Question about Vacuums
The bellt is smoking
Trrn it on it smoks
    Top Expert:
  • Vacuums Master
  • 14,553 Answers
Check the shaft the belt is driven with for black residue from the belt===residue will cause the belt to slip and also can cause from friction smoke there===clean completely with alcohol or very, very fine steel wool.
Posted on Nov 07, 2012
Kirby is smoking?
Send it back
It smokes & has no manual
You don't want either situation
It is defective,obviously
May 12, 2014 | Kirby Vacuums
Hoover Windtunnel Bagged upright vacuum is smoking and belt is slitting and burning
you probably need to replace your brushroll seeing that your belt is burning means motor is turning. first check you brushroll and see if there is an obstruction keeping it from spinning if its not spinning freely replace
Jan 16, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
How to fix a vacume that is smoking
any electrical unit that smokes,is ,not worth repairing
Jul 01, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
I have Hoover Widepath Bagless 12 Amp Windtunnel vacuum. Yesterday I was vacuuming and smelled smoke and it shut itself off. Today I cleaned out the filters (they weren't bad) made sure nothing was...
Hi There,
When a vacuum cleaner smokes, it is usually only one of two possible problems.
It could either be that your motor burned up, or that your belts burned. The belts on this particular model are notorious for breaking, but the fact that your machine doesn't come on at all after this happened, sounds like it may be the motor.
Both of these issues have a unique smelling smoke. If the smoke smelled like an electrical burning smell, this indicates it's your motor. If the smoke smelled more like burning rubber, then it's probably your belts.
If the smoke smelled like burning rubber, here's a video that we've recorded showing step by step how to inspect, trouble shoot, and replace the belts on your vacuum cleaner. If you open it up and the belts are still in tact, then this probably is a more serious problem of the motor burning out.
. I'd be more then happy to walk you through more advanced diagnosing if this doesn't fix your problem, please just use the comment box here on the Fixya repair page.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me. This is really appreciated by the Fixya community if the repair solution was able to fix your problem.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Hoover Self-Propelled WindTunnel Bagless...
I accidently sucked up a pen cap and it stopped working then it began smoking and the belt snapped??
Take the pen cap out of where it is stuck and replace the belt. Most likely the smoke was from the belt slipping around the gear and getting hot. Did the smoke smell like burning rubber?
Oct 01, 2009 | Bissell 3576 CleanView II Bagless Upright...
Bunning smell.
Is it an electrical smell or a rubber type smell. If there is no smoke, it could be that the belt is slipping and causing a smell. If it is the motor, usually it would smoke, or at least quit running and making strange noises.
Jun 16, 2008 | Vacuums
Eureka Altima is smoking!
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618889&thid=606496
Posted by saysay on May 18, 2008
Help! My vacuum is smoking. It won’t work anymore and starts to smoke as soon as it gets turned on.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Eureka Altima Upright Vacuum Model #2996AVS – it is probably doing 2 things, it could be the belt and or brushroll and the easiest ay to check is to remove the belt and see if the motor smokes, if the motor is fine then buy a new belt and check the brushroll to see if the brushroll spins freely, there are bearings in the brushroll and thread and hair get bound up in the ends and needs to be cleaned out. So #1, check the belt – no smoke from the motor then check the brushroll to see if it spins freely then changed the belt. If the motor smokes check your purchase date it may still be under the one year factory warranty from the dop. #2. Either clean or replace the brushroll and belt. If you have any further questions, feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don The Vac Man
Go Ahead. Use Us.
May 18, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Smoke/motor?
I don't know in Nev. call Hoover's 800 number and they will tell you, the number is on the metal tag. But if it is the motor smoking, a motor will run you $85 to $95, plus labor, $40 to $50. But if this an electrical smell, then suspect the motor. But if it is a rbber smell, then maybe you have a belt that is slipping badly, replace the belt.
May 12, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
12 amp motor smoking
If the smoke is coming from the motor and I assume that it is, then your motor has gone bad and you will have to replace it.
Dec 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Clattering sound, then smoke
the clattering sound was probably a stone or something that was being bounced around by the rotating bush. It jammed which caused the belt to slip and cause the smoke you saw. You can probably get away with finding and clearing the jam but I would inspect the belt just to make sure.
Nov 27, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
