Question about Fujitsu Siemens PRIMERGY C200 Server
Primergy c200 no booting
The server is not booting , no display m/b psu ram and processor are working as tested in other machine i cannot figure out the problem regards
    Genius:
  • 2,985 Answers
Fujisu Web site Tech Support Team will be able help on this
Posted on May 25, 2007
Computer wont boot all the way up
There are several reason why a computer won't boot up. First you need to figure out if your Power Supply is working, if your not a computer expert, you can try another PSU to test. Or you can use a PSU tester to test if your PSU is still working. If not, clean and reseat your RAM, if you have 2 RAMs, remove each RAM then try 1 RAM at a time, and try to seat the RAM to different slot. If not luck, clean and reseat your graphics card. If you have a built-in video port, remove your graphics card. Still won't boot? try resetting the CMOS. This might fix the problem.
Sep 07, 2012 | Acer Aspire X3200 PC Desktop
Why is my Dell Optiplex 320 indicating orange led and not booting nor display?
check the ram.change the slot and disconnect the hardrive before that
Apr 19, 2012 | Dell Computers & Internet
I have a server mother board I can get it to past post and it does not display anything when I turn it on this is the 4th motherboard and 3rd processor also got a new stick of ram and still same problem....
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
or it might be your graphics card make sure its securely seated and there is no dust built up
on and around the graphics card hope this helps
Apr 21, 2011 | SuperMicro (X5DL8-GG-B) Motherboard
Dell PowerEdge 1600sc server won't boot.
> black screen & flashing cursor ...
Damaged boot-record on the disk-drive???
Was it configured to try to boot from 'A:' ?
Disconnect the hard-drive & CD/DVD drives.
Put a diskette into the drive, and see if it tries to find a boot-record on the diskette.
If it tries, then it has P.O.S.T.'d correctly.
> no beep codes
When it worked, did it beep _once_ when P.O.S.T. completed?
Taking out the RAM _should_ cause some beep codes, i.e., "no RAM".
> anyone?
Replace the monitor?
Replace a dead video-card?
Or, add-in a video-card, and connect a monitor to it, leaving the original monitor connected to the original video-card. One of the two displays should show the P.O.S.T.
Jun 12, 2010 | Dell PowerEdge 1600...
I have a gateway 506gr with a Bestec atx300 psu. I was having problems being able to turn the computer on, then one day it would not turn on at all. I can push and hold the power button, and hear the psu...
Your psu is works fine.
First open cpu cabinet and find motherbord.
Pull CMOS cell from m/b for 10 minutes.
Refix RAM Memory.
Pull procesor fan and processor clean dust from all parts.
Then fix processor fan and processor.
Reconnect ATX connector to m/b.
Remove pci cards from PCI slot then check.
Let me know if you need more assistance.
Thanks.
Oct 01, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
No display cpu fan are'nt running though there is green and orange light on server
Hello there,
Check your power supply and see if its functioning.
CPU fan that does not run means there is no power getting into the motherboard.
Thank you for using Fixya
Apr 06, 2009 | Fujitsu Siemens PRIMERGY P200 Server
Is it possible to repair c200 power supply
Fujitsu C200 has very precise power supply. And it is always recommended to buy new one.
Jan 27, 2009 | Fujitsu Siemens PRIMERGY C200 Server
Is it possible to repair the power supply of fujitsu c200 server?
Anything is possible if you have the expertise and skills. However, it becomes a question of Value. Is it worth the several hours of your time to trace down the faulty part and replace it?
Boot-failure
I habe exactly the same problem. I habe the P45 Neo3 Board with E8400 CPU and 4GB Dominator RAM(1066MHz). No signal aber reboot. A Bios-Reset helps vor a Moment, but after Restart, i habe no signal.
Jun 16, 2008 | Intel Motherboard
Fujitsu Siemens PRIMERGY C200 Server Logo
252 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
