Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
Failure to boot
Just turned on my FA Porsche external firewire HD and it is failing to boot. Previously it had always booted up within about 20secs of turning it on and then appeared on my desktop pretty much immediately after. When I turn on now, the light just remains orange and, after an initial burst of energy that sounds like it is powering up, nothing else happens. I last used the drive about 2 weeks ago where I ejected it from the desktop properly - there were no apparent problems at this stage and turned it off a couple of hours later when I shut down the rest of my equipment. There have been no known power surges at the property - all computer equipment also plugged into a surge protector socket. Have tried to start it without it being connected to my Macbook; have tried leaving it on for a while to see if it boots up on its own; and have also tried the classic turning it off, leaving for 15 mins, and then trying again. Please help! I need all the information on there. Many thanks!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
This model appears to have a high failure rate in consumer reviews, so it may have physical damage on the disk. Only a re-format of the drive will isolate bad sectors that won't hold data. Try re-mounting your drive after a fresh re-boot of your computer. If the drive came with the manufacture's software to allow it to communicate with your computer, then try removing this software from your system and re-installing it again. This will repair a corrupt driver or I/O program. Try using the drive with a new or different firewire cable. Other users have reported this drive working again after replacing the cable. If you use Mac OS 10.2, you might not be able to initialize or partition the hard drive. This may require you to partition and format the drive on a different computer. From your brief description, it sounds as though you may need to re-format the drive before it will work again.
Posted on Aug 02, 2007
We understand that your problem is: We understand that your problem is: Hello, I have Lacie porsche external hard drive. I also have a seagate firewire external drive which us working fine. Unfortunately...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 18, 2010 | LaCie F.A. Porsche (301177) Hard Drive
When trying to start my computer emachinesE627, i have a black screen that says error loading operating system
The computer can not see the Operating System. This can be caused by several things, so I will just list a few possiblities for you here:
If you have a USB flash drive or external HD plugged into the PC. Remove it while the computer boots. Some machines are set to boot from a flash drive and will search for an operating system on it and display NO OS if the bios can not find one.
If the Hard drive has been removed or replaced recently then the Jumper settings may not be correct on the new drive.
If the computer was having trouble booting periodically, freezing or experiencing blue screens before this message, then you may have HD corruption or possible disk failure. With HD corruption you only need to run chkdisk /p within recovery console in XP or run the Vista recovery center with vista. HD failure is a dead disk, no option but to replace.
Bad RAM or a dead CMOS battery can also cause this type of failure. So check these also.
This can also be caused by a damaged master boot record or primary boot partition. Run fixboot or fixmbr from the recovery console on XP or just run the Vista Boot Repair Console in Vista
Worm Viruses and Rootkits that damage the primary boot sector or the Master Boot Record can also cause the OS to mysteriously disappear. So if none of the above sound like they are for you, then you can try looking for one of these on the affected drive.
Hope this helps,
Gill
Aug 28, 2010 | E-Machines eMachines Monitor E15T4
When using Firewire bus to power the sound card my
It's likely that the FireWire bus isn't meeting the power needs of your card. Just use the external supply since there isn't too much you can do.
Jul 13, 2010 | Edirol FA-66 Sound Card
Laptop freezes when connected to external hd
I am assuming the external is connected while booting up, if so then the laptop may be seeing this unit as a bootable drive. You would need to enter into the BIOS of the laptop and change or make sure the external drive (i.e usb connection) is disabled. Save and reboot with the ext disconnected, log into windows and when it has finished loading, connect ext drive. I hope this helps.
Jul 01, 2009 | Computers & Internet
PC not recognising HD
I havea Western Digital Mybook that did that. I was out of warranty and didn't feel like paying a butload for data recovery, so i ripped out the sata hard drive, and it works like a charm. If youhave a warranty you could try or look on the the manufacture's website and findany support. If all alse fails get out the screw driver.
Nov 21, 2008 | LaCie Computers & Internet
My external won't show up on my laptop
some laptops don't have enough power to just use the firewire cable. try also using the USB power supply that came with the HD
Oct 30, 2008 | LaCie F.A. Porsche (301177) Hard Drive
Not showing up
recheck to insure partitions rexcognized and reinstall unit driver.
Jun 22, 2008 | LaCie Design by F. A. Porsche 80 GB Hard...
Lacie 1tb hd
You can try to boot up with Linux LIVE cd and plug on the external HDD.
Apr 24, 2008 | LaCie d2 Extreme 250GB External with...
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
156 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
