Question about Kenmore 95002 / 95004 Electric Kitchen Range
While in middle of baking all power lost to range. Checked all breakers and they are fine. Is there a reset botton on the range? Range is about 11 or 12 years old.
  • l_pete
    l_pete Nov 07, 2012
    This range is a Kenmore 95002,
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
I don't have anything on that model number. Please look inside the oven or the bottom drawer for the model number.
Regards,
Richard Roth
http://appliancecafe.com
Posted on Nov 08, 2012
reg501
  • 413 Answers
SOURCE: Kenmore range model 790.90152300 the
The electronic oven controller has failed. The cost is around $160.00.
Posted on Jun 26, 2008
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
SOURCE: Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
Posted on Dec 24, 2009
EllaWatson25
  • 725 Answers
SOURCE: I have a Kenmore electric ceramic top range. While
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Posted on Mar 11, 2010
Testimonial: "Sorry about not putting in the model number, etc. I bought a used burner switch for 10 bucks and the burner seems to be working...we'll see. Thanks "
blueextc3221
  • 15935 Answers
SOURCE: Stove was on bake set to 350. Only the broiler
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*&#$%
Posted on Sep 29, 2010
Testimonial: "Thanks for the quality information and advice. Gave me the options and answers I needed to get this fixed!"
Blue lights flashing can not get to reset
Hey Troy, I understand that you are having problems with your Electrolux Dual-fuel Range. Have you recently installed the range or had a power outage? When the range is first plugged in, or when the power supply to the range has been interrupted, the indicator lights will flash and the control will beep. To stop the lights from flashing, turn the selector control knob to BAKE and back to OFF. You can also attempt a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 26, 2015 | Electrolux Icon E30df74gps 30" Pro-style...
My fridgedaire oven will heat up fine on broil but when I put it on bake it only gets to 280 and stops heating
Good Afternoon Friend,
I understand your Frigidaire range, model# PLEF398AC, heats up fine on broil, but only hits about 280 degrees F when put on bake. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, set the clock, and try setting the temperature to 350 degrees on bake. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire PLEF398AC Electric Kitchen...
Replaced the baking element in my frigidaire oven but it still isnt working
Good Morning Karenand, thank you for your post!
I see that you have replaced the bake element in your Frigidaire range but it is still not working. If you wouldn't mind please providing me your model number, I can better address the issue at hand. The serial tag, which lists your model number, is typically located in the storage drawer, on the right side.
Meanwhile, I recommend resetting your range. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn your range on. If resetting the power does not correct the issue, your range could be experiencing other issues such as: a communication problem with the EOC (Electronic Oven Control), an open thermal fuse or a potential wiring failure.
I ask that you please follow up with a comment, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully.
Best of luck!
Jan 26, 2014 | Frigidaire Ovens
Locked Oven Door
You mention shutting off the power. Did you use you circuit breaker to turn off the oven. If not, you should try shutting off power using the circuit breaker. Turn off breaker, wait at least a few minutes, then turn breaker back on. This may reset the oven
Dec 25, 2013 | Electrolux Icon E36DF76GPS Dual Fuel Range...
Our larger oven will not turn on and the led lights do not work either. the smaller oven does turn and led lights work. All burners work fine any ideas??
Hello Brian, thank you for allowing me to assist you!
I understand the larger oven of your Electrolux range is inoperable. Let's try resetting your range by either unplugging it or flipping off the breaker for about ten minutes. An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. In this case, your appliance may possibly be experiencing a communication properly with the EOC (electronic oven control), faulty bake/broil element, or a potential wiring failure.
Dec 16, 2013 | Electrolux E48DF76EPS Dual Fuel Range
Is there an oven reset button on a frigidaire range fefl79jba?
Hello G Rego - The range may be reset by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, turn on the range and select bake or broil option. Should all troubleshooting measures fail, I would strongly recommend consulting a professional to move forward accurately. The range could possibly be experiencing a wiring failure, EOC (electronic oven control), sensor probe and/or faulty element(s). You can often local service providers by visiting the manufacturer website.
Feb 28, 2013 | Frigidaire FEF336BC Electric Kitchen Range
Oven doesn't heat up all the way on our Jenn-Air duel-fuel range
all repairs should be performed by an authorized service person. if your breakers were tripped there is a high voltage short or weak home breakers. when resetting the breakers make sure the dual breaker switches are in the on position. if the is ok check for the proper voltage is at the power outlet is correct.if it is ok unplug the range. be sure not to break the gas line. remove the rear panel check to see if the power cord power cord is secured to the power cord terminal.if the terminal is damaged do to the shortage at the terminal replace the terminal and power cord. when replacing the power cord and install the power cord restrain that usually comes with the.power cord.
Jun 02, 2017 | Jenn-Air JDS9860AAS Dual Fuel (Electric...
316418305 broiler element and bake element will not heat
I see that you are having trouble with your Frigidaire range, model# FEF336BC, broiler and bake element not heating. I would give your range a hard reset. You can do this by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn your oven on and if the elements are still not heating, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 23, 2012 | Frigidaire FEF336BC Electric Kitchen Range
Gas stove Thermadore 36 inch Model PGR366 PL Oven wont bake but will broil
this may seem like a silly question if you've already tried it but have you checked the over temp breaker? If you have no idea what I'm saying there is a breaker on the back side of your machine. Of course Thermador is so kind to place it convenietly behind the back panel so you'll have to remove that. There should be a little red button in there somewhere toward the top middle half of the machine I should say. If you press that button it may work.
Nov 05, 2008 | Thermador PGR366 Gas Kitchen Range
Bosch HES255U Covection bake slow to get up to temp.
My Bosch HES255U Freestanding Electric Range has been reading an error code of all "E's" or r 2 E E. I shut it off completely through the circuit breaker and allow it to reset. When I turn it back on, it starts to beep and shuts off.
Nov 01, 2008 | Bosch HES 232 / HES 236 Electric Kitchen...
Kenmore 95002 / 95004 Electric Kitchen Range Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
