Canon pixma e500 error code 5802 - Office Equipment & Supplies
SOURCE: canon pixma ip 1500
anon PIXMA iP1000
Waste Ink Counter Reset.
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
Remark "After service mode Pls use software for permanent reset"
Posted on Jan 18, 2008
SOURCE: Canon PIXMA MP140 error code E 2
error E 2 => The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
Posted on Mar 02, 2008
SOURCE: Error code 5110 Canon Pixma MP500
Error 5110 = Kann den Schlitten nicht anheben. (mechanischer Fehler)
Posted on Sep 13, 2009
  • 1335 Answers
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
Posted on Dec 19, 2009
trisha8765
  • 120 Answers
SOURCE: Any help with a Canon Pixma MP 250 P2 Error Code?
I found you a site where you can download the latest drivers to install at the link below Good Luck
http://support-au.canon.com.au/EN/search?canonsearch=1&lang=EN&category=All-in-One Printers&series=All-in-One Printers&model=PIXMA MP250&menu=Download
Posted on Dec 27, 2009
How to resolve erreur code E000051-0000 whith canon ir 2800
the Canon E500 printer is one of the most advanced printer which is build upon the latest printing technology. The printer comes in medium-size device and is reasonably light weight of around 5.3 kg. The black plastic body has no sharp edges, and the design is fairly pleasant to appear. The trays of the Canon printer Pixma E500 are quite flexible to use according to Canon Pixma E500 Printer Supportprofessionals. Its glossy finished touched feature makes the printer most eye-striking among users. But here in this blog, we will be introducing you guys with various Canon Pixma E500 error codes that you need to know.
List of top Canon Pixma error E500 codes
Error code 1: Canon E500 Error Code E02 (E,0,2)
  • This error symbolizes that printer is out of paper or is incapable of feeding any document.
Error code 2: Canon E500 Error Code E03 (E,0,3)
  • This error signifies the Paper Jam.
Error code 3: Canon E500 Error Code E04 (E,0,4)
  • The error signifies that the "fine cartridge" is not installed accurately.
Error code 4: Canon E500 Error Code E06 (E,0,6)
  • As stated by Canon Pixma E500 Printer Technical Support experts, the paper output cover is not in a closed state.
Error code 5: Canon E500 Error Code E07 (E,0,7)
  • The ink absorber is complete and users need to reset the counter.
Error code 6: Canon E500 Error Code E08 (E,0,8)
  • Here the error signifies that the ink absorber is almost in a full stage. Users are then required to press the "black or color" button to resume it in a proper.
Error code 7: Canon E500 Error Code E16 (E,1,6)
  • The ink in completely finished as of now. You are required to tap on the "Stop/Reset" button to resume the printing process.
Error code 8: Canon E500 Error Code E17 (E,1,7)
  • The front tray is totally closed.
Error code 9: Canon E500 Error Code E30 (E,3,0)
  • The error code defines that the size of the original cannot be accurately detected or even it is possible that the document is too small when the "Fit-to-Page copying" is selected.
Error code 10: Canon E500 Error Code E31 (E,3,1)
  • The machine is surely disconnected with the computer.
Error code11: Canon E500 Error Code E40 (E,4,0)
  • It shows that the protective material of the Canon Pixma E500 printer for the FINE cartridge or the tape is still attached.
Error code 12: Canon E500 Error Code E50 (E,5,0)
  • Scanning of the print-head alignment sheet has failed to function
Error code 13: Canon E500 Error Code P02 (P,0,2).
  • This is a critical error which shows that the printer is in malfunctioning stage.
Error code 14: Canon E500 Error Code P10 (P,1,0).
  • This error signifies that the mechanical printer is in total malfunction stage.
So, these are few topmost errors of Canon Pixma E500 printer that users need to be aware of. Our professional team of Canon Pixma E500 Printer Support experts is always available for you to help overcome with any kind of unexpected issues. Call us or even you may drop us an email to our professional email ID.
May 16, 2015 | Canon IR-2800 Copier Reconditioned
Canon pixma e505
Assuming your using Windows 7.
http://www.downloads-drivers.com/2013/04/canon-pixma-e500-drivers-for-windows-7.html
Sep 21, 2014 | Canon PIXMA Office Equipment & Supplies
5802 error
This error code is related to a print head problem. Take out each of the ink cartridges one at a time and reinsert them. Next, go to the Maintenance menu of the printer and run the 'print head cleaning' cycle. If there is a 'deep cleaning' option run that, too. If none of the cleaning cycles fix the error code you can try removing each ink cartridge and cleaning the gold contact plate with rubbing alcohol and a cotton swab. Be careful not to leave any cotton fragments behind and allow the alcohol to completely dry before reinserting the cartridges.
Apr 16, 2014 | Canon Office Equipment & Supplies
Hard disc error
the error refers to PDL board mounting error- suggest if the machine has been moved or if any parts have been removed or replaced you check ALL pwb board connections this could take some time to complete try to start where you have been working in the machine first.
Jan 16, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Help me Please ..!! i want to reset my Canon Pixma e500 series
hi folks. joana here....Please help me. I've encountered an error code with my canon e500 series namely P22. while trying to resolve it by print test, Error 5012 suddenly popped up.. I don't know what to do.. please help
Nov 04, 2012 | Office Equipment & Supplies
PRINTER E500 ERROR 5b02
How to solve error 5b02 on canon printer E500
Oct 15, 2012 | Canon Pixma MP480 All-In-One InkJet...
How to install canon pixma E500 without CD
HI how can i install e500 pixma without cd
Aug 20, 2012 | Office Equipment & Supplies
Error code 277-5802
what i can tell you is that there is a comunication problem between the printer board and main controller. the only suggestion i have for you is to call for service and have someone come out and check all the boards. unless you know how to remove them and try putting them back in
Jan 28, 2010 | Canon imageRUNNER 8500 Copier
233 people viewed this question
k24674
