problem, and needs to be replaced.
Nov 05, 2009 | E-Machines (T3104) PC Desktop
Message: check your PC and signal cable
That Means the Monitor Does Not Detect Your PC..Check The Video Cables And See If they Are Fully Connected
Apr 01, 2009 | Computers & Internet
Monitor fault
Try removing the RAM from the motherboard & fix it again...... if this will help you u might not need to go service center.......or check the dispaly cable which is connected to your CPU........hope thjis will help u...............Sameerrayan
Jan 12, 2009 | Computers & Internet
No Signal
No signal on screen means that there is no input for your monitor from the PC.
1. There might be problem in your PC or in the cable connected to PC from monitor.
2. Your PC might damage that it could not send signal to the monitor.
2.1 In your Motherboard might be faulty in the VGA chips.
2.2 In your Motherboard's SMPS mean power supply.
I think you can got my point. If you are tech person it will help you, otherwise you should take a tour to any service centre.
Thanks & Goodluck
Iqbal
Jul 21, 2008 | Intel Desktop Board D845GLVA...
Problem
hmm,
Exact message could Find a Closest solution.
anyways, what you might be getting is a message like,
No Input signal,Check Video Cable.
it means that the Connection from the Monitor to PC is Loose,
Connect them Secure and tight to FIx it.
Jul 16, 2008 | LG Flatron Ez T710BH 17" CRT Monitor
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
