Question about Sony RM-945 Remote Control
Codes for aoc - Sony RM-945 Remote Control
Nesecito los codigos para una tv aoc
0028,0021,0020. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 12, 2013 | Televison & Video
I need to program a VA-405 with a AOC television
Codes to check with AOC TV are:
0004 0005 0009 0014 0156 0175 0187
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Apr 29, 2012 | Televison & Video
What is the comcast remote code for aoc envision tv L32w761
Directly from Comcast.com
AOC 3,010,017,025,044
Hope this helps.
Aug 27, 2011 | AOC Envision L27W461 27 in. HDTV LCD...
I Want to know ,what is the code of R939
Try this:
http://www.eserviceinfo.com/downloadsm/35768/AOC_CT700g.html
Aug 09, 2009 | AOC CT700G 17" CRT Monitor
Color coding in signal cable for AOC CRT monitor
what do you meen by (color coding in signal cable for AOC CRT monitor) i might be able to help you if you can explane what you meen thank you.
Apr 22, 2009 | AOC CT720G 17" CRT Monitor
CODE FOR AOC L26W781B
sorry to trouble you as i did not have one of your controllers , and was looking for a code for my AOC TV, WHICH IN THE END SURFING THE NET STUMBLED ACROSS AN AOC CODE FOR ANOTHER AOC TV ,TRIED IT AND IT WORKED .
THANK YOU.
Jan 21, 2009 | One For All URC-3300 Remote Control
Remote control codes
my mums remote control for her aoc television has broken i bought a new universal remote but there is no code for the aoc television i have tried the other method avaliable but the television still does not accept it what do i do now
Sep 21, 2008 | Televison & Video
Monitor Repair
I disconnect the cable that connects the CPU, the cables came off, I need the connecting diagram for the monitor AOC 1770, the combination of the cables in the connector to the CPU, thanks
Dec 14, 2007 | AOC CT700G 17" CRT Monitor
Televison & Video Logo
20 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
