Sometimes when using the progress bar to fast forward a recording quickly by percentages the unit will crash and turn off and back on again and have to verify files and folders. Now it wants to format the hard disk I don't want to as I will lose all prerecorded programs
  • 27,725 Answers
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive
hope this helps
Posted on Nov 08, 2012
SOURCE: After blackout Mac-formatted ext. hard drive won't mount says its pc-formatted
Here is my best guess and strong suggestion. First do nothing else until you have your work off loaded to some other drive or media....and I mean do nothing....don't even turn it off until this is completed. Once that is done verify your work is there. Then learn to smoke or drink and sing hallelujah.
My best guess is you lost the FAT (file allocation table)...meaning it got (literally) zapped by the power failure (spike) which makes sense since it's continually being accessed. Lacie should have a disk diagnostics program on their website....that loaded onto a diskette or cd would be my first step. It will tell you if the drive is good or not. If good and after you have off loaded your files to a safe media then the fastest solution is probably to reformat and reload your applications then reload your files. I say fastest as (in my twilight years) I have almost (it's a pride thing) given up solving hard problems the hard way...particularly when they can be both hardware and software interrelated.
A couple of other points....uploading to the net your files (even if it costs) or using a bit torrent to transfer to a friends machine (pay for the other drive) or using raid (which I am not a big fan of) or copying them to a one touch....(possibly the least expensive solution (just start it at night...it's not fast the first time and do it daily). You have too much invested to get had by Mother Nature.
Why would I tell you this....well, there was the time I worked all night to finish some code and just as I finished (without saving once) and feeling satisfied I stretched back, extended legs and knocked the plug out of the socket. I also had a computer shop
wipe my disconnected spare duplicate drive at the same time they wiped my master. Today, and I have multiple large projects I work on (mine...not others), and despite more backups in more ways than you can imagine I am still subject to bouts of paranoia.
Lastly....Am not up to date with Mac but at some of the freeware sites I have run across utilities that might be of help. Trying to restore the fat (Windows keeps two copies) might be a possibility and I assume Mac has something similar. But I would only attempt this based on what the drive diagnostics results are....i.e. if you have more than 4 bad clusters it's probably not worth taking the chance of another major disruption. Hope this helps or at least points you in the right direction. Tango
Posted on Jan 25, 2008
SOURCE: can't access files on external hard drive
Hi All had the same prob with my external drive and used a program called Easy recovery professional it worked for me .hope this works
Posted on Jan 04, 2009
SOURCE: Unable to access external WD 500 Gb drive: "You need to format the disk"
I have battled this for a few days. Your mentioning USB leads me to a possible solution.
I had a 500GB drive and put it in the USB enclosure and could only see 128GB one time, 138GB another. I found that external drive enclosures have their own IDE controller chips with older ones limiting the size of the drive they are able to "see".
The best test is to internally mount the drive (perverts will read this differently than intended and risk injury due to shock!) to make sure it can be seen. If so then the next best step is to spring for a new drive enclosure, one that supports the higher capacity drive. It worked for me! My old external enclosure's IDE controller could not handle the higher capacity drive and the new one was perfectly happy with it. Good luck! - Andy C
Posted on Apr 09, 2009
male_28_cam
  • 1555 Answers
SOURCE: doesn't show any files and folders when drive opened
Congrats, You got a nice virus. Its better you backup your drivers and data from ur root partition format it. reinstall your operating system and install avg 8.5 before browsing any of the other partition. I can surely tell u your task manager, registry editor or show hide folder won't be working. There is no permanent solution to this other than format. But beware don't browse other partition before installing avg 8.5. Your earlier installed antivir has given its way to virus its of no use. You won't be able to install antivirus or visit any malware removal virus site. welcome back.
Posted on Jun 14, 2009
SOURCE: Avira antivirus disappeared folders and files
I have the same problem ! I have created a folder in windows seven, and i have downloaded some possible malicious file, a .exe file, and avira did something to it, beacuse know i can't see my folder anymore. My folder is not hidden, i checked it few times in folder options ! From run > cmd i cand access cd Donwloads from D:, but if i isue dir command in D: i don't see the folder...
Posted on Feb 13, 2010
Tape is playing back in fast forward only
It is possible the tape loaded on the wrong side of the drive. If you romove the tape, look for slack and tighten up, try it again or another tape. Otherwise it is likely that a spring for the pressure roller is off or broken. This is not easially repairable.
Oct 19, 2011 | Sony M-670V Handheld Cassette Voice...
Skipping ahead when viewing recorded programs
It sounds liek your remote control button is sticking inside a bit.
To test it, have it playing, and hide the remote under a cushion so it can't possibly send a signal to the main unit.
Sometimes the rubber buttons need cleaning underneath, even though they don't appear to be stuck down at all.
Its also possible that the remote is actually just going faulty emitting fake signals. I have a HiFi that turns on and starts the radio all on its own (spooky!!!). I found its the remote occasionally sends a radio-on signal about once a week to the HiFi :)
I just hide the remote now unless i'm using the thing.
Apr 03, 2010 | Logitech Harmony 880 LCD Remote Control
Canon DM-XM2 Will not record or play back
Clean Idler unit it is magnetism and clean sensor it will work
Mar 08, 2010 | Canon DM-XM2 Mini DV Digital Camcorder
Dazzle records and then it shows back in fast forward motion
Hi and welcome to Fixya,
When recording your video using the dazzle and it shows fast forward in motion I would suggest to you to go ahead and record it again but this time disconnect your dazzle and reconnect at the back of the usb port of the computer and from there check and try recording again.
If still the same problem you need to uninstall your device driver. Click on start>control panel>system>hardware>device manager>sound video and audio preferences>look for pinnacle dvc 100 video device right click and uninstall it. Restart the computer. Go back and check and record it again.
Jan 07, 2010 | Pinnacle Dazzle DVD Recorder
Vhs to dvd
Recording is disabled when the progressive scan mode is on. You have to reset the unit first.
Take out any disc or tape. With the unit on, hold down the Rewind and Fast Forward buttons together for 10 secs.
Then turn the unit off and on. It should work fine after that.
Jun 29, 2009 | Samsung DVD-VR357
Cannot play tape.
Sometimes that happens to me too. What I do is just push play, then fast forward, and normally if you watch it, the picture starts to come back. Just keep fast forwarding until you can see all of the picture, and you should be fine.
Mar 24, 2008 | Panasonic PV-GS19 Mini DV Digital...
Problems with recording/rewind/fast forward
You probably have a bad power supply. But as you will learn, repairing any VCR will cost more than buying a new one.
Feb 17, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
DVD Recorder
During MY long, intensive, painful research concerning the EXACT same problems, I've discovered that in ONE circumstance, these problems are caused whenever the recorder has INPUT (COAX, AV, etc), from a CABLE box!!!! Assuming the controls haven't already frozen, I disconnected the CABLE box from the recorder, and the recorder "came back to life!!!" And this, after bring my recorder in for "repair", THREE TIMES!!! Now, the only thing to resolve is: how to connect the CABLE BOX to the recorder--WITHOUT using any of the recorder's input jacks!!!! Progress, right?
Mar 11, 2007 | Panasonic DMR-EH50 DVD Recorder
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
